Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
121 registered members (2009Edge, 2010Civic, 853okg, 2K2AcuraTL, ad244, 12 invisible), 2,303 guests, and 67 spiders.
Topics286,029
Posts4,901,100
Members67,549
Most Online2,967
Mar 10th, 2019
BMW miss from bad battery? #4974214
01/09/19 01:37 PM
01/09/19 01:37 PM
Seattle WA
Scout1 Offline OP
Scout1  Offline OP
Seattle WA
2013 328i convertible threw a battery discharge warning couple day ago so I figured a battery replacement was in order. Then last night, it started to miss heavily but I don't see any codes on my generic scan tool. I've replaced the battery this morning (kind of a pain since the AGM battery weighs a ton!) but the heavy miss remains. I need to order a BMW scanner so I can register the new battery so I'll have that in a few days to see if there are any BMW codes in there. The old battery was only at 11.7 volts so it was definitely going bad, but the car was still starting and running. It does have a "Service Engine Soon" message but all the on-board maintenance stuff shows green - not due yet. I understand this is a BMW unique message and is similar to a CEL but I can't tell what it may mean till my BMW scanner comes. (I think I'll order the Bavarian Technic 3 VIN setup so I can work on my Z4 as well)
Anybody know if a BMW will shut things down, like a fuel injector maybe, due to system errors caused by a low voltage battery? Seems like that would throw a generic OBD code wouldn't it? With the new battery, think whatever it is might clear with a few engine cycles?
Scout1
Truth will always bear up against falsehood, as oil does above water
Re: BMW miss from bad battery? [Re: Scout1] #4974219
01/09/19 01:41 PM
01/09/19 01:41 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
You would have to read the codes to know what is causing the misfire.
I have the Carly app and bluetooth adapter for my iPhone. It is a bit slow but makes reading the codes and changing features on the car pretty simple.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: BMW miss from bad battery? [Re: jeepman3071] #4974227
01/09/19 01:50 PM
01/09/19 01:50 PM
Seattle WA
Scout1 Offline OP
Scout1  Offline OP
Seattle WA
Yeah, I was looking at Carly but as I understand it, they have gone to a subscription model of $60 per year haven't they? Does that mean your app won't work at all unless you resubscribe and pay each year? I think the Bavarian Technic scanner provides free software updates with no charge so I figure it may actually be cheaper?
Scout1
Re: BMW miss from bad battery? [Re: Scout1] #4974256
01/09/19 02:41 PM
01/09/19 02:41 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Yes, the Bavarian Technic tool is a much better option.
Personally, the best option is to buy the BimmerGeeks cable then download ISTA+ and BMW tools which can be found in the coding section of the BMW forums.
I mentioned Carly because you could probably get the adapter in a day from Amazon to figure out the issue with your car.
Re: BMW miss from bad battery? [Re: Scout1] #4974261
01/09/19 02:45 PM
01/09/19 02:45 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Take a look at Foxwell nt520 for about $190 out the door.
http://www.foxwelltool.com/search/?q=BMW&DirID=
These are popular with the DIY crowd. I have no useful ideas with regards to the miss. I'm thinking plug/coil pack but like you said you have no codes with your generic scanner.
You can ask a BMW Master Tech: https://bmwtechnician.com/
435i
Re: BMW miss from bad battery? [Re: Scout1] #4974346
01/09/19 04:05 PM
01/09/19 04:05 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Most likely coil pack/packs failing, if your service engine soon light is on that means there are faults present. Id recommend doing them all if theyve never been done. Also check voltage while running and loaded up with accessories, like wipers full heat, defroster etc and make sure its above 13.5, but lower than 14.8 or 15. That foxwell tool looks pretty capable, and has alot of nice resets and live data, thats well worth the 200, it has features my professional level tool has. Also, if thats an early N20, the 4 cylinder turbo, check the VIN to see if there were any timing chain updates done. Alot of times the nicer ones that have lower mileage rarely ever see the dealer for updates and recalls.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: BMW miss from bad battery? [Re: Audios] #4974467
01/09/19 06:36 PM
01/09/19 06:36 PM
Seattle WA
Scout1 Offline OP
Scout1  Offline OP
Seattle WA
Do you know for sure that Foxwell tool will register and code the battery? In looking at their literature, it's not clear to me that it will and I definitely need a tool to do that battery registration. I put in a 95 AH battery and took out a 90 AH so I'll need to re-code the system for the slightly larger battery... at least that's what I gather from reading on-line...
