Wrong Place At The Wrong Time
by Warstud - 12/15/19 08:07 PM
4.5" Angle Grinder
by TheLawnRanger - 12/15/19 07:51 PM
Cooper CS5 Ultra Touring
by Warstud - 12/15/19 07:39 PM
Highway power loss
by HyundaiAbuser - 12/15/19 07:21 PM
General truck tires
by spasm3 - 12/15/19 07:18 PM
Alternative uses for CVT fluid?
by stroo - 12/15/19 05:57 PM
CANbus mileage editor
by cwilliamsws6 - 12/15/19 05:56 PM
Fed ex
by Chris142 - 12/15/19 05:53 PM
New oil treatment from Colgin
by qball16 - 12/15/19 05:36 PM
Discount Tire Direct $80 Flash Sale
by BePrepared - 12/15/19 05:16 PM
Bleed and refill?
by cwilliamsws6 - 12/15/19 04:19 PM
Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
Honda Ridgeline ZF 9 Speed
by dakota99 - 12/15/19 12:02 PM
Selling my dump trailer
by Sunnyinhollister - 12/15/19 11:43 AM
Motorcraft 5W-20 canada
by xXF150Xx - 12/15/19 11:40 AM
Brake caliper pins
by Donald - 12/15/19 11:14 AM
Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
theman5142, 750IX, Tzam, tjl5709, stroo
70137 Registered Users
124 registered members (askani79705, 4WD, 67ZL1, alcyon, 53' Stude, 8 invisible), 1,891 guests, and 21 spiders.
Topics298,844
Posts5,142,501
Members70,137
Most Online3,589
Nov 2nd, 2019
'01 Ranger Radiator Drain Plug Head Broke #4972309 01/07/19 01:21 PM
B
benjamming Offline OP
B
What are some good options on how to remove the plastic radiator drain plug from the radiator? The head broke off. It has started leaking so needs to be removed & replaced with a new plug that I have. I assume that KD Tools 720 Extractor Kit would work well. Probably a #3 with 15/64 drill bit.
Thank you.
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972329 01/07/19 01:44 PM
Chris142 Online Content
Online Content
Heat up a screwdriver. Poke it into the broken part.remove the screwdriver and let it cool. Then use the screwdriver to unscrew it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972336 01/07/19 01:47 PM
T
Trav Offline
T
If this one also uses a plastic tank then a spiral would be your best bet, the one you linked to is generally the one you want to use for most jobs but they need to be banged in and that's the last thing you want to do with a plastic tank. Use a little pressure pushing in on the extractor as you can to start it then let the tool do the job.
This one or one similar will do.
https://www.amazon.com/Bosch-BSPE6D...&keywords=spiral+screw+extractor+set
Edit: I like Chris142 idea, try that first.
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972386 01/07/19 02:51 PM
M
MasterSolenoid Offline
M
How about applying some Silicon Grease to the Threads and Sealing Area on the replacement ?
May make it easier to remove in the future.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972488 01/07/19 05:17 PM
DuckRyder Offline
The one I just did had had a hex inside the plug when the head broke off there was enough hex left to grab it with a regular allen wrench and turn it out. Worth a look.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972494 01/07/19 05:27 PM
B
B
DuckRyder,
No dice. Not enough meat left to bite. I'll try the hot screwdriver. Plug is made from polypropylene I believe.
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972575 01/07/19 07:12 PM
B
B
Heated up a flat blade screwdriver with a propane torch for a few seconds. Jammed it into the plug for a few seconds while it smoked. Then turned CCW to remove the plug. Thanks very much Chris142!
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972698 01/07/19 09:12 PM
Online Content
Your welcome!
Re: '01 Ranger Radiator Drain Plug Head Broke [Re: benjamming] #4972953 01/08/19 05:50 AM
DuckRyder Offline
Good deal. My local Ford dealer had one in stock, which tells me we aren’t the only 2.
Robert
