Any Midweight Moto Guzzi Fans Here?
by Silverado12 - 08/20/19 08:31 AM
Central AC drain pump fail, flood
by LeakySeals - 08/20/19 06:38 AM
WiFi “bridge” to outbuilding
by dlundblad - 08/20/19 05:00 AM
Rental review : 2019 Dodge Charger
by FirstNissan - 08/20/19 12:14 AM
Truck diesel oil in Lawn mower (SAE30)
by Polyalphaolefin - 08/19/19 11:18 PM
Pinstripes Not Popular on Pickup Trucks?
by LoneRanger - 08/19/19 10:04 PM
More choices
by KeithS_NW_Ohio - 08/19/19 09:43 PM
INEOS to Surpass EXOM in PAO production.
by MolaKule - 08/19/19 09:17 PM
Need a miter saw
by JLawrence08648 - 08/19/19 09:01 PM
Using a 7.1 receiver with only 2 speakers
by Papa Bear - 08/19/19 08:44 PM
HD Sportster 5000 mi Red line PS 20w-50
by shanneba - 08/19/19 07:17 PM
College Football Time
by kstanf150 - 08/19/19 07:17 PM
Eco Plug oil drain plug
by passgas55 - 08/19/19 07:15 PM
Pep Boys Deals
by kstanf150 - 08/19/19 06:43 PM
MB229.5 and MB229.51
by Tikka - 08/19/19 06:35 PM
2019 Mazda 3 Recall....Wheels fall Off!
by Boomer - 08/19/19 05:43 PM
Rut Roh!😂
by Mad_Hatter - 08/19/19 04:40 PM
Oil for vintage Mopars
by 440Magnum - 08/19/19 04:37 PM
BigMike61, 80Boxcar, gangan, hoosiersupreme, Brandon86
69004 Registered Users
94 registered members (bmwpowere36m3, bluesubie, 1nighttrain, Alfred_B, Aero540T, AurionX2, 9 invisible), 1,682 guests, and 22 spiders.
Topics293,552
Posts5,042,223
Members69,004
Most Online3,532
Jul 30th, 2019
2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles #4973309 01/08/19 03:01 PM
claluja Offline OP
2014 F250 6.7L PSD, 8800 miles on Amsoil DEO Signature Series Max Duty 5w-40. Motorcraft filter.
Sample #s 1 and 4: Amsoil DEO SS 5w-40
Sample #s 2 and 3: Red Line DEO 15w-40
Deleted 1K into this OCI. Not surprisingly, the delete eliminated the fuel dilution. Plan to start extending OCIs now.
Note: T6 5w-40 resulted in about 3 times as much iron wear per mile for this particular engine, compared to the Amsoil 5w-40 here (see prior posts for the T6 results).
Attached PDF document
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: claluja] #4973371 01/08/19 04:06 PM
Donald Online Content
Online Content
Looks fine. You can get just as good numbers with Walmart oil like Delo or Rotella T6. Amsoil oil is great oil but pricey. I have some UOA on his forum for my Ford PSD. I added a bypass filter and will probably go 3 OLM cycles. At least 2. I have Delo 5W40 in it now.
2015 Ford F250 w/Powerstroke
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: claluja] #4973432 01/08/19 05:43 PM
claluja Offline OP
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: Donald] #4973552 01/08/19 08:05 PM
M
madeej11 Offline
M
Why would he go with Rotella when his post told us it shows 3x more iron wear? Looks like the Amsoil showed even better numbers than the Redline.
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: claluja] #4974235 01/09/19 02:01 PM
dustyroads Offline
If I remember correctly, it seems others that did the delete on their diesel pickups saw huge improvement in the aluminum wear. I wouldn't be surprised if your next sample will show lower aluminum, too, because it'll have the benefit of having been deleted from the beginning. Yours has come down but I bet it drops some more next time.
I've never asked anyone before, but does the engine feel more lively and get better fuel economy now? It sure seems like the engine would breathe much easier without the filter and maybe the exhaust routing is smoother, too ?
I used to have a 2005 Cat C15 in a Freightliner Classic XL and each muffler was actually a catalytic converter type thing ( I'm tired and drawing a blank on the technical name). Removing those and replacing them with free flowing mufflers from Pittsburgh Power really made an enormous difference in the way the engine could pull on the hills.
2013 F150 XLT 5.0 4X4 115k
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: dustyroads] #4974265 01/09/19 02:50 PM
claluja Offline OP
Good to know that a delete may lower aluminum wear - thanks for the advice on that!
I'm no expert, but think how the engine feels post-delete is largely based on what tune is used. I did a full delete, both dpf and egr. Tune I'm using is a tow tune, which only increases HP by a small amount - I was advised to do this because of towing 14K quite a bit and was told that regular street or high performance tune may cause things to start melting/blow. For my particular engine, the delete and tune has resulted in the following:
(1) mpg increase of about 1 mpg. Its more or less depending on driving conditions (e.g., larger increase in the 50-60 mph range, and lower increase at 70-80 mph, from what I can tell). Also, my understanding is that the only way to really know mpg increase is by hand calculation, because the display tool on the vehicle is often inaccurate.
(2) oil temp about 4 degrees lower on average.
(3) engine is a little more lively taking off, and a little more lively during mid-speed operations, but can't tell much difference at highway speeds. With my typical 14K load in tow, it is significantly easier getting out of the hole now.
(4) fuel dilution gone from the oil, presumably because no more fuel being injected on the exhaust stroke during regens (this may be particular to 6.7L engine due to regen design).
(5) shifting is smoother/better.
(6) sound is almost the same, but can hear the turbo a little bit more. No smoke from exhaust. My dpf shell is still on - just doesn't have anything inside of it now - so no new exhaust piping for me.
Can't think of anything else right now.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: claluja] #4974343 01/09/19 04:04 PM
R
racin4ds Offline
R
Two very good looking oils! I really want to try the new AMSOIL HD10W30 in my 05 PSD but just can't cough up the $35/gallon for it.
You are guaranteed to have a better running, overall longer lasting truck by deleting it! Thats the best thing you can do to a diesel, just watch that POS factory turbocharger on that 2014, didn't they still have the "dual" compressor wheel setup? I think the ceramic bearings were tossed in 2012 but we seen MANY of the 2011-2014 stock turbos grenaded at my last place of employment.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: claluja] #4974625 01/09/19 09:29 PM
dustyroads Offline
Thanks for the info, claluja. I hadn't thought about a tune in conjunction with the delete. I saw much improved performance from my Cat with just the improved exhaust flow. I later replaced the two standard air filters with new ones from Fleet Air (oiled up foam of some sort) and it made an amazing difference altogether. I could pull hills at low rpm and maintain lots of boost, saving fuel by not down-shifting. Free breathing engines work so much better. I miss having an older OTR truck and making modifications like that.
Back on course, I think you'll see better and better results from your samples in the future.
Re: 2014 F250 6.7L; Amsoil SS 5w-40; 8,800 miles [Re: claluja] #4985233 01/20/19 09:55 AM
B
bbslider001 Offline
B
Deleting....the best thing ever for your diesel. Brought to you by Death Row Diesel Inmates LOL
Byron
1999 F-350 CCLB SRW 7.3, Supertech 15w-40 protected, 300k miles
1997 F-350 CCLB DRW 7.3, SOLD
2015 Kia Soul Plus
