Seasoned Air Travelers - Best Luggage?
by john_pifer - 02/29/20 12:02 AM
Empty house without kid or cat
by vavavroom - 02/29/20 12:00 AM
Windshield Damage
by MolaKule - 02/28/20 10:16 PM
Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
18 registered members (Kamele0N, Char Baby, georgemiller, JMK, bachman, emod, 1 invisible), 871 guests, and 18 spiders.
Topics302,069
Posts5,208,402
Members70,826
Coleman stove repair #4975323 01/10/19 04:14 PM
B
buck91 Offline OP
B
Trying to dial in this Coleman propane stove for camping and emergency use. Left burner works perfectly but the right burner seems to run very rich. No visible clogs and the burners look ok. Only thing o can notice is that the propane tubes fit over the Venturi differently. Does this look right? Or did the right burner tube somehow get displaced?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Coleman stove repair [Re: buck91] #4975346 01/10/19 04:50 PM
Q
Quest Offline
Q
Venturi (nipples) so long as it's not clogged, it will work (for propane stoves).
I'd take apart the right burner and blow it clear. spiders, etc. simply luv creeping into the air tubes and clog things up.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Coleman stove repair [Re: buck91] #4975348 01/10/19 04:56 PM
O
oldoak2000 Offline
O
Top pic looks wrong, like it's jammed on too far;
venturi fuel stream needs to blow across all of opening (hole) to gather air (oxygen) for proper mix/burn.
Re: Coleman stove repair [Re: buck91] #4975411 01/10/19 06:11 PM
B
buck91 Offline OP
B
Top pic is the left, perfectly functioning burner. Was able to reposition the right burner to match without improvement. Burners themselves have been disassembled and did not have a need for cleaning as they are clear.
2011 F150 4x4 5.0L
Re: Coleman stove repair [Re: buck91] #4975437 01/10/19 06:33 PM
Snagglefoot Offline
Maybe send the pic to Old Coleman Parts and see what they think. They have 44 pages of stove parts.
www.oldcolemanparts.com
I’ve ordered parts from them and they are great.
If you want the job done right......do it yourself.
Re: Coleman stove repair [Re: buck91] #4975589 01/10/19 08:53 PM
Dinoburner Offline
A couple of things you might try, re-clean the venturi with a flexible brush all the way to the burner head. Compare the orifice size and if possible remove it to see if a spider mite has taken up residence.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
