On my 2003 suburban 4wd there is no way to get a torque wrench on the top nut that i can see...maybe if you removed the inner fender.
I used a ratchet wrench on the top nut and got it as tight as i could...drove it and then checked again after it settled.
Bottom bolt..Tight as you an get it by hand is good enough.
