Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
37 registered members (carlprop, CleverUserName, 1.8Tango, 3 invisible), 901 guests, and 29 spiders.
Topics296,864
Posts4,960,361
Members66,982
Most Online2,688
Jan 19th, 2019
Back to Basics V #4963790
12/28/18 06:48 PM
12/28/18 06:48 PM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
This problem involves a Blending Plant. The PI, base oil mix, and VII are blended together in a hot tank and then the finished product goes to the bottling machine.
The velocity (flow rate) of the oil at the bottling station is 2.38 meters/s through a circular Pipe of 26 mm Diameter.
How long (in time - seconds) does it take to fill a Quart bottle?
(1 Quart = 0.946 L) and 1 L = 1X10-3 m^3).
I.e, 1 Liter equals 10 to the minus 3 cubic meters.
Hint 1: First find the Volume flow rate (or sometimes called, The "Volumetric Flow Rate") in Liters/second, then determine how long it takes to fill the bottle.
Hint 2: for the simple equations you will need see:
https://www.khanacademy.org/science/physics/fluids/fluid-dynamics/a/what-is-volume-flow-rate or Wikipedia.
This question is open to all, but let's please allow non-engineers, non-Tribologists and non-chemists time to research the question and to respond before answering.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Back to Basics V [Re: MolaKule] #4963800
12/28/18 07:00 PM
12/28/18 07:00 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Q = A x V
Liters/sec = sq cm x cm/s
so rearranging:
sec = (sq cm x cm/s) / liters
= 946 cm^3 / ([2.6^2 x .7854] cm ^2 x 238 cm/s)
= .749 sec to fill the quart bottle.
Volumetric flow rate is 1.263 liter/sec
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Back to Basics V [Re: MolaKule] #4964281
12/29/18 11:54 AM
12/29/18 11:54 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
Would any non-engineers, non-Tribologists or non-chemists like to respond with their calculations and numbers?
Quote
Re: Back to Basics V [Re: MolaKule] #4966366
12/31/18 05:46 PM
12/31/18 05:46 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Oops. Sorry I drained the fun out of this one.
Re: Back to Basics V [Re: MolaKule] #4975510
01/10/19 07:30 PM
01/10/19 07:30 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
This one should exclude mathematicians and physicists, too, Mola. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Back to Basics V [Re: MolaKule] #4977568
01/12/19 11:28 PM
01/12/19 11:28 PM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
Mr Harmon gave the correct answer with one approach to the problem.
My step-by-step approach is somewhat different and is found in the pdf.
With hints and some good links, I was hoping for more responses but Mr. Harmon gets the virtual BITOG Mug with the thumbsup Emblem and a virtual case of XWXX Full Synthetic oil.
Either way, I hope this problem was an educational one.
