Maxlife v dex/merc
by HyundaiAbuser - 09/22/19 09:24 PM
15,119 Mile Supertech UOA
by Stumpy - 09/22/19 08:54 PM
Rust-Oleum Factor 4
by CatCam2 - 09/22/19 08:20 PM
Local Walmart Magnatec Closeout- Maybe Others?
by SSerian - 09/22/19 07:32 PM
Anti theft measures for new truck
by Oldtom - 09/22/19 07:28 PM
What would you do?
by Rexinaus - 09/22/19 06:26 PM
What size wire for 5 HP motor?
by dlundblad - 09/22/19 06:12 PM
Studless V/S studded winter tires
by cecil56 - 09/22/19 06:10 PM
200K more to Go!
by Gebo - 09/22/19 06:07 PM
Toyota license plate bolts/screws
by edwardh1 - 09/22/19 05:38 PM
How Do You Clean Your Grill ?
by Warstud - 09/22/19 04:05 PM
Curious question?
by Bill_W - 09/22/19 03:06 PM
Haldex, Automatic on demand clutch fluid?
by sloinker - 09/22/19 03:02 PM
Winter tires for BMW X5
by iExcel - 09/22/19 02:42 PM
CONVENTIONAL FOR 2010 NISSAN MURANO
by nealberke - 09/22/19 01:44 PM
49er Steeler Tickets today!
by JeffKeryk - 09/22/19 01:20 PM
E15 usage?
by Dorian - 09/22/19 12:56 PM
Shell rotella gas truck $10 rebate 5qts
by shooter667 - 09/22/19 12:36 PM
dburch, Hueiyeh, Texguy, jm1, Dunkaroo
69364 Registered Users
92 registered members (72te27, 03cvpi, AdditiveOCD, 2strokeNorthstar, AandPDan, 12 invisible), 1,849 guests, and 25 spiders.
Topics294,928
Posts5,069,421
Members69,364
Most Online3,532
Jul 30th, 2019
Full time rving with my 2.7 ecoboost #4975625 01/10/19 10:37 PM
F
FLORIDA Offline OP
F
Hello again, its been awhile since I've posted anything here. I've had my 2017 2.7 f150 eco for about 15 months now and it's been great towing my 4800lb dry travel trailer so far. I spend about 8mos a year traveling for work and have recently decided to go full time and just tour around when not working. Although my truck does great towing I'm not sure about whether the half ton is really suitable for full time towing a full size trailer 15,000 miles a year with another 8 to 10k unhitched. I'm just afraid that it may get tired much quicker than a 3/4 ton drivetrain and suspension, not to mention turbos. Just thought I would put this post out there to see what comes back. My gross max is 7600lb and I will probably be close to that when I trade my trailer in for a new one, somewhere between 5500 and 6250lb. Max tow for the 2.7 is 8100 I believe and from what research ice done the only difference for max tow is having a 3.73 gear vs my 3.31. Any ford techs out there that can confirm this? I know the sticker is the sticker and I don't intend to be illegal but if I end up towing to my max I'd rather be configured closer to the max tow configuration. How much better will 3.73s tow compared to my 3.31? Mpg loss while unhooked? Sorry for this post being kind of all over the place, just trying to decide if I want to keep my truck and swap gears or trade on a older f250. Thanks.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975645 01/10/19 11:16 PM
L
Linctex Offline
L
Towing will improve, and if you don't mind going a little slower, then 4.10 gears will help with hills even more.
Gas mileage will go down 1-2 MPG when unhooked with 3.73s gears compared to 3.31
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975652 01/10/19 11:30 PM
M
MParr Offline
M
The 2.7 Ecoboost isn’t the best thing for towing. https://www.ford.com/cmslibs/conten...df/guides/18RV&TT_Ford_F150_Oct9.pdf
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975667 01/11/19 12:12 AM
M
maxdustington Offline
M
I doubt you have to worry about the engine, you will smoke a trans much sooner than the turbos towing all the time. I think I would prefer a tune over gears, less messy and less of a chance of the shop installing the gears incorrectly.
