Kohler Engine Problem
by Swagen. 04/26/19 09:33 AM
2019 L5P Duramax, Delvac 1300 15W-40
by wensteph. 04/26/19 09:05 AM
Opinions on the John Deere S240?
by glock19. 04/26/19 08:37 AM
FS: 2006 BMW Z4 M 19k mi.
by italian68. 04/26/19 08:28 AM
75w85 VS 75w90
by nicholas. 04/26/19 08:21 AM
Oil Life Monitors
by Char Baby. 04/26/19 07:58 AM
Those who do UOA, do you also do soil testing
by Donald. 04/26/19 07:20 AM
Indiana Cen-Pe-Co dealers
by backwoodsfarmer. 04/26/19 07:00 AM
AAA Pressure Washer Pumps-Comet made?
by Joeescape63. 04/26/19 03:56 AM
Viscosity Calculator predictions...
by Shannow. 04/26/19 02:22 AM
Can you use giant rubbermade as fish tank
by BossMoss. 04/26/19 01:13 AM
Tow Truck Cell Phones
by das_peikko. 04/26/19 12:25 AM
What parts to keep on hand?
by das_peikko. 04/25/19 11:30 PM
Leather / Vinyl Repair
by tom slick. 04/25/19 10:53 PM
Purolator PSL14610 C&P, 2506 miles
by blupupher. 04/25/19 10:11 PM
Filtering New Oil
by edgrrr. 04/25/19 10:10 PM
Castrol 0w40 at Wally World
by Kjmack. 04/25/19 09:59 PM
c0pperheaded, relevante, Frank9000, Swagen, Williammaurice
67914 Registered Users
112 registered members (antik, 1978elcamino, 2015_PSD, atikovi, ARCOgraphite, 13 invisible), 1,915 guests, and 31 spiders.
Topics288,085
Posts4,940,555
Members67,914
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: Mathew_Boss] #5000635
02/03/19 07:20 PM
02/03/19 07:20 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
Originally Posted by Mathew_Boss
Originally Posted by dnewton3
There is a lot of variation in the wear Fe. The other metals are low enough to not concern ourselves with and very steady; ignore them.
Regarding the Fe, the first sample was at 8ppm/1k miles; that's a bit high to be honest.
Second sample at 4ppm/1k miles.
Third sample at 3ppm/1k miles.
Is the first sample an anomaly? Don't know this particular engine well enough. More samples need to be taken. These engines (not all of them, but many of them) use that multi-displacement fuel saving concept. I am not intimately familiar with how the system works, but I presume it shuts down cylinders and somehow alters cam/valve actions. I know we've lost many cams to this design at the SO where I work. It's a known phenomenon. The reason I bring this up is because your driving patterns and behaviors will affect the wear in Fe. More steady state driving will actually make the fuel management system shut down cylinders more often. This is not unique to the 5.7L Hemis; I see clear evidence of escalated Fe in many of the Vortec GM engines that use a similar valve deactivation system. However, the Vortect engines don't seem to eat cams like the Hemis do. Some engine designs with reasonably simple architecture have very low wear rates. Both of my 4.6L 2v engines in our Grand Marquis have wear rate of Fe 1ppm/1k miles or so. But they have very simple designs that don't use any fancy tech, and therefor have reasonably steady lube system performance.
My point is that the 8ppm/1k miles is high; the others a bit more "normal" for that Hemi design. Suggesting 10k mile OCIs is not out of the question, but I'd ease up there and not jump right to it. Work you way up methodically using UOAs as your guide.
Also, the water pumps are a consumable replaced on these Hemi engines at a rate far faster than many other brands/types, IMO. But that's a side topic not related to lube AFAIK.
The first sample was a different brand of oil. Thoes amounts concerned me too but the Pennzoil has been much better.
You could try 5W30 a slightly thicker lube will likely cause your iron numbers to drop and will not affect MDS.
I thought 5W30 made the check engine light go off in 5.7L Hemis with MDS?
No it does not if this was the case no motor oil would work. Oil is an dynamic fluid meaning it is constantly changing its viscosity with tempature, time, and ect.
don't use.
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: Gasbuggy] #5000655
02/03/19 07:44 PM
02/03/19 07:44 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
[quote=Gasbuggy]Hey, FYI, I had a Vendor on the ChargerForums, who makes and sells a custom oil for these MDS Hemi's correct me on the Charger forum. (I just bought a 2010 Charger Pursuit with the 5.7)
For anyone thinking that the system is the same between the different displacement Hemi engines, this is what I was told regarding running the Pennzoil SRT 0w40 in the 5.7
"No, you need a 5w20 for bleed down in .04 seconds and also the VVT."
"The orifices on the 5.7L MDS are different than the 6.4L Hemi MDS orifices and therefore will function differently. One for the 5.7L (5w20) and 0w40 for the 6.4L The thickest we were able to provide on the 5.7L Hemi is 7.5w25 but still had intermittent functionality so we backed it down to 7.5w23 and that functions great in the 5.7L Hemi V8. We have provided oil for these engines well over 14,000 of them with Jed's OCD being one of them both non-eagle and eagle. We kept it the same on the Eagle engine like what you have when they added Variable Valve Timing."[quote]
I do not know what your point because everything here is non-sense.
don't use.
