2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (1.8Tango, BobGoblin, 69GTX, AnonOIl, carlprop, Blkstanger, 3 invisible), 998 guests, and 29 spiders.
Topics296,864
Posts4,960,358
Members66,982
Most Online2,688
Jan 19th, 2019
Page 2 of 4 1 2 3 4
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975225
01/10/19 02:23 PM
01/10/19 02:23 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Been using Fumoto for over a decade on multiple vehicles in the family including my own. No downsides I can see. I get just as much oil out with the valave as with the drain plug.
I really like that you can put a tube on the end of the version I buy with the brass nipple (not the white plastic version) so that the oil doesn't splash on windy days as its draining.
'18 Dodge Grand Caravan GT - 17k KM - AMSOIL SS 0w30
'06 Hyundai Santa Fe - 535k KM (Dead) - AMSOIL SS 0w30
Re: Oil drain valves like Fumoto and EZ [Re: Kawiguy454] #4975241
01/10/19 02:38 PM
01/10/19 02:38 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Originally Posted by Kawiguy454
I like to dump the oil and have it come out as quickly as possible. Usually with the engine hot and I even open the fill cap to help. The Idea is to draw out any heavier particulates that may be on the bottom of the pan near the oil drain. Anything that slows down the flow or has threads that extend up into the pan IMO is not optimal. After I drain oil I also look at the drain pan for anything abnormal.
If the valve slows it down (if) its not by much. It will drain out quickly with Fumoto valve or just drain hole.
I doubt there is a significant amount of oil left in the oil pan after draining with a Fumoto valve.
2015 Ford F250 w/Powerstroke
Re: Oil drain valves like Fumoto and EZ [Re: redbone3] #4975281
01/10/19 03:20 PM
01/10/19 03:20 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
Originally Posted by redbone3
I prefer using an oil extractor. One extractor is good for as many vehicles as you service, you don't have to crawl under the vehicle, you don't have to worry about it leaking, you don't have to worry about stripping the threads on the oil plug.
I bought an oil extractor, only to find that I can't get the tube down into the fluid on my Subaru. Not the oil, nor the transmission fluid. I'm not sure if there's something blocking the path or if the opening is just big enough for the flat metal of the dipstick to get through. I worked and wiggled and pushed the tube for probably 5-7 minutes each to no avail. I was heartbroken to discover this after dropping $50 on the extractor.
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975329
01/10/19 04:23 PM
01/10/19 04:23 PM
PimTac Offline
PimTac  Offline
I don’t think there is a blanket yes or no answer. It depends on your vehicle. Will the valve make it easier to drain the oil?
Then there is the possible consequences of having someone else do your oil change. Will they secure the valve properly?
Cannot see signatures any longer so it doesn’t matter.
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975347
01/10/19 04:52 PM
01/10/19 04:52 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
On my truck, I have the version with the nipple. I have a 6" length of hose clamped to the nipple. The truck has an underbelly "diaper"-like skid plate with some cutouts in it. I leave the hose laying on the diaper when not in use and pull it through the cutout and directly into my oil jug (repurposed 9.8 liter plastic RV antifreeze jug). Reach up, flip the lever and drain the oil without a pan. when it's done, flip the lever closed and tuck the hose back onto the plate. the filter has a built in funnel under it and i can direct the oil from the filter directly into the same jug. Easy oil change with the fumoto and no mess.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975361
01/10/19 05:13 PM
01/10/19 05:13 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Originally Posted by wemay
The benefits are obvious, but...
What are the drawbacks to using these?
Have any of you tried it and reverted back to plug? Why?
Which are the most reliable? ( I didn't realize there were so many).
I'm interested but undecided.
Thanks in advance thumbsup
What's the big advantage you still have to crawl under the car?
2004 Corolla 128276
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975368
01/10/19 05:22 PM
01/10/19 05:22 PM
California
DGXR Offline
DGXR  Offline
California
Drawbacks:
-- potential for leakage (maybe small, but still... happens once and you are toast)
-- vulnerable to damage (not always, depends on model... happens once and you are toast)
-- spending money on a part you don't really need
With the popularity of these quick drain valves... our lives have become WAY too busy.
If 20 minutes is too long for a homemade oil change, it's probably time to loosen up the schedule a bit. Just sayin
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 2wd access cab
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975373
01/10/19 05:29 PM
01/10/19 05:29 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Is there such thing as a Fumoto valve for the atf plug? if so I could see getting one for the oil and one for the atf.
edit: found this:
https://help.fumotooildrainvalve.co...I-use-a-Fumoto-valve-on-my-transmission-
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975386
01/10/19 05:43 PM
01/10/19 05:43 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Random, but does anyone know of a Fumoto like thing where you can pick the thread pitch?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975397
01/10/19 05:55 PM
01/10/19 05:55 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I went to Fumoto's HQ at 45 E.34th St. in Manhattan. They had a wall of bins with lots of sizes.
Go to their catalog / website or call 'em (877) 350-5584
Are you looking for a size used by car/truck makers or something odd?
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975398
01/10/19 05:57 PM
01/10/19 05:57 PM
VA
Gebo Offline
Gebo  Offline
VA
I just couldn't handle it sticking down and being so exposed. I used them for a while but it does take a lot longer to drain and when I removed them a little more oil came out. Not a lot, though.
I sold all of mine here on bitog.....
'98 LEX LS400 280K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Oil drain valves like Fumoto and EZ [Re: wemay] #4975438
01/10/19 06:34 PM
01/10/19 06:34 PM
St. Louis
MONKEYMAN Online content
MONKEYMAN  Online Content
St. Louis
Used a Fumoto 10 years on a Saturn. No problem. Loved to just change oil in Winter and used a good filter for 2 OCI's.
Then came my 2017 Elantra. Was going to let dealership change oil then had 3 gallons of free PP 5w-30 to use. I figured a way to change my oil with car parked in garage. So with the EZ valve I just come home from work. Open valve under cat litter pan. Come in and pet cats. Take a cat nap. A few hours later come out and close the valve and change oil filter. If I want a look see I use a mirror. Everything is protected and more oil drained than with oil drain plug. Needed 4.2 quarts compared to the 4 quarts needed when using the drain plug.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Oil drain valves like Fumoto and EZ [Re: demarpaint] #4975455
01/10/19 06:45 PM
01/10/19 06:45 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Originally Posted by demarpaint
Fortunately I never owned a vehicle that I felt needed one.
For me, the vehicles didn't need a Fumoto at all. The real problem was the person who always makes a mess doing the oil change. That would be the guy I see every day in the mirror when shaving. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Oil drain valves like Fumoto and EZ [Re: Garak] #4975463
01/10/19 06:51 PM
01/10/19 06:51 PM
St. Louis
St. Louis
Even with a Fumoto valve I managed to make a mess. Was in a rush one day and put oil in my Saturn before I closed the valve. They are not fool proof, me being the fool.
2017 Elantra SE
Re: Oil drain valves like Fumoto and EZ [Re: MONKEYMAN] #4975573
01/10/19 08:36 PM
01/10/19 08:36 PM
Garak Offline
Garak  Offline
I'm sure I can still make a mess. I imagine I can move the oil pan somewhere foolish, fumble with the valve, and there's always my old standby of slam dunking the oil filter into the pan.
Page 2 of 4 1 2 3 4
