The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
25 registered members (c502cid, dishdude, carlprop, csandste, Blkstanger, 3 invisible), 740 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
2014 Silverado 5.3, Magnatec 5w20, 7774.7mi #4975825
01/11/19 09:11 AM
01/11/19 09:11 AM
NC
lawrencerd Offline OP
NC
Code
Fluid Manufacture	Castrol
Fluid Category	GTX Magnatec
Fluid Grade	5W20
Time on Unit	71952
Compartment Age	71952
Time on Fluid	7774
Metals (ppm)
Aluminium (Al)	6
Nickel (Ni)	1
Chromium (Cr)	2
Iron (Fe)	47
Copper (Cu)	33
Lead (Pb)	<1
Tin (Sn)	<1
Titanium (Ti)	<1
Vanadium (V)	<1
Silver (Ag)	<1
Additives (ppm)
Potassium (K)	5
Molybdenum (Mo)	13
Boron (B)	18
Magnesium (Mg)	95
Calcium (Ca)	1790
Zinc (Zn)	702
Phosphorus (P)	575
Barium (Ba)	<1
Contaminants (ppm)
Silicon (Si)	19
Sodium (Na)	7
Contaminants
Water (%)	<0.05
Coolant	No
Physical Tests
Viscosity (cSt 100C)	8.8
Physical / Chemical
Base Number (mgKOH/g)	2.2
This sample saw frequent towing, average mpg for the interval was 12.9. olm was at 1%. The filter used was a fram TG10575.
Comments from the lab: "Engine wear levels appear satisfactory for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Viscosity within specified operating range. Action: As oil and filter(s) already changed, resample next service interval to monitor and establish wear trend."
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #4975897
01/11/19 11:02 AM
01/11/19 11:02 AM
Nebraska
Mathew_Boss Offline
Mathew_Boss  Offline
Nebraska
I'm not familiar with that engine and you dont have universal averages or what the average miles are but the Iron and Copper look outrageously high to me.
125k Mile 11 Dodge Durango 5.7L Hemi PP HM or QSUD 5w20 or 0w20 w/Purolator Boss or Wix XP
40k Mile 2015 Dodge Charger 3.6L Pentastar Pennzoil Platinum or QSUD 0/5W20, or 5W30
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #4975944
01/11/19 11:47 AM
01/11/19 11:47 AM
Lafayette, Louisiana
Samrsnow Offline
Samrsnow  Offline
Is this a 0w20 specified truck? I'd think a 5w30 would be more appropriate for towing. Seems like a lot of iron/copper. I suppose the numbers are within universal average.
1987 BMW e28 535is - mystery mileage (300,000+) Valvoline Maxlife 15W40 - Mahle filter.
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #4975980
01/11/19 12:14 PM
01/11/19 12:14 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
It is a Chevy V8, that explains the iron-wonder where the copper is coming from-does a 5.3 have an oil cooler?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #4976545
01/11/19 10:05 PM
01/11/19 10:05 PM
NC
NC
Yeah, it's a 0w-20 specced truck with zero ambiguity about it. We might compare a run or two of magnatec 5w-30 and see how it likes it, but stuck with 20wt so far. This engine has a variable displacement oil pump and cylinder deactivation, but member gonefishing seems to have tried 5w-30 at some point with no apparent issues. I believe the truck is equipped with an oil cooler.
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #5012837
02/16/19 06:19 AM
02/16/19 06:19 AM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
0-20 Should be in this truck, Also Copper levels are normal for L83 sbc, Iron is about on par also maybe slightly high but well okay. Run Wix XP or Fram ultra and use 0-20 like dexos approved oil and see how next analysis is at 7k.
(I know these numbers are about on par cause my last truck was L83 5.3 also)
16 Silverado 2500 LML 20k Miles
Rotella 5w-40 T6
ST 75w-90 GL5 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant, K&N Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #5013640
02/17/19 02:30 AM
02/17/19 02:30 AM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
There is nothing abnormal about this sample. Thanks for posting.
don't use.
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: dave1251] #5013985
02/17/19 01:13 PM
02/17/19 01:13 PM
New Mexico, USA
jimbrewer Offline
jimbrewer  Offline
New Mexico, USA
So what’s a bad iron number on a 7,700 mile run?
2ppm per thousand miles is more typical. Is this the kind of bump we should expect from towing?
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: jimbrewer] #5016747
02/19/19 06:07 PM
02/19/19 06:07 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
No, it's the kind of bump you should expect from a GM V8.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: Brons2] #5017144
02/20/19 12:21 AM
02/20/19 12:21 AM
New Mexico, USA
jimbrewer Offline
jimbrewer  Offline
New Mexico, USA
Well, if it were me, I’d change a losing game.
I’d at least change brands. If that didn’t help I would move up to slightly heavier oil.
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: lawrencerd] #5049937
03/21/19 01:48 PM
03/21/19 01:48 PM
Pittsburgh PA
battleman13 Offline
battleman13  Offline
Pittsburgh PA
I've always heard Fram filters were garbage, I use Napa Gold (Wix) or purolator. I've almost never heard of anyone actually like and recommend a fram oil filter.
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: battleman13] #5050167
03/21/19 05:22 PM
03/21/19 05:22 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
(Welcome to Bitog). Keep reading BITOG threads here battleman. Then you will slowly change your mind.
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: bullwinkle] #5050346
03/21/19 08:36 PM
03/21/19 08:36 PM
Texas
4WD Offline
4WD  Offline
Texas
They have coolers and cast iron sleeves …
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: battleman13] #5052149
03/23/19 07:47 PM
03/23/19 07:47 PM
Rapid City, South Dakota
littlehulkster Offline
Fram's quality is variable. The cheap orange cans are a bottom tier filter, but the Ultra (gold can) is a top tier filter, as good as anything made and not too expensive, either. The Fram Ultras are a favorite around these parts.
2015 Mazda3 I 2.0
Re: 2014 Silverado 5.3, Magnatec 5w20, 7774.7mi [Re: battleman13] #5052168
03/23/19 08:24 PM
03/23/19 08:24 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Huh, I wonder where you got that.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
