Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
Oil sampling tube
by kevmor99. 01/22/19 10:00 AM
Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
119 registered members (28oz, 4x4le, 53' Stude, 2004tdigls, 13 invisible), 2,330 guests, and 30 spiders.
Topics296,983
Posts4,962,937
Members67,013
Most Online2,821
Jan 21st, 2019
Possibly the ultimate Harley oil? #4975827
01/11/19 08:13 AM
01/11/19 08:13 AM
Montana
Reltor Online content OP
Reltor  Online Content OP
Montana
This is made by Lucas in a conventional and Semi-Synthetic from what I have seen. It is pricy but the ZDDP levels are super high. I may try it in the spring. My bike is older...no cats.
https://lucasoil.com/products/marin...xtreme-duty-marine-sae-20w-50-engine-oil
The conventional is around $10/qt and the semi-syn around $17/qt
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4975835
01/11/19 08:30 AM
01/11/19 08:30 AM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Harleys don't need a ton of ZDDP. They have roller bearings everywhere. And roller lifters. And stock Harley engines are far from "high performance". I ran Redline 20w60 for many years in both my Big Twin Harleys. Had 80,000 miles on the Black one when it was totaled.
99 Jeep WJ 4.7 195,000 Maxlife 10w30, Fram Ultra.
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4975857
01/11/19 09:03 AM
01/11/19 09:03 AM
Michigan
Diesel12 Offline
Diesel12  Offline
Michigan
Not a bad looking oil except take a look at the CCS Viscosity at -15C its 9500cp. i bet that oil has a crappy pour point thats why they dont post it.
Compare it to Schaeffer 20w-50 V-twin which the same test at the same temp resulted in 3500cp. Also has a stable pour point of -41F.
Here is the data sheet for Schaeffer V-twin 20w50 https://www.schaefferoil.com/documents/229-707-td.pdf
1998 Dodge Neon-Rebuilt 2.4L-Schaeffer 5w40
2014 Dodge Durango 3.6, 56K- Schaeffer 5w-20
2002 Ram 2500 Cummins 125K- Schaeffer 5w-40
2008 Dodge Avenger 220K Schaeffer 5w-20
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976225
01/11/19 02:36 PM
01/11/19 02:36 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Mystik 15W-50 is what i get locally (and VERY inexpensively) and the it has been giving OUTSTANDING used oil analyses on here
[Linked Image]
Re: Possibly the ultimate Harley oil? [Re: Diesel12] #4976273
01/11/19 03:32 PM
01/11/19 03:32 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
And tell me again why you care about low temperature performance in this application????
I think what you have stated here may be both true and irrelevant.
2001 Mitsubishi Galant 2.4 - 160k+
Grandma's creampuff...
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976318
01/11/19 04:43 PM
01/11/19 04:43 PM
New England
Jarlaxle Offline
Jarlaxle  Offline
New England
Maybe because some people do actually ride in cooler weather? Especially in Michigan.
1979 Coupe de Ville, 542 stroker, winter storage frown
2011 Crown Vic P71, 5W-20 Super Tech, Super Tech
2011 Sportster 883, winter storage frown
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976415
01/11/19 06:30 PM
01/11/19 06:30 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Would not anything with more than 1200 ppm ZDDP cause impurities /sludge in the engine?
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Possibly the ultimate Harley oil? [Re: Jarlaxle] #4976505
01/11/19 08:12 PM
01/11/19 08:12 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
Call me back when you're riding at below 0°C.
Otherwise...
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976700
01/12/19 05:46 AM
01/12/19 05:46 AM
New England
Jarlaxle Offline
Jarlaxle  Offline
New England
My coldest was 3 C a couple years ago...bike was fine. (Oil was 10W-40.) I suspect my current bike (with conventional 20W-50) might not be.
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4976985
01/12/19 12:08 PM
01/12/19 12:08 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That's a high performance Marine oil. It's made more like an SAE 50 for shear resistance. They don't care about cold weather operation, because a high performance boat is not going to be subjected to that.
Pour point depressants are usually left on the shelf.
Re: Possibly the ultimate Harley oil? [Re: Reltor] #4980719
01/16/19 05:52 AM
01/16/19 05:52 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Hard to comment on the OP as there is no mention of what year and model his Harley is.
Being there are so many, for me, I try to stick to the recommended type of oil.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Possibly the ultimate Harley oil? [Re: alarmguy] #4987655
01/22/19 02:18 PM
01/22/19 02:18 PM
Montana
Montana
2002 Dyna Wide Glide 88cu - Carbureted, Cams, upgraded oil pump etc. Have always Run 20w-50, lately Lucas Synthetic 20-50W for motorcycles.
Not sure about the high ZDDP levels causing any sludge
I do ride when it's pretty cool, but if its near freezing I usually leave a warm garage and hope to return to it within the day 90% + of my riding is 50 degrees and up.
I think I am going to try it in the engine and primary, if my local auto parts can get some from the distributor.
