Originally Posted by gman2304
Originally Posted by BigCahuna
Which recommendation are you guys referring to?. The one that says to use diesel oil if Harley oil isn't available, or the one that says to change it out as soon as possible and use Harley's oil?. It says both in the manual.,,,
BC, glad you brought this up. The only oil other than Harley branded oil recommended by Harley is a HDEO and then only for top offs. My Harley manuals state to change the oil back to genuine Harley oil ASAP after topping off with the HDEO oil. Nowhere that I can find does Harley recommend any oil, and in Harley's recommended viscosities, other than Harley's branded oil except for top offs. An HDEO will most likely be OK but personally, I wouldn't use it.
Ha ha, This is why they sell so much Harley oil. I personally have never run the stuff.
. The only Harley oil I use is the Formula+ in the primary. Some people imply that Harley recommends using HDEO when Harley's oil isn't available which isn't correct. Harley recommends HDEO oil " only for top offs ", and then to change the oil when Harley oil is available. Yes, Harley wants their customers to buy their oil.
Directly from the owner's manual: "If HD 360 is not available, add oil certified for diesel engines, Acceptable designations include CH-4, CI-4, and CJ-4. Preferred viscosities, in descending order are: 20W50, 15W40, and 10W40.
The highest mileage Harley I saw got nothing but 15W40 diesel oil since 10,000 miles!
