"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
60 registered members (53' Stude, aquartlow, 2009Edge, 4WD, 97K15004WD, 67baccaruda, 10 invisible), 924 guests, and 63 spiders.
Topics286,321
Posts4,906,409
Members67,599
Most Online2,967
Mar 10th, 2019
Oops! I put limited slip additive in transfercase #4975905
01/11/19 11:08 AM
01/11/19 11:08 AM
Cape Cod
Max_Pressure Offline OP
Cape Cod
HI!
I'm looking for some advice - I have a 2003 Dodge Ram 1500 4x4 4.7 Auto. I mistakenly added about 4oz of limited slip additive when doing a fluid change to the transfercase (I was doing both diff's as well but just screwed up where that stuff was supposed to go). Dodge calls for just straight ATF +4 in there. Should I be concerned? Should I get it outta there? I'm in the Northeast where it's cold (25 F today) so the fluid will definitely be thicker than what it would be normally be.
Advice? Thoughts?
Thanks for any feedback!
Max
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4975933
01/11/19 11:38 AM
01/11/19 11:38 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
wont hurt anything I'd leave it alone.
Transfer case has nothing that uses "friction" in it.. and fluid thickness doesnt matter much.
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4975963
01/11/19 12:01 PM
01/11/19 12:01 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I would think it would do nothing bad unless it was an auto 4x4 transfer case like the GM MP auto line that use clutches to engage part time four wheel drive.
If you want the job done right......do it yourself.
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4975996
01/11/19 12:26 PM
01/11/19 12:26 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
If it's just a basic chain driven part time transfer case, it won't care what's in it as long as it's not too heavy or gear oil.
A Np 231/241/271 won't care; any light oil that isn't gear oil will work.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4975997
01/11/19 12:27 PM
01/11/19 12:27 PM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
From what I am aware of, the LSD additive should not hurt the transfer case.
I have used gear oils with the LSD additive already in them, in transfer cases and differentials that didn't require the LSD additive.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4976026
01/11/19 12:46 PM
01/11/19 12:46 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
Should be fine, leave it in and run it until the next change.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4976254
01/11/19 04:11 PM
01/11/19 04:11 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Should be fine. That being said: It's what... 2 quarts in your tcase? Inexpensive to drain and fill again if it helps put your mind at ease
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4976255
01/11/19 04:11 PM
01/11/19 04:11 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
As stated, only if you have an "auto 4wd" setting that uses friction clutches will there be a problem. Normal 2wd, 4hi and 4lo cases don't have any issue with LSD additive.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4976404
01/11/19 07:24 PM
01/11/19 07:24 PM
Cape Cod
Cape Cod
Wow - GREAT feedback! Thank you all so much for the quick and helpful responses, it's very much appreciated! Yea, it's typical 2 hi, 4 hi, 4 low ...
@Snowdrifter - yea, it's a good point, it wouldn't take much to just change it again and I might but I didn't know how urgent I should make it.
Thanks again everyone!
Last edited by Max_Pressure; 01/11/19 07:25 PM. Reason: (2 low should have read 4 low)
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4976604
01/11/19 11:29 PM
01/11/19 11:29 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I would change it as soon as feasible. The specific chemistry in a LSD additive is NOT compatible in any way with an ATF.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Oops! I put limited slip additive in transfercase [Re: MolaKule] #4976773
01/12/19 08:57 AM
01/12/19 08:57 AM
Cape Cod
Cape Cod
Yeah that's what I was kinda worried about but I don't really understand it at all. I mean they're all oil based lubricants right? How can they not work (blend) together?
Other than different qualities or characteristics (viscosity, ideal performance temp, heat dissipation) don't they all do the same thing??
Thanks Mola!
Re: Oops! I put limited slip additive in transfercase [Re: Max_Pressure] #4977055
01/12/19 02:18 PM
01/12/19 02:18 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Thanks Mola!
They do NOT all do the same thing.
It is not the blending as most oils will mix with each other and not all lubricants are the same. Just because one oil will mix with another doesn't say anything about actual compatibility and how it will affect the machinery.
ATF's and GL-5 gear oils are both lubricating fluids and will readily mix, but you would not logically want to mix ATF with GL-5 gear lube and put that mix in your differential. Viscosity and additive differences are just two of the issues.
Not all lubricants have the same additive chemistry which is why we use specific additive packages for specific applications in finished products.
Likewise, LSD additive, while it will mix with the ATF, is not suitable in a mechanical component speced for ATF because it will affect the total chemistry of the resulting mix, and not in a good way.