Scout1
Re: BMW miss from bad battery? [Re: Scout1] #4974536
01/09/19 08:04 PM
01/09/19 08:04 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
Have had numerous non-BMW that were sensitive to a failing battery. So yes, certainly possible.
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: BMW miss from bad battery? [Re: Scout1] #4977346
01/12/19 08:19 PM
01/12/19 08:19 PM
Seattle WA
Scout1 Offline OP
Scout1  Offline OP
Seattle WA
Solved!
So I decided to go for the Carly app to read the codes but Amazon Prime took till today to get the adapter to me :-(
It had all sorts of misfire codes, #2, #5, and even a code for "multiple cylinders" plus it had a bunch of other codes as well including "undervoltage". So I cleared everything, started it up and misfire cylinder #2 came back. All the other codes stayed off since the new battery was installed so that took care of all those. So I open it up and looked at the #2 spark plug and it wasn't fouled so I switched the coil packs between cylinders 1 & 2. Low and behold when I started it up, cylinder #1 misfire. So, down the the parts store for a new coil pack and all is well again. I did register the battery properly with the Carly app which works quite well by the way!
Bottom line was my battery for $150, the one coil pack replacement for $39 (Bosch OEM from Napa) plus $120 for the Carly diagnostics. So not too bad I guess...
Still wonder if the low voltage took out the coil pack? Anybody ever hear of that happening or is this just a coincidence the coil pack went bad the same time as the battery?
Scout1
Re: BMW miss from bad battery? [Re: Scout1] #4977351
01/12/19 08:25 PM
01/12/19 08:25 PM
Seattle WA
Scout1 Offline OP
Scout1  Offline OP
Seattle WA
By the way, I'm pretty sure this coil pack is covered under warranty since this is an N51 engine and is covered under the 7 year/70,000 mile SULEV warranty. Anybody know if I can get reimbursed from BMW for the coil pack I replaced? How would I do that, just take the receipt into my BMW dealer? I bought this car used so I don't have a relationship with my local BMW dealer...yet!
Scout1
Re: BMW miss from bad battery? [Re: Scout1] #4978158
01/13/19 06:18 PM
01/13/19 06:18 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Call directly BMW North America, or if you have good relationship with Service advisor at local dealership, talk to them. Good relationship with SA goes long way. I save bunch of money on my X5 when my SCR cat failed. They did everything possible to save me from changing cat which was covered until 80k, and I had 87k.
Also, once you realized it is coil pack, why not taking it to dealer?
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: BMW miss from bad battery? [Re: Scout1] #4978184
01/13/19 06:47 PM
01/13/19 06:47 PM
southeast texas
meadows Offline
meadows  Offline
southeast texas
Why do you register the battery in a BMW?
Re: BMW miss from bad battery? [Re: meadows] #4978189
01/13/19 06:52 PM
01/13/19 06:52 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
So the adaptive charging system knows the capacity of the battery.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: BMW miss from bad battery? [Re: Scout1] #4978227
01/13/19 07:26 PM
01/13/19 07:26 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
It's unlikely they'll reimburse for the coil for a variety of reasons, buy lesson learned.
435i
Re: BMW miss from bad battery? [Re: edyvw] #4979418
01/14/19 09:36 PM
01/14/19 09:36 PM
Seattle WA
Scout1 Offline OP
Scout1  Offline OP
Seattle WA
I thought about it, but I wasn't totally sure it was the coil pack till I replaced it and it fixed my problem. Also, I was worried about driving it with such a heavy miss thinking I would be dumping raw gas into my very expensive CATs. Come to find out that BMW engine management software actually turns off the gas to a cylinder where it detects a misfire so I probably would have been OK.
Scout1
