S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
115 registered members (853okg, 2K2AcuraTL, 2010Civic, ad244, ABerns, 12 invisible), 2,237 guests, and 65 spiders.
Topics286,028
Posts4,901,089
Members67,549
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
PentaStar Hot Stumble - Fixed #4973413
01/08/19 05:07 PM
01/08/19 05:07 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I ordered a replacement coolant temperature sensor in an attempt to fix my annoyance of the Caravan's hot-restart minor stumble. It bugged me because it has done it since new and my Father in-laws which is a 2017 that I have driven enough didn't so while it was nothing to panic about it did bug me. (OCD)
Anyway... I had gapped the plugs, scoped it, read for codes, looked at each cylinder on my dad's scope, and looked at the oxygen sensors and couldn't seem to figure it out.
Finally I decided for the whole $10 USD that a new temperature sensor was worth a shot and it looked easy to change so I thought I would take the chance and try that and if not that I would look into the Map Sensor.
Before I put it in I measured the ohms at room temperature and at 32F (0c) on the new sensor and made a note of it. Then I replaced the sensor and let the other one cool to room temperature over the course of a day and measured its ohms and again at 32F (0C) using cold ice-water (Similar to how you calibrate a kitchen probe thermometer). There was a difference of 61 ohms between the two temperatures so clearly something is a miss in the old one seeing as the new one fixed the problem.
It was also a problem with the coolant reading 200F or more with the old one in place so the ohms could be drastically different between the two sensors at this temperature than just the 61 I could see at the cooler temperatures.
I waited a few days to be sure the problem wouldn't return because of the adaptives re-calibrating things and it hasn't. I went through a complete tank of gas in this time as well.
I'm posting here because I forget who else said they had a minor stumble as well in their 2018 PentaStar equipped vehicle. (My apologies I didn't make a note), and also for anyone else that might encounter the problem.
It now idles in gear and out of gear as smooth as glass and you can barely tell the vehicle is running at the lights it's so smooth and quiet. If it weren't for the injectors pulsing it would be hard to hear the engine at all with the hood closed.
Changes I noticed:
-Secondary ignition wave form looks slightly different from previous.
-Injector Pulse width has changed slightly under fully warmed up conditions compared to previous.
-The timing has changed ~2 degrees under various conditions verified with my dad's equipment and my scan-gauge.
-The temperature gauge doesn't bounce around as much when coasting down the highway as it did before.
-Long Term and Short Term Fuel trim numbers under various conditions as reported by my ScanGauge have changed from their previous numbers.
-During moderate acceleration it feels as though the engine pulls away better almost like it want's to go faster on its own ever so slightly. (Sorry best way I can describe it)
The sensor that came out was an Standard brand sensor and the one that went it was the same Standard brand. Only difference is that the one that went in didn't have the Mopar number stamped on the collar of the electrical connector.
How to change the sensor the easy way
I changed the sensor quite easily while the coolant was warm. (It's located in the front head (Bank 2) in the Caravan on the right side, facing the radiator fan brass in colour with a 2 wire connector).
I took the upper radiator hose off the radiator and tied it to the crankcase fresh air breather line to keep it out of the way. (You don't need to remove the plastic clip holding it to the plennum)
I then took off the overflow bottle which just sits in slots on the radiator by sliding it upward. (Have to take off the hose going to the fill-neck of the radiator first though)
I Then slid the red safety lock on the sensors electrical connector backward using a small flat screw driver the length of my thumb, before squeezing and pulling off the connector.
Unscrewed the sensor using a 3/4" wrench and quickly put the other one in before too much coolant leaked out.
Tightened until just snug and then 1/2 turn to crush the sealing washer the sensor comes with.
I Put the connector back on and put the radiator hose / overflow bottle back in place. Topped up the coolant in the radiator and then somewhat burped the system running it without the cap on the radiator for a few minutes and then took it for a drive to continue the burping process.
Not that a coolant temperature sensor isn't important or doesn't play a big role in a vehicles engine management setup, but I think it's very important in the case of this engine because they run them as lean as possible for a PFI setup and even minor difference in readings between sensors that otherwise seem to function fine can make a big difference as noted above.
Anyway, happy it's fixed and happy to share with others that might be scouring the web for their 3.6L PentaStar Chrysler/Dodge engines in various models of vehicle.
cheers
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973440
01/08/19 05:53 PM
01/08/19 05:53 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Thanks for the tip. Good job on fixing the problem!
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: PentaStar Hot Stumble - Fixed [Re: zrxkawboy] #4973446
01/08/19 05:58 PM
01/08/19 05:58 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
thumbsup You are welcome...