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: SteveSRT8] #5000708
02/03/19 08:40 PM
02/03/19 08:40 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
Originally Posted by SteveSRT8
Brian has a lot of info, but as far as functionality we Hemi owners have been dancing on this issue since 04. He makes excellent oil in bizarre grades that really holds up per real world analysis. But I know hemis with 200k miles on them running 40w oils. I also own 2. There are only the most insignificant variations in MDS performance from most oils. It simply is not an issue that will ever be noticed unless you analyze things to the 4th decimal place like Brian does.
The real world facts are that new gen Hemis run great on almost any oil.
He may make excellent oils (I've never heard of the guy) but making up grades drives me nuts. There are standard grades that cover the ranges of viscosity, making up your own to slot in between the real ones to sound unique is simply silly. Like how do you even qualify a 7.5W? There's only a 5C test difference between 5W-xx and 10W-xx and the ranges are relatively generous shrug
Anyways, the "orifice" point sounds like complete BS. If that were the case, then when the oil was cold, MDS wouldn't work and neither would VCT as that 0.04 second figure is static and viscosity isn't. Since we know that's not the case, that casts a serious cloud of doubt on the validity of everything presented.
It's quite easy to use a visc calc to see how little difference in oil temp is required for a 5w-20 to be the same operating viscosity as a 0w-40. The programming is definitely different between the 0w-40 spec engines and the 5w-20 spec ones, but again, that's just software. Anyone participating in burla's Redline saga is already running a MUCH heavier lubricant, as Redline's 5w-30 has the same HTHS as most 0w-40's and is close to an xW-40 on the KV100 too. I'm guessing none of those guys are complaining their MDS isn't working nor their VCT.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: OVERKILL] #5000863
02/04/19 12:31 AM
02/04/19 12:31 AM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
I read MDS doesn't come on until oil temp sensor sees 120 degrees...
5.7s can throw a code stating incorrect oil, internet is littered with people getting this code. P1521
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 5w30 Euro L
LR Series III 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 PP
10 Charger Pursuit 5.7L
95 Accord - 386k. Mobil 2 RIP
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: OVERKILL] #5000932
02/04/19 07:11 AM
02/04/19 07:11 AM
Nebraska
Mathew_Boss Offline OP
Nebraska
I also have a Charger with a Pentastar. I would love to buy 5W30 for both and not have to use two different viscosity oils. Say the engine light does come one. Is there any harm in finishing the OIC before switching back? I don't know I'm brave enough to risk it. I though my wear numbers got much better with making the switch to PPHM (Last 2) over VFSHM (First sample)
125k Mile 11 Dodge Durango 5.7L Hemi PP HM or QSUD 5w20 or 0w20 w/Purolator Boss or Wix XP
40k Mile 2015 Dodge Charger 3.6L Pentastar Pennzoil Platinum or QSUD 0/5W20, or 5W30
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: Gasbuggy] #5000974
02/04/19 08:24 AM
02/04/19 08:24 AM
Ontario, Canada
Ontario, Canada
120F? That's still only 48C, there's a huge visc difference (look at 40C and 100C visc on a PDS) between that and operating temperature. I will check to see when the MDS kicks on in my 6.4L this AM and report back though smile
Yes, 5.7's CAN throw a code, I noted earlier that user Clevy was able to get his Charger to do it when it was -35C, but otherwise, couldn't. He was running 0w-40. As I said, the programming is different between the two engines. That doesn't mean that the hardware is.
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: Mathew_Boss] #5001058
02/04/19 10:34 AM
02/04/19 10:34 AM
Ontario, Canada
Ontario, Canada
It would appear my MDS started working at 32C (90F) oil temp, though it is harder to tell when it kicks on when it is warm. When the mornings are quite cold it is extremely obvious when it kicks in, likely due to the oil being much thicker. I'll verify the temperature again later this week when we get another cold spell.
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: Mathew_Boss] #5001710
02/05/19 04:00 AM
02/05/19 04:00 AM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
Looks like some joined to troll the oil blender a bit on the charger forum. I know it was said that the lifters are all the same for the MDS in the 5.7, 6.1, 6.4 but perhaps this is only because Mopar back spec'd new parts? Similar to how any LS engine specs LS7 lifters now. There may be some truth to suggestions of differences. One thing is for sure, regardless of variables, cams are being dined on by these lifters. GM has the same issues with their AFM.
Below in this article is where I saw the parameters for MDS to kick in.
Posted 10/12/2009
By Greg Montero
In 2005, the Multiple Displacement System (MDS) version of the 5.7L HEMI engine was introduced on the Chrysler 300C and Dodge Magnum. This engine can deactivate four of the eight cylinders, and operate as a 4-cylinder engine during periods of low load, improving fuel economy and emissions. The MDS provides the 5.7L engine the fuel economy of a V6 while maintaining the performance of a V8. The fuel economy improvement is estimated to be up to 20 percent, depending on driving conditions. The MDS operation, invisible to the driver, is fully integrated into the fuel injection system.
