Cleaning Painted Alloy Wheels
by Wrenchturner44 - 08/25/19 03:57 PM
1988 cadillac brougham oil disappearing
by momo - 08/25/19 01:41 PM
Amp draw
by mjk - 08/25/19 01:36 PM
SHELL cracker plant
by 53' Stude - 08/25/19 12:03 PM
Mirrored Window Film
by Warstud - 08/25/19 11:40 AM
I want a Challenger
by Jarlaxle - 08/25/19 11:33 AM
Why not?🤔
by Mad_Hatter - 08/25/19 11:10 AM
CanAm OEM oil alternatives
by Carbon12 - 08/25/19 10:46 AM
2019 Dodge Ram Classic 1500 Big Horn Brakes
by Honda2003 - 08/25/19 10:45 AM
Pontiac V8 oil observation
by CheezWhiz - 08/25/19 10:42 AM
Dillemma ...
by Baveux - 08/25/19 10:41 AM
Schaeffers vs Mobil one
by salesrep - 08/25/19 10:04 AM
Moly EP grease
by rideon - 08/25/19 09:59 AM
grease in a golf cart clutch
by jacobsond - 08/25/19 09:53 AM
Pennszoil
by JohnnyJohnson - 08/25/19 09:32 AM
Clunk from the front when I let out the clutch
by atikovi - 08/25/19 09:16 AM
M1 5w30 SN+ D1 / G2 Make Up ?
by ChrisD46 - 08/25/19 09:07 AM
2015 F150 owners manual rear diff fluid options
by Buzzinhalfdozen - 08/25/19 09:02 AM
Recommend a 7 passenger w/10,000 tow
by sasilverbullet - 08/25/19 08:54 AM
Faux, jk1401, EricTwoCamaros, Subie5w30, Iautox
69057 Registered Users
89 registered members (53' Stude, 007, 08z06, aircooled, 2K2AcuraTL, 12 invisible), 2,300 guests, and 25 spiders.
Topics293,783
Posts5,046,669
Members69,057
Most Online3,532
Jul 30th, 2019
Engine still missing after replacing code Variable Valve Timing Actuator #4973679 01/08/19 09:48 PM
J
JLawrence08648 Offline OP
J
2005 Toyota Rav, 4 cylinder, engine is missing badly under acceleration and very badly when cold. Idles pretty good but you can feel slight bucking, almost indiscernible, on the highway. AutoZone read the codes and said most common problem for that code is the variable valve timing actuator. So I replaced with OEM Toyota Densa. No difference. I did not have the codes re-read. What's next?
I thank those people on here who told me where the darn thing was located! But once you had the part in your hand, it was easy to find.
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973682 01/08/19 09:53 PM
spasm3 Online Happy
Online Happy
Can you give us the codes that the ecm has thrown? Is it throwing the same codes after the VVTA?
How many miles and what maintenance has been done so far?
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973683 01/08/19 09:54 PM
P
PeterPolyol Offline
P
Hows that head gasket?
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973691 01/08/19 10:00 PM
R
Rand Offline
R
any leaks or missing fluids(vanishing oil, coolant etc)
When is the last time it got plugs and wires?
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973725 01/08/19 10:42 PM
M
michaelluscher Offline
M
I'd check ignition
What's the milage?
That 2AZ I4 is coil on plug
Remove all 4 and check plugs/boots
'06 Toyota Camry SE V6 3MZ-FE 124k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973726 01/08/19 10:42 PM
crainholio Offline
Sounds like you replaced the VVT oil control valve, not the actuator. Are you certain which part it was? The VVT actuator is typically part of the intake camshaft sprocket assembly, not an easy project. The oil control valve is bolted to the outside of the cylinder head and sounds more like what you're working on.
What error code(s) was it throwing prior to the replacement?
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973866 01/09/19 06:33 AM
Char Baby Offline
Yes, it could be the coil on plug(COP). Is this the 4 cyl or V6? Not that it matters.
If this engine is the V6, I am suggest looking into the Knock Sensors. "Look into", I mean, have the engine scanned properly, looking for issues deep into the system...IDK if I said that right but, I had this issue on an RX300.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4973951 01/09/19 08:36 AM
J
J
Head gasket is fine, not losing any water, nothing to indicate bad head gasket, synthetic oil since new, changed every 10k, 173,300 miles, 4 cylinder, variable valve timing oil control aka solenoid valve assembly replaced, has a sensor, wire, 10mm bolt, bolts from rear of the engine front
I believe the code for the "actuator" was P0027 but I don't remember for sure, AZ gave me a paper. I back Googled the code for actuator.
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4974101 01/09/19 11:24 AM
L
LeakySeals Offline
L
Is a 2AZ-FE?
Were you getting the vvt lock pin rattle at startup?
How much oil are you consuming?
What brand and weight oil are you using?
What oil filter are you using?
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: Rand] #4974157 01/09/19 12:33 PM
SatinSilver Offline
+1,..........
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: LeakySeals] #4974161 01/09/19 12:37 PM
J
J
Originally Posted by LeakySeals
Is a 2AZ-FE?
I don't think it's a 2AZ-FE engine, 2.4 FI DOHC
Normal oil usage, 1 qt every 2,000 miles or so, maybe 3,000, maybe even little longer
Brand varies, right now Pennzoil, sometimes Valvoline, Mobil 1, usually Pennzoil
5w-20
Usually Toyota, right now Fram
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4974633 01/09/19 09:45 PM
clinebarger Offline
All 2005 Rav 4's have a 2AZ-FE.
Post the actual Codes as P0027 isn't valid for your vehicle
2001 Chevy Camaro L92/4L80E
Re: Engine still missing after replacing code Variable Valve Timing Actuator [Re: JLawrence08648] #4974637 01/09/19 09:54 PM
A
atikovi Offline
A
Throwing parts at a problem based on a stored code rarely fixes the issue. You need to diagnose why the code was set. Maybe look at the freeze frame data as a start.