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973453
01/08/19 06:09 PM
01/08/19 06:09 PM
Chicagoland
Skippy722 Offline
Skippy722  Offline
Chicagoland
Good too know! I’ll lkeep this in mind if mine ever starts acting up.
The Grand Caravan doesn’t use the PUG engine does it? Or did they finally update that?
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973460
01/08/19 06:13 PM
01/08/19 06:13 PM
south dakota
joekingcorvette Offline
south dakota
Good to know thanks for the tip!
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973470
01/08/19 06:21 PM
01/08/19 06:21 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Didn't ethanol blends fix it ?
Because sometimes the simple things in life...
...simply don't know any better
Re: PentaStar Hot Stumble - Fixed [Re: Shannow] #4973536
01/08/19 07:51 PM
01/08/19 07:51 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I thought so originally and then it came back. It was weird though because it only came back on 91 E-0 it appeared but as time went on it appeared with the 87 E-10 so it was just a fluke. I posted that in that thread.
Re: PentaStar Hot Stumble - Fixed [Re: Skippy722] #4973537
01/08/19 07:53 PM
01/08/19 07:53 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
The GC's only use the PentaStar until their discontinuation at the end of 2019. The Pacifica vans also use the PentaStar but with a 9-Speed transmission instead of the 6-speed in the Caravan. Ram 1500's use it is used in the Jeep line as well. Waiting on the new straight six coming. slobber That will be my next vehicle if it turns out to be a winner like the PentaStar.
I think the 6-speed 62TE and the PentaStar is a great match and really enjoy my commute in it daily.
Now that I have that squared away and I found 1/2" Fuel line I'm going to put my Catch Can that I had on the Highlander on this and see what it catches. Just for fun, not because I think it needs it. Although the line from the PCV on the rear camshaft to the plennum is like 8" at best so it might catch some stuff diverting it to the can first. (Can't stop tinkering).
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973543
01/08/19 07:59 PM
01/08/19 07:59 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Good thing it wasn't misbehaving that badly and good job IDing it. My old Camry use to stall the engine out and not start up again from a bad ECTS giving wild and erratic readings. Never once tripped a CEL which made diagnosis a real bear
There's no replacement...'scosity for natural viscosity
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973550
01/08/19 08:05 PM
01/08/19 08:05 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
How did you obtain a Secondary Waveform on a COP Coil?
In my experience.....I've never seen much difference in secondary waveforms if the ignition components & engine is in good health.........Unless it's running so lean that the engine is actively misfiring.
I find it easier to tag Primary Current on Ford & Chrysler COP vehicles as the Transistor is remote (PCM).
2001 Chevy Camaro L92/4L80E
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973613
01/08/19 08:54 PM
01/08/19 08:54 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
My dad has a pick-up that goes between the boot and the coil over and another going after the boot to the plug. Pico does a good job explaining how it works although his isn't a Pico. I would love to have a Pico though. slobber https://www.picoauto.com/library/automotive-guided-tests/secondary-coil-output-test/
It's a royal pain in the you know where to do this on the PentaStar with the plennum needing to be removed and then trying to fit all this mess with the coils underneath it while testing as the plennum has to be back on for the test. We ended up doing 1 cylinder at a time and just using 2 of the bolts to hold the plennum in place in between testing the front cylinders.
Back cylinders are easy because it just involves removing the throttle body and air tubing/box at the back to change from one cylinder to the next.
I have access to his big arse garage at his rural home and it's semi-heated and there is always fresh coffee mum makes so I have all the time in the world to mess around. Like a kid in a candy store plus I get to spend time with my dad before the inevitable happens.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973619
01/08/19 08:57 PM
01/08/19 08:57 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Nice diagnostics and fix, will file this just in case I need it. Thanks for sharing this thumbsup
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: PentaStar Hot Stumble - Fixed [Re: KrisZ] #4973625
01/08/19 09:01 PM
01/08/19 09:01 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Glad folks might get use out of this. It was a weird one because it wouldn't set the misfire counter on the cylinders either and no MIL/CEL.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973698
01/08/19 10:15 PM
01/08/19 10:15 PM
MN
14Accent Offline
14Accent  Offline
MN
Great diagnosis! Just goes to show how reliant engine computers are on coolant temperature readings for proper operation.
Reminds me of a tough one I had come through the shop earlier this week. 1994 Econoline with the 4.9 straight 6. The complaint was a surging and stalling when up to temp, coming to a stop or taking off from a light.