"In 2005, the Multiple Displacement System (MDS) version of the 5.7L HEMI engine was introduced on the Chrysler 300C and Dodge Magnum. This engine can deactivate four of the eight cylinders, and operate as a 4-cylinder engine during periods of low load, improving fuel economy and emissions.”
When the MDS engine switches to 4-cylinder mode, the powertrain control module (PCM) controls solenoids that manage special "dual mode" lifters, allowing the intake and exhaust valves to remain closed on cylinders 1, 4, 6 and 7. There is one solenoid for each cylinder (two lifters). The PCM also deactivates the fuel injectors for these cylinders when in the 4-cylinder mode.
When the MDS solenoids are in the "off" state (8-cylinder mode), they supply oil pressure of approximately 3 psi to the lifter bores. This lifter oil keeps the bores lubricated and prevents air from entering the system. When the solenoids are activated, oil pressure of 16 psi or greater is supplied to the lifters and the engine enters the 4-cylinder mode.
When the special lifters are supplied high oil pressure by the solenoid, pins inside the lifter move inward. This unlocks the outer portion of the lifter and allows it to move independently from the center portion of the lifter. The camshaft can move the outer portion of the lifter without transferring motion to the inner portion of the lifter.
8-cylinder mode: Solenoids are in the "off" state (de-energized). Minimal oil pressure is applied to the special lifter. They are working normally in this mode.
4-cylinder mode: Solenoids are in the "on" state (energized). High oil pressure is applied to the special lifters and the lifters become inactive and essentially the four pistons are along for the ride. Both valves are closed.
The PCM will activate the 4-cylinder mode when the following enabling conditions are met:
Low engine load
1200 to 3000 rpm
Vehicle speed between 12 mph and 90 mph
Battery voltage from 9 volts to 15 volts
Oil pressure from 15 psi to 147 psi
Oil temperature greater than 120 F
Engine coolant temperature from 158 to 248 F
Ambient temperature from 14 F to 248 F
No throttle position sensor or MDS faults
The PCM deactivates solenoids one cylinder at a time in the firing order. If the system is "on" for long periods of time, such as a long flat road with no stopping, the system will return to the 8-cylinder mode approximately every six minutes to maintain engine temperature. The PCM will also unlock the torque converter before the transition, to minimize the effect on driveability.
The oil temperature sensor used for this system is a two-wire sensor, negative temperature coefficient, like the sensors for engine coolant temperature or intake air temperature (IAT). The PCM uses this input - along with oil pressure, load and rpm - to calculate oil viscosity and flow rate. This information is critical to MDS operation.
It's important to know this engine uses 5W-20 engine oil. If the wrong oil is used, fault code P1521 can be set, and the vehicle may show symptoms of a shudder - similar to a torque converter shudder - when the MDS system is activated and deactivated. Other symptoms may include MDS performance codes or engine misfire codes.
Before spending a lot of time with these codes, use the vehicle service history to find out what type of oil is in the engine. Because this is not always possible, the next best thing is to replace the oil (and filter) with 5W-20. This may have to be done twice to fully restore the system back to normal. Oil sludging, restricted oil passages or lifter contamination can also cause problems with this system.
Quick facts:
Each MDS solenoid has about 12 ohms of resistance. When the solenoid is activated by applying 12 volts to it, an audible "click" can be heard from under the intake manifold. This test can be done with a jumper wire or by using the actuator test mode (ATM) mode of a compatible scan tool.
If the solenoid is mechanically stuck in the "on" position, the result will be one dead cylinder.
Hopefully, this information will be helpful if one of these systems shows up in your shop."
76' 300D Edge 0w40
02 Yukon 10w30 PP
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: Gasbuggy] #5001758
02/05/19 08:11 AM
02/05/19 08:11 AM
Ontario, Canada
Ontario, Canada
That's really unfortunately that folks have gone after the blender. Regardless of my opinion on the information presented in this thread, I still think that's pretty low frown
Thank you for the quote! I am going to guess that either the 6.4L operating parameters are different or Chrysler has updated the system since 2009 when the article was authored. I say that because I've observed MDS operate:
- When the oil temp was below 120F
- When the ambient temp was below 14F, which has been the case several times in the last few weeks and the system still kicks in (and is noticeable when it is that cold as I noted earlier) not far from my house on my way to work.
Re: 11 Dodge Durango 5.7 5k Oil 131k Unit [Re: OVERKILL] #5002474
02/05/19 09:54 PM
02/05/19 09:54 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
The tempature explains a lot because I could not have the engine throw a code. I don't get temps around here that low. If it is 40F folks around here get parkas and scarfs out of the attic. You should have seen the poor guy from Morelos he broke out the Artic cold weather gear because it was 36F at 5AM.
don't use.
Page 2 of 2 1 2
