Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
74 registered members (Alfred_B, avi1777, 2004tdigls, 1foxracing, 2009Edge, 2015_PSD, 5 invisible), 1,417 guests, and 61 spiders.
Topics286,108
Posts4,902,738
Members67,563
Most Online2,967
Mar 10th, 2019
m1 0w40 wet clutch? #4964212
12/29/18 11:20 AM
12/29/18 11:20 AM
Ice Box of the Nation
Doublehaul Offline OP
Hey Guys,
Also curious as to this one...no JASO cert...but is it ok in a shared gear box as well?
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4964216
12/29/18 11:26 AM
12/29/18 11:26 AM
European Union
Atesz792 Offline
Atesz792  Offline
European Union
I'd take a wild guess here and warn you that it might shear down a grade or two in the blink of an eye when used in a shared sump.
2004 Suzuki GS500F
2006 Renault Megane 1.5 dci
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4964274
12/29/18 12:44 PM
12/29/18 12:44 PM
pa
benjy Offline
benjy  Offline
pa
more info helps, what + where will it be used
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4964311
12/29/18 01:46 PM
12/29/18 01:46 PM
Maryland USA
rubberchicken Offline
Maryland USA
What motorcycle would you put this in ? Unless it called for a 0w-X in the manual, I think I would not recommend it. I can see possibly a ATV or snowmobile might recommend it for cold temps though.
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4964887
12/30/18 12:28 AM
12/30/18 12:28 AM
Sorry guys...this would be for a Honda Rancher 350. Calls for a 40wt...had some lying around
Mobil 1 0w40
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4965056
12/30/18 09:38 AM
12/30/18 09:38 AM
South Carolina
ka9mnx Offline
ka9mnx  Offline
South Carolina
I don't know about the 0w-40 but M1 HM 10w-30 works great in my Kawasaki UTV. HTHS >3.5 of the 0w-40 I would think would be fine.
2005 Ranger 3.0 - M1 HM 5w-30/Motorcraft - (85+K)
2000 4Runner 3.4 - M1 HM 10w-30/Toyota - (250+K)
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar - (175+K)
1993 F150 4.9 - M1 HM 10w-30/Motorcraft - (250+K)
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4969124
01/03/19 08:11 PM
01/03/19 08:11 PM
Wisconsin
Mr_Joe Offline
Mr_Joe  Offline
Wisconsin
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4975154
01/10/19 01:56 PM
01/10/19 01:56 PM
Michigan
Diesel12 Offline
Diesel12  Offline
Michigan
I know Rotella T6 5w-40 is Wet clutch approved and available almost everyehere.
1998 Dodge Neon-Rebuilt 2.4L-Schaeffer 5w40
2014 Dodge Durango 3.6, 63K- Schaeffer 5w-20
2002 Ram 2500 Cummins 125K- Schaeffer 5w-40
2008 Dodge Avenger 226K Schaeffer 5w-20
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4975889
01/11/19 10:55 AM
01/11/19 10:55 AM
USA-Michigan
Mike_dup1 Offline
Mike_dup1  Offline
USA-Michigan
0W is just the cold weather rating of the oil, 0w-40, 10W-40 are both 40 wts at operating temp so a 0W will not cause one bit of problems except maybe start easier. Honda ATV's have wet clutch so its must carry the JASO MA spec.
2017 GMC Sierra Denali Ultimate CC 6.2L 4WD
2018 John Deere X738
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4980594
01/16/19 12:06 AM
01/16/19 12:06 AM
Rocky Mountain West
smokingun45 Offline
smokingun45  Offline
Rocky Mountain West
I wouldn't use it if it has an internal "wet" clutch. Use a good 5W-40 or 15W-40 diesel oil. Shell Rotella oil in these grades meets the JASO MA wet clutch specs. I have used them for years in several ATV/UTV's with excellent results. I prefer the 15W-40 unless I'm running it in the Winter when 5W-40 makes it easier to start.
Re: m1 0w40 wet clutch? [Re: Doublehaul] #4988563
01/23/19 02:11 PM
01/23/19 02:11 PM
Central Texas
Brian553 Offline
Brian553  Offline
Central Texas
I wouldn't use it. There is nothing demanding Mobil to build it to resist heavy shearing, and there is great potential for it to shear a lot very quickly (<1000mi). Suggested heirarchy:
1. ATV/Motorcycle Oil
2. Allison TES-439 spec'd HDEO oil (15w40)
3. Monograde HD oils
4. CK4 HDEO (15w40)
maybe try looking for Delo XLE 15w40 next?
Re: m1 0w40 wet clutch? [Re: Doublehaul] #5019646
02/22/19 12:37 AM
02/22/19 12:37 AM
MT
jongies3 Offline
jongies3  Offline
MT
Just use M1 Racing 4t 10W-40 and don't worry about it, a motorcycle oil designed for wet clutch use. I've had good luck with it in my 400EX. I'd never use a car oil in a wet clutch, if it's not JASO certified, don't even try!
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30, Napa Gold 1515 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: m1 0w40 wet clutch? [Re: Doublehaul] #5019647
02/22/19 12:43 AM
02/22/19 12:43 AM
MT
jongies3 Offline
jongies3  Offline
MT
Not to mention, M1 Racing 4t 10W-40 is formulated with extra shear resistant additives in mind for this purpose. It's a very stout motorcycle oil and the best I've tried so far. I'd imagine as stated above, a 0W-40 would shear out of grade real fast in a shared sump application as these are extremely hard on oil.
