Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
22 registered members (bworley, CaspianM, bachman, BlakeB, ajchien, 1 invisible), 1,202 guests, and 30 spiders.
Topics305,879
Posts5,281,962
Members71,528
Gear oil again #4973074 01/08/19 10:29 AM
T
thejudges69 Offline OP
T
The local oil company has their own brand of oil they sell, proguard, I find little information about it. Their sales guy has been offering it to me, because it's house brand of course, but whenever I read any data sheets a lot of the areas for testing says "data not available." I don't see that on a big name oil, Chevron, citgo, and so on. Price comparison it is cheaper, but again, I find limited info about it. I am using their ep2 complex grease, I've only greased once with it, so can't speak of wear, it was half or better of the cost of my Chevron ep2. And if I don't like it, I'll give it to the neighbor for fifth wheel grease.
Little price point on the gear oils.
He's quoted me citgo 75w90 at 450.00 for 120lb keg
And 565.00 for a 120 kegnof mystik sx7000 75w90
And I believe Chevron is over 600 for the 75w90
I'll update with the cost of the 75w90 proguard, he didn't have it when I talked to him.
Is it normal for a lot of test data not to be displayed? Also, how do I find additives and other information on oils?
Here is a link to all their house products, Lyden oil is the dealer.
http://www.proguardoil.com/proguard/Safety.aspx
Re: Gear oil again [Re: thejudges69] #4973075 01/08/19 10:37 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Youre looking at SDS...
http://www.proguardoil.com/proguard...-PROGUARD%20Syn%20Auto%20Gear%20Oils.pdf
Seems to have as much info as any major oil company gives...
Try this link...
http://www.proguardoil.com/proguard/Product.aspx
Re: Gear oil again [Re: JHZR2] #4973083 01/08/19 10:52 AM
T
T
Try this link...
Thanks. I always thought sds was more of a hazmat thing.
Re: Gear oil again [Re: thejudges69] #4973088 01/08/19 10:54 AM
T
T
Is there an article or link on here I can read up on for the breakdown of the sds? I can compare numbers to other brands, but I'd like to know what I'm comparing.
Re: Gear oil again [Re: thejudges69] #4973094 01/08/19 10:58 AM
Donald Offline
As a customer (not a shop owner), given that you only use a few QTs of gear oil and do not change it very often I would always prefer to have the mechanic use a high quality gear oil.
2015 Ford F-250 w/Powerstroke
Re: Gear oil again [Re: thejudges69] #4973095 01/08/19 10:59 AM
Z
zeng Offline
Z
For gear oil , in particular industrial gear oil, grade in KV @40*C is the thing to look for ...... other than OEM approvals, if it matters.
Re: Gear oil again [Re: Donald] #4973112 01/08/19 11:33 AM
T
T
I change every 250k, each rear end takes about 4 gallons and the transmission takes about 4-5 gallons.
Re: Gear oil again [Re: thejudges69] #4973115 01/08/19 11:35 AM
T
T
Has all eaton drivetrain, older ds402 rears and original 15 speed 1.7 million on the trans. 250k on the rears
Re: Gear oil again [Re: thejudges69] #4973156 01/08/19 12:24 PM
Z
zeng Offline
Z
Originally Posted by thejudges69
Has all eaton drivetrain,....................
Other than higher KV @40C, look for SAE J2360, PRF 2105E compliance and OEM approvals in Eaton/Dana/Mack/Meritor etc.
Re: Gear oil again [Re: zeng] #4973162 01/08/19 12:32 PM
T
T
This is late 80's early 90's technology. Do those compliance ratings still apply?
Re: Gear oil again [Re: thejudges69] #4973196 01/08/19 01:02 PM
K
Kamele0N Offline
K
I would ask your neighbour trucker what works out in his truck(s)... .and would use that instead smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Gear oil again [Re: thejudges69] #4973267 01/08/19 02:00 PM
P
PiperOne Offline
P
Put the Chevron in and forget about it for 500,000 miles. For the transmission...you should be using a 50 weight manual transmission oil. Both have been the recommended fluids/change intervals for a long time now and both will deliver excellent results and a touch better fuel economy. You don't need to overthink it and saving money on lubes (especially grease) in my fleet experience....never pays. Quality+extended drains = lower cpm.
More importantly......Sweet Ride!!!
HDEO in Diesel Engines. No spark plugs here.
Re: Gear oil again [Re: thejudges69] #4973495 01/08/19 07:05 PM
L
Linctex Offline
L
That's outstanding!
The last time I did regular maintenance on Eaton and Rockwell rear-ends, I was using a Schaeffer's product.
Re: Gear oil again [Re: thejudges69] #4973548 01/08/19 08:04 PM
H
hatt Offline
H
Sounds spendy if the store brand oil causes problems.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Gear oil again [Re: Kamele0N] #4973756 01/08/19 11:30 PM
T
T
They use a mystik grease that's real sticky he said. We work in 2 completely different areas of trucking. They are in the grain industry and they use a thick sticky grease to keep grain dust out. I don't get into those environments.
