NEW ROTELLA RTO-177 FILTER CUT OPEN
by 53' Stude. 07/19/19 05:37 PM
NEW PRIME GUARD POF 6128
by 53' Stude. 07/19/19 05:26 PM
Hayward Pool Filter ????
by Oldtom. 07/19/19 04:27 PM
Constant pressure well system fluctuating
by LeakySeals. 07/19/19 04:22 PM
C&P XG3387A with filter mag - 6318 miles, 6 months
by shibby6600. 07/19/19 04:19 PM
Engine oil from natural gas??
by sloinker. 07/19/19 04:11 PM
Jeep for 16 year old
by stockrex. 07/19/19 03:51 PM
Mustache no beard?
by sloinker. 07/19/19 03:50 PM
GS430 Toyota WS transmission oil
by Shaz. 07/19/19 03:35 PM
High level input question
by buck91. 07/19/19 02:47 PM
Drill press vise?
by buck91. 07/19/19 02:40 PM
More filter dissections to come ;)
by 53' Stude. 07/19/19 02:37 PM
Massive amounts of PEA got into my oil ???
by j_mac. 07/19/19 02:10 PM
Anyone have over 200K on their GDI or TGDI engine?
by Speak2Mountain. 07/19/19 12:55 PM
ATF to help with seeping output shaft seal
by spavel6. 07/19/19 12:39 PM
A/C Gas refill with stop leak/dye?
by stockrex. 07/19/19 12:26 PM
[pics] 2004 Corolla spark plug, piston tops
by zorobabel. 07/19/19 11:55 AM
Philippe1988, ChiefDaBooty, JIMBO5658, Agway, Murphhyy18
68709 Registered Users
101 registered members (53' Stude, 01rangerxl, 379KITTY, 2oldtommy, 77GrandPrix, 9 invisible), 2,178 guests, and 24 spiders.
Topics292,097
Posts5,016,821
Members68,709
Most Online2,967
Mar 10th, 2019
More mouse issues #4974273
01/09/19 02:58 PM
01/09/19 02:58 PM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
I just tweaked by garage door bottom seal to better seal the garage door. Looks like my garage floor is not perfectly flat.
Anyway mouse chewed most of the seal that I just added. But he fell hard for the peanut butter.
So I have some new garage door bottom seal on order that can seal 2" plus an air tube inside the seal fold that you cap with plugs. But would prefer not to install the new stuff and have mouse chew it up. It's $2.50/ ft.
[img]http://[/img]
2015 Ford F250 w/Powerstroke
Re: More mouse issues [Re: Donald] #4974298
01/09/19 03:21 PM
01/09/19 03:21 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Poor lil deer mouse. NOT! Never seen a plastic snap trap before. TOM Kats are Chinese , but they're still wood! grin2
Thick oil is better grin2
Re: More mouse issues [Re: Donald] #4974304
01/09/19 03:30 PM
01/09/19 03:30 PM
PimTac Offline
PimTac  Offline
Did they chew through the seal to get to the peanut butter?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: More mouse issues [Re: Donald] #4974309
01/09/19 03:34 PM
01/09/19 03:34 PM
NY
demarpaint Offline
demarpaint  Offline
NY
A little late for you but it might help someone else. I had a similar problem, not as bad, and made a mouse trap from a 5 gallon wallpaper paste bucket. It worked better than glue strips, humane traps, and snap traps, all baited with peanut butter. I took a small plastic peanut bottle and drilled a hole dead center in the top and bottom, then drilled two holes about 4" down from the rim of the bucket. I used a welding rod to suspend the bottle, and cut a slot for a ramp which was set about 2" away from the peanut bottle and above it by about an inch. Basically the mouse has to jump for it. The thing spins like it has ball bearings. I baited it with peanut butter. It will catch several mice. You can put a few inches of water in it, anti-freeze if you can't tend to the trap every day and are concerned with the water freezing,. Or leave it w/o water and release them if you choose. A 5 gallon joint compound bucket will work, the paste buckets I have are a little deeper, so water is not needed. From what I've been told antifreeze is a quicker kill than water, and they won't decompose and stink as quickly.
You put it against a wall, with the ramp alongside the wall, they run along the corners formed where the walls meet the floor. If the garage is empty you can put it against the wall with two ramps.
I stole the idea years ago when the dead end I live on had a rat problem because the village cheaped out and didn't use rat poison in the creek. The village used a 55 gallon drum with water with the same design and caught quite a few stragglers after they put out poison.