I could tell right away on my test drive that something wasn't right. It's idled OK, cruised OK, but throttle tip-in was awful. It wanted to stall almost every time. Being OBD1, I figured I had a long road ahead of me.
Long story short, a quick scan of the limited data stream showed an engine coolant temp of 400!! I almost couldn't believe it. I tested the wiring to confirm the PCM was alright, and replaced the sensor. It solved all the problems!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973700
01/08/19 10:17 PM
01/08/19 10:17 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
400, wow. LOL
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973760
01/08/19 11:39 PM
01/08/19 11:39 PM
MN
14Accent Offline
14Accent  Offline
MN
Originally Posted by StevieC
400, wow. LOL
You're telling me. I won't lie, there was a strong part of me that wanted to ignore that data. Early OBD isn't known to be reliable, and scanner software isn't perfect. Especially on older vehicles.
The one thing that helped me was the temperature gauge. It read perfectly normal at all times. One of the nice things about those older cars is the instrument clusters are analog and simple. There's almost always a second "dumb" temperature sensor (i.e. a simple 1 wire resistance unit) that feeds the cluster, since data lines were almost non-existent then.
Just to throw another kink in the mix, when I unplugged the failed sensor (for the PCM input), the data stream would read ~ coolant temperature. I have no idea why, or where it got that number, but strange nonetheless.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973785
01/09/19 12:27 AM
01/09/19 12:27 AM
PEARL River la
tiger862 Offline
tiger862  Offline
PEARL River la
Changes I noticed:
cheers
I am the one that had slight stumble at idle. I noticed that the temp gauge would bounce when it did it so I just assumed air was trapped so I ran heater until hot then shut off. Did this until gauge was smooth and now gauge stays little less than half way. The other stumble I got was shutting down after a hard run of interstate get out of the way driving then pulling over to get a cup of coffee shutting off for 10 minutes then restart with a high idle. Assumed that to be mounts since it does it only on high idle around 1500 rpms and only last a second or two so not enough for me to worry about. Smooth as glass at idle as well as driving along with 27 mpg on the trip we took.
Tiger862
2018 Grand Caravan
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973786
01/09/19 12:28 AM
01/09/19 12:28 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Oh ok.. Sorry I got that a bit wrong. Anyway, good info to keep on file. smile
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973788
01/09/19 12:30 AM
01/09/19 12:30 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Oh and pray you never have to change the knock sensors. They are only $16 each but they are royal PITA to get at.
You have to take the plennum off, intake off, oil to coolant heat exchanger off which involves draining the coolant somewhat.
https://www.youtube.com/watch?v=tNeDsDbPxn0
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4973810
01/09/19 01:23 AM
01/09/19 01:23 AM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
Great work OP. I had a similar issue with my old 03 Cobra after I bought it. Seemed like the car just wasn't running strong. Looking at the live feed data and the IAT temp was 366 or so. Took me a while to figure out but a single wire was pinched under the supercharger on the back side against the firewall when the previous owner removed it and reinstalled. Cut, splice, fixed.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 5w30 Euro L
LR Series III 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 PP
10 Charger Pursuit 5.7L
95 Accord - 386k. Mobil 2 RIP
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4974053
01/09/19 10:18 AM
01/09/19 10:18 AM
PimTac Offline
PimTac  Offline
Wouldn’t this be covered under warranty?
Cannot see signatures any longer so it doesn’t matter.
Re: PentaStar Hot Stumble - Fixed [Re: PimTac] #4974068
01/09/19 10:37 AM
01/09/19 10:37 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Yes but because it's not storing any pending codes or hard codes and it's intermittent that is hard to reproduce on demand I decided to go after it myself.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4975257
01/10/19 03:58 PM
01/10/19 03:58 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Yeah, that probably would have been a bear to get a FCA dealer to fix under warranty. Like you say, I've read time and time again where dealers will go the no code, nothing wrong route.
I'm at just under 28K miles with the Pentastar in my Ram 1500. All good so far. Have a brother who liked mine so much, he just bought a new 2019 Ram 1500 classic (old body style) with the pentastar.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4975803
01/11/19 08:32 AM
01/11/19 08:32 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Having driven it for a while now and burning another tank and a bit of gas the adaptives must have tuned it further because I can say I have never driven a V6 of any brand that is this smooth. The thing is smoother than my Highlander I had and that engine is ultra refined and smooth.
