I've searched for this data here and Google, but no where can I find it.
Amsoil bypass filter (the filter itself, not the bypass "system") flow vs diff pressure data.
I've seen several graphs for other filters that show how many GPM the filter will flow vs the differential pressure across it.
Example: How much flow can the bp100 filter pass with a 2, 5, or 10 PSI differential?
As for why?
Could a bp100 or 110 filter be the primary/only oil filter if the oil flow rate is ~1 GPM with a drop of only 2-3 PSI?
Thanks, all.
As for why?
Thanks, all.
