Vintage Sinclair promo
by HiPowerShooter - 02/18/20 11:29 PM
why did my Ford iolm go to 9% after 3k miles?
by dogememe - 02/18/20 11:15 PM
HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
67 registered members (bbhero, avi1777, 69GTX, A_User55555, 6 invisible), 1,472 guests, and 14 spiders.
Topics301,630
Posts5,199,513
Members70,746
Engine still missing after replacing code Variable Valve Timing Actuator #4973679 01/08/19 08:48 PM
J
JLawrence08648 Offline OP
J
2005 Toyota Rav, 4 cylinder, engine is missing badly under acceleration and very badly when cold. Idles pretty good but you can feel slight bucking, almost indiscernible, on the highway. AutoZone read the codes and said most common problem for that code is the variable valve timing actuator. So I replaced with OEM Toyota Densa. No difference. I did not have the codes re-read. What's next?
I thank those people on here who told me where the darn thing was located! But once you had the part in your hand, it was easy to find.
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973682 01/08/19 08:53 PM
spasm3 Online Happy
Online Happy
Can you give us the codes that the ecm has thrown? Is it throwing the same codes after the VVTA?
How many miles and what maintenance has been done so far?
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973683 01/08/19 08:54 PM
P
PeterPolyol Offline
P
Hows that head gasket?
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973691 01/08/19 09:00 PM
R
Rand Offline
R
any leaks or missing fluids(vanishing oil, coolant etc)
When is the last time it got plugs and wires?
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973725 01/08/19 09:42 PM
M
michaelluscher Offline
M
I'd check ignition
What's the milage?
That 2AZ I4 is coil on plug
Remove all 4 and check plugs/boots
2006 Toyota Camry SE V6
131k
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973726 01/08/19 09:42 PM
crainholio Offline
Sounds like you replaced the VVT oil control valve, not the actuator. Are you certain which part it was? The VVT actuator is typically part of the intake camshaft sprocket assembly, not an easy project. The oil control valve is bolted to the outside of the cylinder head and sounds more like what you're working on.
What error code(s) was it throwing prior to the replacement?
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973866 01/09/19 05:33 AM
Char Baby Offline
Yes, it could be the coil on plug(COP). Is this the 4 cyl or V6? Not that it matters.
If this engine is the V6, I am suggest looking into the Knock Sensors. "Look into", I mean, have the engine scanned properly, looking for issues deep into the system...IDK if I said that right but, I had this issue on an RX300.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973951 01/09/19 07:36 AM
J
J
Head gasket is fine, not losing any water, nothing to indicate bad head gasket, synthetic oil since new, changed every 10k, 173,300 miles, 4 cylinder, variable valve timing oil control aka solenoid valve assembly replaced, has a sensor, wire, 10mm bolt, bolts from rear of the engine front
I believe the code for the "actuator" was P0027 but I don't remember for sure, AZ gave me a paper. I back Googled the code for actuator.
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4974101 01/09/19 10:24 AM
L
LeakySeals Offline
L
Is a 2AZ-FE?
Were you getting the vvt lock pin rattle at startup?
How much oil are you consuming?
What brand and weight oil are you using?
What oil filter are you using?
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: Rand] #4974157 01/09/19 11:33 AM
SatinSilver Offline
+1,..........
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: LeakySeals] #4974161 01/09/19 11:37 AM
J
J
Originally Posted by LeakySeals
Is a 2AZ-FE?
I don't think it's a 2AZ-FE engine, 2.4 FI DOHC
Normal oil usage, 1 qt every 2,000 miles or so, maybe 3,000, maybe even little longer
Brand varies, right now Pennzoil, sometimes Valvoline, Mobil 1, usually Pennzoil
5w-20
Usually Toyota, right now Fram
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4974633 01/09/19 08:45 PM
clinebarger Offline
All 2005 Rav 4's have a 2AZ-FE.
Post the actual Codes as P0027 isn't valid for your vehicle
2001 Chevy Camaro L92/4L80E
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4974637 01/09/19 08:54 PM
A
atikovi Offline
A
Throwing parts at a problem based on a stored code rarely fixes the issue. You need to diagnose why the code was set. Maybe look at the freeze frame data as a start.