I honestly find myself watching the tach at the lights to see if it stalled. I think it's a combination of fixing the temperature sensor, going for the 0w30 over the 5w20 it calls for and having the plugs properly gapped which I did when I was trying to troubleshoot this minor hot-stumble annoyance. Oh and it's also running 91 Octane E-0 fuel which might also add a touch to the smoothness factor as it certainly changes the timing running it.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4975870
01/11/19 10:19 AM
01/11/19 10:19 AM
PimTac Offline
PimTac  Offline
I find myself doing the same with our CX5. At a stop the smoothness of the engine plus the quietness of the cabin push me to glance at the tach. This on 0w20.
Re: PentaStar Hot Stumble - Fixed [Re: PimTac] #4975874
01/11/19 10:25 AM
01/11/19 10:25 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
PimTac, yeah I hear you... Our friends just bought a beautiful silver CX-5 and they love it. It is quite nice from the 10 minutes I spent in it going around the block when they first got it. They use whatever the dealer puts in, I guess 20wt.
The only reason I decided to try the 30wt was because these engines originally spec'ed a 30wt and while there have been some minor revisions to the engine not much has changed and from what I feel so far it seems to prefer it.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976175
01/11/19 02:58 PM
01/11/19 02:58 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Congrats on the coolant sensor replacement ! :-)
Wyr
God bless
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976238
01/11/19 03:54 PM
01/11/19 03:54 PM
Chicagoland
Skippy722 Offline
Skippy722  Offline
Chicagoland
My 300 was in the body shop for awhile and they put me in a 2018 Nissan Altima 2.5 (I should get an equivalent vehicle, but I digress) I forgot how smooth it was and kept doing the same thing all week lol
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976240
01/11/19 03:56 PM
01/11/19 03:56 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I like the 300's. I rented a 1st generation and drove it to Kentucky for our friends wedding. (They now live in Ohio). It was like driving a couch. Our friends here bought one of the 3rd generation ones and while it was nice I found the suspension to be a little more sportier than the refined floaty suspension in the one we rented.
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976242
01/11/19 03:58 PM
01/11/19 03:58 PM
GA
Silver Offline
Silver  Offline
GA
My wife's 2016 GC has a bit of a stumbly idle all the time. No one would notice it but me. It's just a deep, ever so slight jitter. I just figured it's one of those types engines. It runs great although city mileage really sucks at around 12-14. Lots of really short trips though.
It's a loud engine, exhaust-wise. Loudest stock vehicle I think I've ever ridden in.
Got any tricks on checking the trans fluid with no dipstick? ???
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976262
01/11/19 04:19 PM
01/11/19 04:19 PM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Silver,
Yeah their mileage in town does suck... It hasn't gotten any better from 2012 when I drove our first one to now with the 2018. The 2018 is much more responsive though so that's good but does nothing for fuel economy. grin2
Mine isn't loud but I have the GT trim level so it has more noise deadening insulation than the almost base model my dad has which is a 2012 and his is noisier. My dad went to end of the roll and bought a piece of padded commercial type carpet that was great in colour and put it down over the factory black carpet and did a good job cutting it around the seats and tucking under the trim panels / floor boards here/there and that made a huge difference to the noise. He did this when he got it from me (formerly my fleet vehicle for work), so it wouldn't show the dog hair like the black carpet does. Maybe that's an option for you.
To me mine sounds like a buzzing motor with a shhhhhhh type sound coming from the exhaust as I moderately to heavily accelerate as the exhaust gas rushes out the back pipe. If I take off from a light normally I don't hear the exhaust at all and just hear the buzzing of the motor which really makes it sound electric more than mechanical. But this is all probably related to the insulation my trim level has.
It also has blue mood lighting on the ceiling on either side of the DVD screen console. It's different but it's kind neat. Mine is black and not white though...
[Linked Image]
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976396
01/11/19 07:16 PM
01/11/19 07:16 PM
Chicagoland
Skippy722 Offline
Skippy722  Offline
Chicagoland
Mine is the S trim, has the “sport tuned” suspension but not the full “sport” suspension. It rides better than my Citadel ever did! I’d love to take the top of the line luxury model for a spin to compare it, I imagine that one is like driving on a cloud
Re: PentaStar Hot Stumble - Fixed [Re: StevieC] #4976880
01/12/19 11:09 AM
01/12/19 11:09 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I haven't driven in an "S" series only the 300 and 300c which if memory serves me correctly are the same suspension in those models. The SRT line of vehicles have some nice ride feel but sportier feedback suspension. I know my Caravan GT with the self-leveling non-air-bag suspension has a nice ride to it while offering a more sportier feel and boy does it corner. Without self incriminating here I can tell you it does quite well on the highway at higher speeds. grin2
Page 1 of 3 1 2 3
