2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
67 registered members (Bailes1992, alarmguy, ArrestMeRedZ, 94astro, 97K15004WD, bachman, 6 invisible), 1,530 guests, and 37 spiders.
Topics301,899
Posts5,204,913
Members70,798
Coleman stove repair #4975323 01/10/19 04:14 PM
B
buck91 Offline OP
B
Trying to dial in this Coleman propane stove for camping and emergency use. Left burner works perfectly but the right burner seems to run very rich. No visible clogs and the burners look ok. Only thing o can notice is that the propane tubes fit over the Venturi differently. Does this look right? Or did the right burner tube somehow get displaced?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Coleman stove repair [Re: buck91] #4975346 01/10/19 04:50 PM
Q
Quest Offline
Q
Venturi (nipples) so long as it's not clogged, it will work (for propane stoves).
I'd take apart the right burner and blow it clear. spiders, etc. simply luv creeping into the air tubes and clog things up.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Coleman stove repair [Re: buck91] #4975348 01/10/19 04:56 PM
O
oldoak2000 Offline
O
Top pic looks wrong, like it's jammed on too far;
venturi fuel stream needs to blow across all of opening (hole) to gather air (oxygen) for proper mix/burn.
Re: Coleman stove repair [Re: buck91] #4975411 01/10/19 06:11 PM
B
buck91 Offline OP
B
Top pic is the left, perfectly functioning burner. Was able to reposition the right burner to match without improvement. Burners themselves have been disassembled and did not have a need for cleaning as they are clear.
2011 F150 4x4 5.0L
Re: Coleman stove repair [Re: buck91] #4975437 01/10/19 06:33 PM
Snagglefoot Online Content
Online Content
Maybe send the pic to Old Coleman Parts and see what they think. They have 44 pages of stove parts.
www.oldcolemanparts.com
I’ve ordered parts from them and they are great.
If you want the job done right......do it yourself.
Re: Coleman stove repair [Re: buck91] #4975589 01/10/19 08:53 PM
Dinoburner Offline
A couple of things you might try, re-clean the venturi with a flexible brush all the way to the burner head. Compare the orifice size and if possible remove it to see if a spider mite has taken up residence.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