I think you're in the perfect position to mod your truck as opposed to replacing it. You're planning to approach the limits of what it can tow, and need the capabilities for peace of mind more than anything else. I would get a tune and transmission cooler, and perhaps towing focused brake pads.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975673 01/11/19 12:26 AM
T
tcp71 Online Content
Online Content
T
The 2.7 is built with a CGI block and about as close to a diesel as you can get for torque down low. Having 3.73 gearing certainly would help, but it wouldn’t be a deal breaker. Whether you have the 6R80 or 10R80 transmission (I forget for 2017) both are the same transmission as max tow trucks with the 3.5 TT. My 2016 is a max tow rated for 11700lbs and 1806 lbs of payload. I think you would be fine with the truck you have.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975688 01/11/19 12:54 AM
W
wallyuwl Offline
W
Special order a 2019 with the 3.5, max tow, and heavy duty payload package. I think payload package comes with 3.73 gears. Hard to find on a lot so ordering might be only way. Replace the rear shocks with Fox 2.0 or better. I would not be towing that heavy, that often, with the 2.7 and no max tow or payload pckg. Also get BLIS, great in general but especially for towing.
My 2018 5.0 Coyote with 3.55 gears and tow pckg would tow better than your set up, and I would not use my truck for what you do/plan to do.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975773 01/11/19 07:27 AM
DuckRyder Offline
I would not go to an older truck for towing. IMO the issue is not the 1/2 ton truck, it is that the half ton truck isn’t equipped properly for best capability. Does it alt least have the tow package and not just a hitch?
Go to Fords build and price and look at what’s in the “max tow package”, how much of that does your truck have?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975789 01/11/19 08:12 AM
Cujet Offline
Properly maintained, it should hold up well. That means using very high quality synthetic oil and changing at the severe service interval or sooner. There is no question that a smal engine working hard will place additional loads on various internal components. The key to long life has always been good maintenance and good choices. I’d not worry about your rear axle ratio too much, as your transmission will select a lower gear when necessary and that transmission is tough enough to tow in 4th, 5th or 6th. By the way that 6 speed transmission is about industructable with proper service. The higher numerical ratio rear will simply mean it spends more time it top gear (on a six speed auto) which has no benefit in my mind.
As for the higher numerical ratio axle being somehow tougher, I don’t buy that either. The pinion gear is smaller.
I have a 2018 4x4 2.7L and tow a 22 foot trailer with aircraft (helicopter landing pads) on it. About 6000 pounds, 3.55 gears. The 10 speed auto ranges between 6th and 10th gear. Rarely spending all that much time in any gear.
In the leaded fuel/air cooled aircraft engine world, oil lasts about 35 hours, at which point contaminates are sufficient to accelerate wear. The manual allows 100 hour oil changes, because it’s safe. But not ideal with regard to wear or deposits. Testing by Shell shows that the oil’s performance starts to degrade in the mid 30 hour range.
It’s easy to dismiss aircraft as being a different world, but we must remember they are highly loaded engines, with some (such as mine) rated for full HP continuously. Turbochargers glow red hot for hours on end. As I mentioned above, those who get good engine life and often go many hours past overhaul (I know of one guy who has nearly 4000 hours on both his engines) , maintain their equipment well. Those who choose 100 hour oil changes sometimes don’t even make the 2000 hour overhaul.
I’d have confidence that a good maintenance program will keep your stuff healthy.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975799 01/11/19 08:31 AM
T
thastinger Offline
T
You're only talking about 4800 Lbs, doesn't make sense to me to drop major coin on a 3/4 ton to do that with when you have a truck capable already.
I would spend some money an an upgraded transmission cooler, not sure if there are factory alternatives that will fit your truck but on my 98 F150, the 7.3 PSD tranny cooler will bolt right in, that is what I did as your transmission is what is going to take the beating. If you don't have a weight distribution hitch then get one.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975813 01/11/19 08:53 AM
M
meep Offline
M
Stick with what you have. I wouldn't even change the gearing. Taller gears generate less heat, while shorter gears give more advantage to the driveline. Do you have the 6 or or 10spd trans? Both have more than enough ratios to keep you at an optimal rpm without needing the help of shorter gearing. And, then, you have less concern about heat in the axle. Remember, the transmission is liquid cooled and probably thermostatically regulated, while the axle just hangs out in the wind. OTR drivers have told me the axle is the bigger item to watch than the trans.
