Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
118 registered members (01rangerxl, 2009Edge, 2010Civic, 853okg, 2K2AcuraTL, 11 invisible), 2,298 guests, and 67 spiders.
Topics286,029
Posts4,901,100
Members67,549
Most Online2,967
Mar 10th, 2019
Page 3 of 4 1 2 3 4
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975608
01/10/19 10:14 PM
01/10/19 10:14 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
I have them on my truck and Scion, had them on my Elantra, Jeep TJ, and Grand Caravan, will be getting one for my Santa Fe.
I just find it easier when doing the oil change to not worry about what size the drain plug is. Just get the drain pan, slide it under, and open the Fumoto. Go up top, remove the fill cap, go grab the filter and oil, go under vehicle and close Fumoto, remove and replace filter, go back up top, add oil and done.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975680
01/11/19 12:37 AM
01/11/19 12:37 AM
Los Gatos, CA
JeffKeryk Online content
JeffKeryk  Online Content
Los Gatos, CA
While these drain valves are not for me, but I do have a question:
What if the thread length is somewhat longer than the female threads?
Does this limit a complete drain?
Just curious...
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975724
01/11/19 03:31 AM
01/11/19 03:31 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
JeffKeryk,
Yes, there's a video where model 106 SX is being installed on a 2015 Wrangler where the presenter discusses this.
18 KIA Sportage 2.4 AWD
PUP 5W30, OEM
QSUD 5W20, OEM (next)
13 Hyundai Santa Fe Sport 2.0T
MAGNATEC 5W30, OEM
PPEuroL 5W30, OEM (next)
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975849
01/11/19 09:52 AM
01/11/19 09:52 AM
Los Gatos, CA
Los Gatos, CA
Originally Posted by wemay
JeffKeryk,
That video landed on Youtube; I tool a look.
I guess a lotta people like these valves, but it ain't for me.
Not sure how much oil is trapped in the pan, but it certainly looks like some could be.
For me, grabbing a Snap-On wrench outta the roll away is a thing of joy.
2018 Lexus RX450h
2006 Acura TSX
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975861
01/11/19 10:08 AM
01/11/19 10:08 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I have tested mine on my Santa Fe, Journey and now the Caravan whereby I drain the oil using the valve, close the valve and then remove the valve and see what else comes out and it's only a few drips at most, not even a fine stream or dripping stream indicating there was a bit more oil to come out so it's getting everything out of mine.
You could always put a thin threaded nut onto the valve first, tighten down and then put this up against the blue sealing washer they send you with the valve and this will keep more threads on the valve out of the pan, but I haven't found this necessary to date on any of the vehicles I have had it on. Maybe it's because I change my oil using ramps on the front end and the engine is tilted or because the oil is hot when I change it I don't know...
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975892
01/11/19 10:58 AM
01/11/19 10:58 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Any steel pan that has an oil drain has a fitting that extends beyond the floor of the pan. There is definitely oil staying in there. Unbelievably, some cast pans are this way too.
I use Fumoto valves on some of my equipment. They are fantastic for windy days and such. No big mess or oil being whipped all over.
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975958
01/11/19 11:59 AM
01/11/19 11:59 AM
blupupher Offline
blupupher  Offline
I am not worried about a few ounces of oil that may be left in my pan (if any) by using the Fumoto.
More oil sitting in passageways and such within the engine than is left in the pan.
Re: Oil drain valves like Fumoto and EZ [Re: JeffKeryk] #4976656
01/12/19 02:31 AM
01/12/19 02:31 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
In my case, with the G37, my experience is the same as that of StevieC. I basically let it stop dripping, removed the Fumoto, and just got dripping again, so it's pretty insignificant. Of course, it's not necessarily that way in other applications.
Plain, simple Garak.
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4976675
01/12/19 03:27 AM
01/12/19 03:27 AM
Central Iowa
TiredTrucker Offline
Central Iowa
I have used Fumoto valves on all my vehicles and equipment for over 20 years. Jeeps, cars, pickup trucks, semi trucks, compact tractors, etc. I have never reverted back to plug. I change any vehicle over to Fumoto at the first oil change. My previous Jeep and all my pickups have had to deal with off road on my property. Ditches, hillside terraces, pushing snow, nasty rural gravel roads year round, etc. I have never had a valve leak or fail. The one on my '95 Freightliner went 1.4 million miles. A '05 International, 989,000 miles. Current 2013 Freightliner, 926,000 miles thus far. 2006 Cadillac CTS 3.6, '98 Chevy 2500 454, '13 Chevy 1500 5.3, '15 Chevy 2500 6.0, and '06 Jeep Liberty diesel. Fumoto on all of them.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4976678
01/12/19 03:43 AM
01/12/19 03:43 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Thanks for all the feedback.
PUP 5W30, OEM
MAGNATEC 5W30, OEM
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4979938
01/15/19 12:57 PM
01/15/19 12:57 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
Only issue I ran into having a valve is the few times on travel and need a shop to do my oil changes, they still spin the valve off even when I tell them not too. Then they crush the fiber gasket the valve comes with when they spin it back on.
2019 Toyota Tacoma 3.5L (MileSyn 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4979954
01/15/19 01:10 PM
01/15/19 01:10 PM
Chattanooga, TN
Spector Online content
Spector  Online Content
Chattanooga, TN
It always amazes me that when these valves come up for discussion all of the potential problems are shown and the worst case scenarios, No one ever states how many problems there have been with leaky gaskets on the plugs, or the plugs not tightened properly, or stripped threads and pans lost from hitting objects on the road.. these Fumoto valves are build really really solid, I drove over a cement barrier once and shaved the nipple off of one and it still worked for years without a leak. After 20 years of usage I swear by them. As to oil left in after a drain,, how many shops pull the plug wait until the flow slows to a trickle and put the plug back in and refill, how much is still in the pan then???? It may take a while to feel comfortable with the valve on there but they really are reliable and very nice for changing the oil.,.
Re: Oil drain valves like Fumoto and EZ [Re: Spector] #4980023
01/15/19 02:10 PM
01/15/19 02:10 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
We have 9 in the family and not one has had an issue except the 1 shortly after install. I know because I change their oil among other maintenance/repairs. Mine that leaked (dripped slightly occasionally) and they warrantied it for me and it has been fine since. Still using it currently and it has been opened and closed tons of times and see lots of road time. I completely agree.
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4980205
01/15/19 04:50 PM
01/15/19 04:50 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
I'm thinking of perhaps getting one for my minivan. Is around $25 a good price for one, or do they go on sale from time to time? I'm not in a hurry as I just did an OC on it.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Oil drain valves like Fumoto and EZ [Re: KrisZ] #4980206
01/15/19 04:53 PM
01/15/19 04:53 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
$25 is good, it's all brass with stainless ball so you are paying for the metal and the quality manufacturing so it stands the test of time IMO. They do have sales from time to time but it's not a regular occurrence. (I get their e-mails)
I have this from the Journey but it fits the Caravan too... https://www.fumotooildrainvalve.com/f106n.html
(Any Chrysler thread wise)
Page 3 of 4 1 2 3 4
