The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
26 registered members (dishdude, 928, Blkstanger, Brad_C, carlprop, 1 invisible), 688 guests, and 60 spiders.
Topics286,320
Posts4,906,413
Members67,597
Most Online2,967
Mar 10th, 2019
Need advice rear diff service on my Silverado #4975725
01/11/19 03:41 AM
01/11/19 03:41 AM
OKLAHOMA
GMguy84 Online content OP
GMguy84  Online Content OP
OKLAHOMA
2005 Silverado Z71
280K miles
RPO GU6 3:42 with G80 limted slip rear diff
Just use it as a basic work truck no hauling. Have no clue on previous maintenance so wanted to get this done
What you guys recommend ?? Book calls for 75W-90, But I have some supertech 80W-90 left at my shop.
So would the 80-90 work okay or go with the 75-90 ??
Dave
05 Silverado Z71 5.3 Mobil 1 EP 10W30/FUG XG3675
01 Suburban 5.3 Mobil 1 AP 5W30/FUG XG3675
1982 TRANS AM (KITT) Mobil S5K 10W40/M1-302A
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975729
01/11/19 03:51 AM
01/11/19 03:51 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I would say YES, others may not.
As long as the Super Tech has the LSD additive or you add your own, I think you'll be fine.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975744
01/11/19 05:52 AM
01/11/19 05:52 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
The additive isn't necessary with the G80. GM actually advises against it.
Either or should be fine, but I'd use what it called for personally. $5 a quart at WM for full syn ST 75w90.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975758
01/11/19 07:02 AM
01/11/19 07:02 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I am with the others. You will be fine with what you have on hand, 80W90. But given you will only use a couple of quarts, I would but what is spec'ed for the diff.
2015 Ford F250 w/Powerstroke
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975769
01/11/19 07:21 AM
01/11/19 07:21 AM
Milton, FL
jhs914 Offline
jhs914  Offline
Milton, FL
Use what you have. That 280,000 mile differential won't know the difference.
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975777
01/11/19 07:39 AM
01/11/19 07:39 AM
Ontario Canada
caprice_2nv Offline
caprice_2nv  Offline
Ontario Canada
I would use the best stuff possible since the rear end is one of the weak points in these trucks. They aren't bad, but I've seen a few of them fail at higher mileage.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975798
01/11/19 08:27 AM
01/11/19 08:27 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Originally Posted by GMguy84
2005 Silverado Z71
280K miles
Dave
Your owners manual calls for synthetic in the rear diff and conventional in the front diff. Is the Supertech 80w-90 Synthetic?
I believe the G-80 is a locking differential, not a limited slip differential and does not require the friction modifier.
Also your owners manual says, if it is a Quadrasteer, do not add friction modifier.
If you want the job done right......do it yourself.
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975800
01/11/19 08:31 AM
01/11/19 08:31 AM
USA-Michigan
Mike_dup1 Offline
Mike_dup1  Offline
USA-Michigan
GM trucks DO NOT use a limited Slip Differential (except in the Quadrasteer models - Dana). Its use a Eaton G80 Locking Differential. Additives are not required!!
Quote
¨ Optional Equipment (G80 Order Code) on all GM two-wheel and four-wheel drive light trucks and sport utilities.
Benefits
¨ Improved traction differentiates the vehicle relative to other rear wheel and four-wheel drive vehicles on the market.
¨ Maintenance free; requires no lube additives.
¨ Enhanced towing and off-road performance.
¨ Patented carbon friction disc technology enhances performance and durability while reducing warranty claims.
Principles of Operation
¨ Wheel speed difference (left to right) in excess of 100 RPM will cause a flyweight mechanism to open and catch a latching bracket.
¨ The stopped flyweight will trigger a self-energizing clutch system, which results in the cam plate ramping against a side gear.
¨ Ramping increases until both axles turn at the same speed (full lock), which prevents further wheel slip.
¨ At speeds above 20MPH, the latching bracket swings away from the governor and prevents lockup from occurring.
Technical Specifications
¨ Automatic locking takes place within a fraction of a second, so smoothly that it is unnoticed by the average driver.
¨ Unlocking occurs automatically, once the need for improved traction is gone, and is unnoticeable to the average driver.
¨ Compatible with anti-lock brake systems
2017 GMC Sierra Denali Ultimate CC 6.2L 4WD
2018 John Deere X738
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Re: Need advice rear diff service on my Silverado [Re: Mike_dup1] #4975848
01/11/19 09:48 AM
01/11/19 09:48 AM
Texas
4WD Offline
4WD  Offline
Texas
Delvac 1 is what I use in AAM’s rears with G80’s … paid $32/gallon for what’s going in the Z71 …
Re: Need advice rear diff service on my Silverado [Re: dlundblad] #4975952
01/11/19 11:54 AM
01/11/19 11:54 AM
OKLAHOMA
OKLAHOMA
Yes, ST WM 75-90 is Full Syn and $5.86+tax down here. But have a Atwoods farm in town with top tier fluids CHEAP , gonna check out today before I pull trigger
DAve
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4975993
01/11/19 12:23 PM
01/11/19 12:23 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
You live in Oklahoma . Might go a little thicker ? Best I can tell , it gets about as hot in Oklahoma as it does in our part of Texas .
Does the diff have any clunking or whine ?
How are the wheel and pinion seals ?
Might consider throwing on a diff cover with a drain or fill plug ?
Wyr
God bless
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4976016
01/11/19 12:39 PM
01/11/19 12:39 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
80w90 will be fine. Your truck should have the re-usable gasket so it will be easy to change, as long as you can get the fill plug out. Although it should have an iron center section, so the plug should not corrode itself in there.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4976509
01/11/19 09:15 PM
01/11/19 09:15 PM
OKLAHOMA
OKLAHOMA
Thanks guys for all your advice, I went ahead and got 3 qts of 75W-90 full syn at Walmart came out to around $20 after tax
75W-90 is easy to find around here, Everywhere else it was 80W-90 or higher
Shouldnt matter that much anyways, In a few months around spring/tax time I plan to sell it since i'm moving back home to Chicago and would need something else drive around there lol
But I like to get TOP dollar on my vehicles at sale time so I prefer to do any basic maintenance and document it to attract more buyers
Dave
Re: Need advice rear diff service on my Silverado [Re: GMguy84] #4976910
01/12/19 11:39 AM
01/12/19 11:39 AM
Snagglefoot Offline
Snagglefoot  Offline
Da Bears! laugh