Your trailer is not overly heavy for the 150. It's probably right about in the sweet spot. I've towed more with less, and owning the same truck as you I feel very comfortable towing with that vehicle. Diesel-like engine block, liquid cooled turbos, and, in my opinion, a truly excellent transmission/engine tow mode. I'm surprised by how much passing power it keeps in reserve. I can truly hold 65 if I want to on uphill grades (or more, but I have no need); it is not under powered, and due to the generous torque down low, we cruise around 2200 2400 rpm, which is very pleasant, rarely ever going over 3,000 like my last truck did all the time.
You can tell my opinion; save the money. Go aggressive on axle, trans, and tcase fluid changes and enjoy the truck.
-m
2018 F150
2015 crv (wifey!)
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975834 01/11/19 09:29 AM
Snagglefoot Offline
When you consider what went into optimizing a twin turbo to work with a 10 speed automatic transmission and then do something old school like swapping a rear gear, I think you’re asking for headaches. Sure,some folks might do it but does it really work as well afterward? This ain’t no 350 Chev with a TH400.
Run what you have. laugh
If you want the job done right......do it yourself.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975868 01/11/19 10:15 AM
DoubleWasp Offline
Rear end ratio is a lot more important than it's being made out to be. A numerically low ratio places more stress on the transmission at the limit and makes acceleration more difficult from a stop. The difference between towing with a set of 3.27-3.31 gears compared to 3.73 to 4.10 gears can be large. The loads on the engine and transmission are greater in the lower gears, where a transmission has limited options to downshift. In first, there's nowhere to go, and then it has to upshift whether or not the next gear is optimal or not. There's no getting around the fact that a numerically lower ratio is going to rely more on engine load than mechanical advantage to roll out than a higher one.
But that's not a discussion to have about 5-6k being towed by a halfton truck.
If it were me, I would just run high quality synthetic oils and a super large transmission cooler.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975879 01/11/19 10:32 AM
J
jcartwright99 Offline
J
If you don't already, use premium fuel if you can. Ford recommends in towing situations and extreme driving. Keep severe driving service schedule too.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975895 01/11/19 11:00 AM
F
FLORIDA Offline OP
F
Thanks all. I'm at work so. Can't have a lengthy response but to answer a few of the questions here, I do have a tow package good to 7600. It's the 6 speed auto. It does great with my 4800 pound trailer but I'm upgrading to a 6k pounder which is going to put my right at my max. I do already use a weight distribution setup. Thanks again.
Re: Full time rving with my 2.7 ecoboost [Re: FLORIDA] #4975932 01/11/19 11:38 AM
M
MNgopher Offline
M
Couple of comments. (Disclosure: I own a 2016 F150 with 2.7 - and love it for what I do).
If you stay where you are on the trailer, you're fine.
If you upsize to the size you are talking about (and is that dry weight?), you are going to start having issues running up against payload. Typically, that is the limitation on the 2.7 trucks and not the maximum towing weight.
On the 2.7, to get the maximum towing capability (between 8000 and 8500 depending on configuration), you would need the payload package. That brings on the 3.73 gear ratio, but also: Adds heavier rear springs, upgraded the rear axle to the 9.75 from the 8.8 (at least it did on the 2016's), goes from a electric parking brake to a mechanical one. It may also net you a heavier frame, though there is not a lot of confirmation on that. Long story short, just upgrading to a 3.73 gear ratio is not the only limiting factor to your truck.
For those who comment that the gear ratio makes a large difference, note that on these trucks you go from 76-7700 lb towing capacity to 80-8500 lbs towing capacity, plus needing the payload equipment to do it. You gain 400-800 lbs of trailer weight rating - not a lot.
Part of the difference is the transmission gear ratios are a lot different than when trucks and 3 and 4 speed transmissions. On the F150, the 4R70 had a 1st gear of 2.84:1. The 6R80 went to 4.17:1. The 10R80 is now at 4.69:1, with a whole bunch of options in between. Makes the gear ratio game on the rear end a little different.
All in all, if you stay where you are, I wouldn't worry. If you upgrade, then I'd be looking bigger - either F150 with the 3.5 or a 3/4 ton.
