Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
72 registered members (2004tdigls, 1foxracing, 2009Edge, 2015_PSD, 2010Civic, Agnosto, 5 invisible), 1,385 guests, and 54 spiders.
Topics286,108
Posts4,902,735
Members67,563
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #4970168
01/05/19 12:00 AM
01/05/19 12:00 AM
Spokane, WA, U.S.A.
HighbrowHillbill Offline
Spokane, WA, U.S.A.
Originally Posted by DoubleWasp
The XG7317 is loads better than the 60-80 micron unit Mopar uses. Using the XG is the same thing as adding an external oil filter to the cooler line, except it's in the pan, and the XG is a lot better than even most of the oil filters used in those kits.
Long story short is, most definitely enough. The XG has pretty good efficiency even at 5 microns.
I would highly recommend you get a metal filter boss from one of the many suppliers that make one. I don't trust the plastic ones that come with those filters.
Also, don't forget to toss some good high temp magnets in the pan. 68RFE solenoids hate ferrous metal contamination.
And don't forget to tape off the open end of the filter and wire wheel off the filter's paint. I don't even know if it is an issue, but it's super easy to knock off all the paint with a wire wheel. Just takes a few seconds. Then wipe the can down with a towel and brake cleaner, so you're not leaving behind metal and paint dust.
What is a metal filter boss?
Could you post a link to the magnets you used?
Did you ever take pictures of your remote filter setup?
05' Ram 5.9 Cummins
11' Infiniti QX56
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #4973570
01/08/19 08:14 PM
01/08/19 08:14 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
On subaru the ATF spin on filter filters only 10 to 15 of the oil on each pass most is diverted through a screen. Those that substituted a regular engine filter wound up having transmission failures.
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #4988598
01/23/19 02:54 PM
01/23/19 02:54 PM
Fort Lauderdale, FL
DoubleWasp Offline OP
Fort Lauderdale, FL
Subarus must be different. Mine having no issues after more than 20k miles.
Google "68rfe steel filter screw" for the metal filter boss. I'll post pics of my setup soon.
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #4999031
02/02/19 12:40 AM
02/02/19 12:40 AM
Spokane, WA, U.S.A.
Spokane, WA, U.S.A.
Thanks, I'd never heard of that part. And I know very little about the 68RFE. Driven a few with that trans for short distances, but I still just like my old NV5600. Super simple and never needs anything.
Looking forward to the pics. I've been gathering parts for around a month now to put together an inline filter for our 11' QX56 and it's 7AT. Getting pretty close.
05' Ram 5.9 Cummins
11' Infiniti QX56
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #5024740
02/26/19 06:57 PM
02/26/19 06:57 PM
sonoma
burla Offline
burla  Offline
sonoma
Thanks double wasp, what a great find you have here. I took my rfe filter off and cut it open at 30k, stiff as a board, likely been on bypass for a while. Very smart knocking off the paint as well, proper mechanic you are sir.
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #5024743
02/26/19 07:02 PM
02/26/19 07:02 PM
sonoma
burla Offline
burla  Offline
sonoma
U&A at Ram Forum found a direct replacement as well...
pic doesnt come thorugh, PM if interested from ram forum.
m1-110a is a direct fit for the mopar rfe trans filter, lines up prefext, threads screw together as well.
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #5024751
02/26/19 07:14 PM
02/26/19 07:14 PM
sonoma
burla Offline
burla  Offline
sonoma
The cross reference to that m1 filter is 57055xp for the wix xp. I just did my change, but I saved my old filter, I will see if that xp will direct fit. If I can't get RP I think I'd like the XP, but also really appreciate having Fram Ultra as an option. great thread bud, and the metal thread upgrade is a must as well.
Re: Begun a Transmission Filter Experiment on my 68RFE [Re: DoubleWasp] #5024916
02/26/19 09:32 PM
02/26/19 09:32 PM
sonoma
burla Offline
burla  Offline
sonoma
amsoil ea EA15K13 another synthetic option.
Page 2 of 2 1 2
