Originally Posted by Eosyn
Just got back from the range, shooting my new pistol for the first time. What I experienced:
- Started to get blisters on my middle and ring finger, more so the middle finger. Either the handle is too small (using the larger adapter) or I'm holding the handle incorrectly.
- 3 jams using the Federal ammo, all while loading the magazines. The round did not make it into the chamber. I think this is operator error rather than ammo or gun.
- Double action on first Trigger pull is heavy. Subsequent trigger pulls are much easier.
- Couldn't hold pistol steady when aiming. contributing this to my excitement and nervousness.
- Thumb got sore pushing the lever while loading magazines.
Over all, not a bad experience. I'm okay with everything I listed (as they can be corrected) except for the blisters.
Here are my two targets. I think I shot about 100 rounds today (not all on the 2 targets). The other targets, I'm too ashamed to show.
You're off to a good start.
Keep in mind the pistol may have some break-in time, so don't write off all ammo just yet, wait until it gets 1000 rounds or so under its belt. (But really poorly matching ammo will be evident).
Often blisters mean a finger is interfering with the slide, which can also produce jams. But you are talking about lower fingers, so I guess that's not what is happening. Another thing that can cause soreness is if one part of the hand or finger(s) is taking most of the recoil.
To steady the pistol while aiming, push lightly forward with your strong hand, and pull lightly backwards with the other.
Some Ruger 22 magazines (Mark II, 22/25) have a button that allow you to pull down the follower, then the ammo can be top loaded in the magazine with ease. If not, there may be a "thumb buster" loading accessory you can get.
