Maxlife v dex/merc
by HyundaiAbuser - 09/22/19 09:24 PM
15,119 Mile Supertech UOA
by Stumpy - 09/22/19 08:54 PM
Rust-Oleum Factor 4
by CatCam2 - 09/22/19 08:20 PM
Local Walmart Magnatec Closeout- Maybe Others?
by SSerian - 09/22/19 07:32 PM
Anti theft measures for new truck
by Oldtom - 09/22/19 07:28 PM
What would you do?
by Rexinaus - 09/22/19 06:26 PM
What size wire for 5 HP motor?
by dlundblad - 09/22/19 06:12 PM
Studless V/S studded winter tires
by cecil56 - 09/22/19 06:10 PM
200K more to Go!
by Gebo - 09/22/19 06:07 PM
Toyota license plate bolts/screws
by edwardh1 - 09/22/19 05:38 PM
How Do You Clean Your Grill ?
by Warstud - 09/22/19 04:05 PM
Curious question?
by Bill_W - 09/22/19 03:06 PM
Haldex, Automatic on demand clutch fluid?
by sloinker - 09/22/19 03:02 PM
Winter tires for BMW X5
by iExcel - 09/22/19 02:42 PM
CONVENTIONAL FOR 2010 NISSAN MURANO
by nealberke - 09/22/19 01:44 PM
49er Steeler Tickets today!
by JeffKeryk - 09/22/19 01:20 PM
E15 usage?
by Dorian - 09/22/19 12:56 PM
Shell rotella gas truck $10 rebate 5qts
by shooter667 - 09/22/19 12:36 PM
dburch, Hueiyeh, Texguy, jm1, Dunkaroo
69364 Registered Users
93 registered members (72te27, 2strokeNorthstar, AandPDan, 10WSmuckers, ACC, 13 invisible), 1,907 guests, and 27 spiders.
Topics294,927
Posts5,069,412
Members69,364
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Be careful of those coated rotors! #4976058 01/11/19 01:12 PM
dan_erickson Offline OP
I did a quick simple brake job on my Accord during the week and bought new rotors from Autozone. I bought the 3 year warranty rotors that are fully coated with a black paint even on the rotor to pad surface.
Obviously the idea is that the pad will wear off the paint where it makes contact and the edges will be left with black paint and prevent it from rust. Long story short the paint got embedded into the brake pads and was causing the pad to skip across the rotor while braking. The knocking noise was awful sounding.
I took the pads off the car and sanded them with some 80 grit paper to remove the embedded paint and all is good now
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976070 01/11/19 01:24 PM
K
KGMtech Online Happy
Online Happy
K
Not exactly a nice experience after all that work!
I would suggest you contact Autozone to give them feedback - if they don't hear your comments they will assume all is fine.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976073 01/11/19 01:27 PM
demarpaint Offline
I didn't think coating the braking surface with paint is a good idea. It seems to me a cost cutting compromise to finishing off coated rotors, they save a few pennies not masking off the braking surface prior to painting them.
God Bless Our Troops
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976081 01/11/19 01:33 PM
K
Kestas Online Content
Global Moderator
Online Content
Global Moderator
K
Definitely give feedback to Autozone. The manufacturer needs to know this problem.
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976098 01/11/19 01:46 PM
A
anndel Offline
A
I have EBC rotors and they came with a black paint coating. After the brake job, I drove around the block to test the system and all the paint came off. I took the caliper off again to see and none of the pads were coated/clogged with the paint.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil XL 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976115 01/11/19 02:09 PM
Cujet Offline
Wow, removing that paint is adding to your workload. Ugh.
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976131 01/11/19 02:20 PM
K
Kibitoshin Offline
K
Don't know what type of coating AZ rotors use but I've never had any issues with NAPA's fully coated rotors.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976140 01/11/19 02:27 PM
N
nthach Offline
N
It seems like Bosch/ATE/Zimmermann, BPI(Napa/Raybestos) and EBC use a different coating like Geomet or a proprietary Al/Zn coating or an electrophoretic coating that won't interfere with the pads. Whoever supplied AutoZone probably used standard paint or a cheaper coating.
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976233 01/11/19 03:45 PM
F
FlyNavyP3 Offline
F
Most of the coated rotors I've ever used were Zinc/Aluminum coated and had no issues, the ones that were painted weren't painted on the pad/rotor interface.
Luke
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976252 01/11/19 04:09 PM
SnowDrifter Offline
Pop the pads off, lightly sand them, reinstall, then to some hard stops.
I always use coated rotors and the only time I've had an issue is if I don't properly burnish the pads. I do back to back hard, but not locking the wheels up 50-10mph stops until I get brake fade, then drive the thing for 4-5 miles to let everything cool, avoiding stops longer than a few seconds
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Be careful of those coated rotors! [Re: SnowDrifter] #4976395 01/11/19 07:15 PM
cpayne5 Offline
Yep, this is how to do it. Take your kids with you, they love it. At least mine do. smile
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976486 01/11/19 08:51 PM
H
HangFire Offline
H
I am guessing these would be the Duralast Gold? https://www.autozone.com/brakes-and...ast-gold-brake-rotor/818588_195255_2708#
That would be "Z-Clad"
https://www.autozone.com/landing/page.jsp?name=duralast-gold-rotors
https://youtu.be/9s_elN7lR84?t=76
According to the video and the text, it's just supposed to wear off.
I'm trying to figure out how a coating on a pad makes a "knocking noise".
Various musings: http://hangfire.net
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976516 01/11/19 09:24 PM
V
vavavroom Offline
V
A painted coating sounds like a really bad idea for a brake component that can reach over 400°F while also undergoing constant heat cycling. Look for plated coatings.
Re: Be careful of those coated rotors! [Re: dan_erickson] #4976543 01/11/19 10:03 PM
E
edyvw Offline
E
Just put these, coating was gone after three light braking.
[Linked Image]
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Be careful of those coated rotors! [Re: HangFire] #4976583 01/11/19 11:01 PM
The paint was heated and embedded into the pads. The next time I drove the car the pads were grabbing and then skipping across the rotor surface. It’s the best way I can explain it. When I took the pad off to clean them the pad surface looked like a mirror.
Page 1 of 3 1 2 3