It took all of about 10 minutes to build, including digging out some tools for drilling and cutting.
God Bless Our Troops
Re: More mouse issues [Re: Donald] #4974351
01/09/19 04:16 PM
01/09/19 04:16 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Dozens of devious mouse trap examples on Youtube. My daughter got some ultrasonic deterrent things from Amazon and hasn't seen a mouse in her garage since.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: More mouse issues [Re: Donald] #4974378
01/09/19 04:45 PM
01/09/19 04:45 PM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Don't remember where I grabbed this picture (not mine), but I got a good chuckle out of it. Have no idea of its efficacy (wouldn't it just trip a breaker?), but it struck me as being pretty clever.
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: More mouse issues [Re: Donald] #4974392
01/09/19 05:01 PM
01/09/19 05:01 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
OMG, hahahahahahah that's the best mouse trap I've ever seen.
I'm currently renting a log home in PA. The mice have decided they like my home. One night, I felt a mouse scratching on my back while I slept. Trying to climb up on me I guess. The covers flew off, that was war. The next day, I caught 3 of them immediately and 2 more a bit later on.
Re: More mouse issues [Re: Donald] #4974423
01/09/19 05:37 PM
01/09/19 05:37 PM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
They can be challenging to get rid of.
What helps is that their stupid. Their brains don't evolve and adapt to hazards.
I always had mice under the concrete slab at my front door.
Last two Weeks I trapped six of them. Using plastic traps with peanut butter.
To solve problem, I added more dirt along the side of walkway so they can't easily burrow under concrete.
If their getting IN your garage, try and trap them outside.
1) Get rid of any Bird-Feeders
2) Discard any objects in your yard they may hid under
3) Set out traps and ALWAYS maintain with fresh bait.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: More mouse issues [Re: 28oz] #4974468
01/09/19 06:36 PM
01/09/19 06:36 PM
Oklahoma
65f100 Offline
65f100  Offline
Oklahoma
Somebody built one and it didn't kill mice.
Re: More mouse issues [Re: Donald] #4974484
01/09/19 07:03 PM
01/09/19 07:03 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
What brand of seal did you get? I have the gab issue too.
Northshorecommercialdoor.com has a rodent proof seal that interests me.. Just not sure on the gab coverage.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980 (Ecore)
Re: More mouse issues [Re: Donald] #4974577
01/09/19 08:42 PM
01/09/19 08:42 PM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
I ordered the seal from northshorecommercialdoor. It's $2.50 a foot and fits in the normal T track. That seal appears to cover a gap up to 2". That was before I saw the mouse chewing. Now thinking of getting the rodent proof seal.
That company seems to have a wide variety of bottom seals to seal up to almost 3" gap. Even an air be bladder you slide in the seal and then blow it up.
I also had a garage door company come and adjust my door a little so it was hitting the floor as flat as it could.
Re: More mouse issues [Re: Donald] #4974823
01/10/19 07:30 AM
01/10/19 07:30 AM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
Catching them is not the problem. The plastic mouse traps work fine (mostly)..
But I do not want them chewing the bottom seal to get in.
Not sure how a mouse thinks or smells. Did the mouse smell peanut butter from outside the garage and chew the garage door seal to get in and get some yummy peanut butter? Or did he chew to get warm and then found the peanut butter.
If the garage door was perfectly sealed would the mouse have attempted. The seal was not 100% and the mouse made the space larger and then climbed in.
They sell garage door seal with an anti-rodent lining. But the seal I have on order should seal better.
Re: More mouse issues [Re: Donald] #4974858
01/10/19 08:18 AM
01/10/19 08:18 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'm interested in how the new seal works for you. As far as the traps, you had much better luck than I did. I was dealing with Houdini, but he didn't escape the bucket trap.
Re: More mouse issues [Re: demarpaint] #4974884
01/10/19 08:57 AM
01/10/19 08:57 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Very nice. I use the bucket without the wheel. its pretty effective. But i think the wheel will make it even better. Thanks for the tip!
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
Re: More mouse issues [Re: Donald] #4974918
01/10/19 09:31 AM
01/10/19 09:31 AM
One Step Beyond
One Step Beyond
Mice are always out exploring and prefer to travel along (the bottom of) walls (may give them a sense of security).
If you use a 'snap type' trap, place it along the wall.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
