CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
PTL, vdubw, NJ01MGM, Antiquity, tundraotto
69034 Registered Users
26 registered members (carlprop, e55amgbenz007, edyvw, clinebarger, Deontologist, 5 invisible), 878 guests, and 19 spiders.
Topics293,664
Posts5,044,641
Members69,034
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4968987 01/03/19 05:39 PM
skyactiv Offline
I bought an OEM one for my GTI. My car has two fuel pumps, one in the tank and a high pressure cam driven fuel pump for the direct injection. The fuel filter has a built in regulator for my application. I don't trust the aftermarket
to be as precise like the OEM filter in that regard.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4969071 01/03/19 07:20 PM
Snagglefoot Offline
Aftermarket.(clearance private brand) from Rock Auto. Not sure what’s in them. I guess cutting them might be a little risky. laugh
If you want the job done right......do it yourself.
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4969151 01/03/19 08:37 PM
Q
qdeezie Offline
Q
When I buy a vehicle, my first replacement fuel filter is OEM and my subsequent filters are all aftermarket.
My logic for doing this is that I want to establish a baseline on how the vehicle runs (usually I'm buying used vehicles so there are certain parts I replace from the start) and from that point on, I should be able to pinpoint a problem if there's a problem with the aftermarket piece. I haven't roasted a fuel pump or stopped up injectors yet from a filter, so I guess I'm doing ok.
'90 F150 XLT Lariat
'13 Hyundai Elantra Coupe SE
'03 Ford Focus ZX3
'06 F150 King Ranch
Re: Do you buy OEM fuel filters or aftermarket? [Re: khittner] #4969153 01/03/19 08:38 PM
J
JC1 Offline
J
Originally Posted by khittner
A Mahle fuel filter for your Civic is $6 from RockAuto. 99 Civic Fuel Filters From RockAuto Looks like a bargain on a first-rate part to me.
That is what I'll be buying for the 97 Civic this spring.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4969530 01/04/19 09:51 AM
DoubleWasp Offline
Depends, depends. Mostly on how critical fuel filtration is to the fuel system.
With the exception of CAT 2-micron filters, I never use a non-OEM fuel filter for diesel. Injectors are stupid expensive, sensitive, and a royal pain to replace. No thanks.
For gas, I can usually find a good enough deal on OEM that I'll do that. If it's just a regular old vehicle I have, then I'll just get a name brand fuel filter. If it's something I've had to clean the injectors on because they were disgusting, then I'll slap in a 6-micron filter/separator.
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4969539 01/04/19 10:10 AM
Snagglefoot Offline
There are plenty of cuts of new and used filters on You Tube to help make a decision.
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4969835 01/04/19 04:09 PM
Snagglefoot Offline
Although fuel filters look a lot like oil filters, the oil flows at liters or quarts per minute with oil filters and liters or quarts per hour with fuel filters. It’s not brain surgery to build a decent gas filter.
laugh
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4974252 01/09/19 02:30 PM
N
nthach Offline
N
OEM or from who made the OEM part originally. On Japanese cars, Denso/Mahle Japan/Toyo Roki made the OEM filter and I've noticed Worldpac's NPN line did have a Japanese-made part in the box that felt and installed like the OEM Denso.
Last time I replaced a fuel filter, I used a Taiwanese GM clone. It works fine. One thing about California's mandate for double-walled fiberglass underground tanks for pollution prevention, cleaner(in terms of particulate matter) fuel at the pump.
Re: Do you buy OEM fuel filters or aftermarket? [Re: InvalidUserID] #4979836 01/15/19 11:06 AM
U
UG_Passat Offline
U
Usually buy Mann filters.
Funny, that on the 2.0T (FSI-turbo and TSI), VW puts a second external fuel filter on certain cars, namely GTI's and Jettas.
The same engine on a Passat, CC, & Tiguan only has the in-tank filter/strainer only. No external second filter.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Page 2 of 2 1 2
