CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
PTL, vdubw, NJ01MGM, Antiquity, tundraotto
69034 Registered Users
22 registered members (Deontologist, carlprop, e55amgbenz007, edyvw, clinebarger, 4 invisible), 889 guests, and 20 spiders.
Topics293,664
Posts5,044,641
Members69,034
Most Online3,532
Jul 30th, 2019
Magnatec 5W-30, 6800 miles, 3.5 Ecoboost #4974561 01/09/19 08:31 PM
O
Onug Offline OP
O
First sample with Castrol Magnatec. Oil is 5W-30, full synthetic (old formula; not SN+). I’ve shifted gears from my previous testing and now plan to run the oil until my OLM gets to 20%.
Oil was run for 6,811 miles over 153 days. It ran for 251 hours, including 61 at idle (24%). OLM was at 18%. I did a few hundred miles of towing, but otherwise just the same normal commuting as my other samples. Some have claimed this oil quieted their motor down, but I didn’t notice anything different. One batch isn’t a trend, but this sample has lower wear metals than the M1 or Schaeffer’s averages of my previous testing, so I’m happy with that direction. Especially since this is the longest I’ve ever run a batch (measured in both miles and OLM remaining). The iron average of my three M1 samples (covering 15,700 miles) was 3.2ppm/1k miles, Schaeffer’s was 4.2ppm/1k miles (15,400 miles between the three samples) and this Castrol sample was 2.5ppm/1k miles.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974581 01/09/19 08:45 PM
V
Vern_in_IL Offline
V
I like the 5 quart container. The best thing about it is the handle vent that connects to the mouth. This allows little bubbles to get from the mouth to the top of the oil still in the tank. This stops the big glugs that you get with the cheaper bottles.
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974582 01/09/19 08:46 PM
L
Linctex Offline
L
I wonder where the copper is coming from?
What was the oil that you used to use - - with all the moly?
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974595 01/09/19 08:59 PM
M
MRtv Offline
M
Thanks for the share. I have 10 quarts in my stash to go into one or both of my vehicles.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Linctex] #4974636 01/09/19 09:52 PM
O
Onug Offline OP
O
No clue about the copper...
The high-moly UOAs are the three Schaeffer samples
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974649 01/09/19 10:10 PM
KJSmith Offline
I like it.
Its the only oil that says it reduces wear.... and actually does.
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974654 01/09/19 10:15 PM
B
BikeWhisperer Offline
B
Nice report, Magnatec continues to look good in these Ecoboost vehicles.
2015 F150 XLT SCrew 2.7 Eco-Boost
5w-30 Magnatec, FL2062
2018 Ford Edge SEL Eco-Boost 2.0
5w-30 Magnatec, FL-910S
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974811 01/10/19 07:05 AM
dnewton3 Offline
Global Moderator
Global Moderator
My data set has over 200 samples for the 3.5L EB engine.
They average around 3.9ppm/1k miles for the Fe.
They average around 5.0ppm/1k miles for the Cu. (where the Cu comes from I cannot say; don't know the engine well enough. perhaps a Cu based oil cooler like some GM engines?)
They average around 1.0ppm/1k miles for Al.
The other metals are generally low enough to not even consider an issue; only if you got a huge spike would it be a cause for concern.
This UOA is pretty typical for a 3.5EB; nothing but normal. Now, the "new" EB with the duel injection systems, I don't have enough data to really get details yet. Given the total miles on this unit I can presume it's one of the 1st gen motors, so my data is valid for comparison and contrast.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974822 01/10/19 07:28 AM
J
joekingcorvette Online Content
Online Content
J
I use the Magnatec in my Ford F-150 only I use 0W-20. I have a pretty good stash of it since I bought it at Walmart for $17 plus change for the five quart jugs. I have about 6 jugs left. Thanks for posting the oil analysis.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4974833 01/10/19 07:47 AM
V
Virtus_Probi Offline
V
Onug, do you know if that oil had the dexos1 Gen 2 label?
That looks like an LSPI-resistant formulation to me even if it is not SN+.
Thanks!
2014 Forester XT, 105000 miles
Last Change;
PP 5w30 d1G2
Tokyo Roki 15208AA170 filter
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: BikeWhisperer] #4974929 01/10/19 09:45 AM
SureshR Offline
It is one of the very few oils certified WSS-M2C-913C/D (along with Mobil Super 3000 X1 and Shell Helix Professional AF). Basically ACEA A5/B5 with extra ZDDP for a chain wear test.
If you want a change try any of the other A5/B5 5w30s on the market.
The Shell one (also Ford certified) is by far the best of the lot if you can get it. https://www.shell.com/motorist/oils...l-helix-ultra-professional-af-5w-30.html
2014 Ford Fiesta 1.5 TDCI (Mobil F1 5w30 A5/B5 Ford WSS-M2C-913D) | 2015 Mahindra Scorpio 2.2 mHawk (Amsoil CK4 Turbo Truck)
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4975240 01/10/19 03:37 PM
B
Brigadier Offline
B
Given the low Calcium, are you sure this wasn't the SN+/d1G2 version?
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4975648 01/10/19 11:21 PM
O
Onug Offline OP
O
Well, this stuff was for a long time semi-synthetic and then magically became full synthetic. Maybe they changed and released the formula before they got the SN+ “approval”? I’ll dig up one of the bottles tomorrow and post some pics.
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4976564 01/11/19 10:29 PM
O
Onug Offline OP
O
Here you go...
Re: Magnatec 5W-30, 6800 miles, 3.5 Ecoboost [Re: Onug] #4976599 01/11/19 11:23 PM
L
littlehulkster Offline
L
It's been a full syn in most grades for a while. IIRC the really heavy stuff is still a blend.
That said, this looks good, but does anyone know what exactly these so called intelligent molecules do? Is it just marketing hype around what seems to be a pretty good oil, or is there something to it?
2015 Mazda3 I 2.0
