Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
94 registered members (3311, arowbat, avi1777, aquariuscsm, ARB1977, Alfred_B, 10 invisible), 1,705 guests, and 49 spiders.
Topics286,112
Posts4,902,785
Members67,565
Most Online2,967
Mar 10th, 2019
Pennzoil Ultra, 22k miles, 2002 Camaro Z28 #4970025
01/04/19 08:31 PM
01/04/19 08:31 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
This UOA has been almost 3 years in the making.
Once the Camaro reached the point where it would use a whole quart of oil in a 30-minute lapping session, I decided to retire it from track use, as of October 2016.
But it still runs fine on the street, so I put it on the "perpetual oil change" regimen, to use up the 3 gallons of SN Pennzoil Ultra I had stashed. I changed the filter at 260k.
Polaris Comments:
Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor
equipment and fluid conditions. BEARING/BUSHING METAL is at a MODERATE LEVEL: Base Number is MODERATELY LOW. As
Base Number depletes, the ability to neutralize acids is diminished. OXIDATION is at a MODERATE level, which may be due to
extended drain interval or high operating temperature. FLAGGED ADDITIVE levels indicate slight LUBE MIXING; Lubricant and
filter change acknowledged.
Overall, I think I ran it too long based on the high corrected Iron level, and low TBN. I now have VML 5w30 in it, and will do 10k-mile OCI's and see how it likes it.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970031
01/04/19 08:50 PM
01/04/19 08:50 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
From Aug 2014 to Dec 2018 - This is one sump fill, that lasted 4+ years and 52,000 miles?
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970034
01/04/19 08:58 PM
01/04/19 08:58 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
So if I read this right, the filter went 42K miles and a fresh quart of oil (from blow by) was added every 3700 mi over the past 52K miles?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970063
01/04/19 09:40 PM
01/04/19 09:40 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
No. I stopped doing UOA's after Aug '14, but did not stop doing oil changes. The last oil change was March, 2016.
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970067
01/04/19 09:45 PM
01/04/19 09:45 PM
A Warm place to live in
berniedd Offline
berniedd  Offline
In Feb2013 to July 2013, you ran only 2000 miles, you had to add 2 quarts of oil, and yet the the iron, aluminum, lead and tin skyrocketed while the TBN took a dive. Why is this?
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: berniedd] #4970082
01/04/19 09:58 PM
01/04/19 09:58 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
The car was sitting outside my mechanic's shop for 3 months waiting for him to rebuild the transmission. He left the exhaust system open, and I assumed this allowed a couple of cylinder bores to rust. If you go back to my posted UOA at the time, there is discussion on it.
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970189
01/05/19 12:35 AM
01/05/19 12:35 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
I think that you are being a bit harsh on this analysis.
Remember, that the oil starts off with zero PPM iron, so the quart lost in the first interval contains nearly none...
I've thrown together a couple of curves to demonstrate...1,500 mile intervals got me closest to 14 quart makeup with simple math. Adjusted the "iron per interval" to get it close(ish) to your end.
First curve is oil consumption similar to yours...funny, how linear wear rate with oil consumption (and make-up) "appears" to wear more in the first interval, then get better...hmmm...
Second curve is straight linear, no consumption, indicating that your corrected value as a straight multiplier is overly pessimistic by around 15%...
Because sometimes the simple things in life...
...simply don't know any better
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970197
01/05/19 12:47 AM
01/05/19 12:47 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Part two of my thought bubble hinges on the two P.U. fills being from similarly sourced oil.
If the oil transport to the exhaust (loss) is all droplets, through the PCV, then the above curves hold...the transport oil will be carrying whatever the level of contaminants in the sump is at the same ration.
Papers seem to indicate that in the ring belt, the volatiles make it into the chamber, leaving more highly additised oil remaining in the drain back oil.
IF your two P.U. fills were from similar batches in time (stash), the concentration of the additive elements increasing over time would indicate that considerable of the transport mechanism is in the ring belt...thus the concentration factors both in my oil consumption curve, and your straight multiplier are also excessively negative.
In short, I think that your rig is good for perpetual oil changes, with 10k filter changes.
Please, at 10k, pull a sample, and not the oil, and decide to move on from there.
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: Shannow] #4970208
01/05/19 01:21 AM
01/05/19 01:21 AM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted by Shannow
... Papers seem to indicate that in the ring belt, the volatiles make it into the chamber, leaving more highly additised oil remaining in the drain back oil. ...
Might that separation effect be less significant in an engine consuming oil so rapidly? (... assuming those papers were about less severely worn engines)
2011 Toyota Prius now at 97K
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: Shannow] #4970534
01/05/19 02:09 PM
01/05/19 02:09 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
Good stuff!
An adjustment to the first graph would be the sump volume in the Camaro is 5.5 qts, so the cumulative Iron concentration would be:
Which puts the concentration at the end of interval even closer to 51.
Then goal-seeking the Iron concentration rate to get exactly 51 gives 9.75 ppm.
This makes the wear rate 6.5 ppm/kmile, which is pretty high.
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970543
01/05/19 02:19 PM
01/05/19 02:19 PM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
That's awesome!
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 5w30 Euro L
LR Series III 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 PP
10 Charger Pursuit 5.7L
95 Accord - 386k. Mobil 2 RIP
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970556
01/05/19 02:45 PM
01/05/19 02:45 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
I would love to see the inside of your Ultra, if you still have it, to see how the media did (blinded off or not?).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4970575
01/05/19 03:09 PM
01/05/19 03:09 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
It's really cool that your 4th gen LS1 is still chugging along at that mileage! thumbsup
My '00 Z28 finally dropped a lifter @ ~235K (HARD!) miles, and, as you know, once those needle bearings, and other lifter bits circulate in the sump, it is basically a FULL rebuild, since the heads have to come off anyway for even the lifters to be changed out.
Since I did not have access to either the tools, nor the facilities necessary to do this (and I was getting quotes of upwards of $10K to do the full job, even with a used stock LS1), I sold it as it was (and YES, I DID inform the buyer, and he could hear the clacking from a block away anyway wink ), and bought the little rally rocket in my sig instead. drive
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: dailydriver] #4970664
01/05/19 04:37 PM
01/05/19 04:37 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
When the oil consumption went up a few years ago, I wanted to do an LS3 swap and keep tracking it. But underbody rust from 16 Michigan winters is making me think twice about that.
It can probably go for a few more years in daily driver service. I hope you haven't jinxed it by pointing out how yours failed! wink
Re: Pennzoil Ultra, 22k miles, 2002 Camaro Z28 [Re: A_Harman] #4974334
01/09/19 03:55 PM
01/09/19 03:55 PM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
I'm amazed to see that era LS1 still alive especially being beat on! lol I had many friends in my younger years with those fancy LS1 cars trying to outrun my mustangs, they were faster on the strip but never lasted much past 50k miles. They burnt tons of oil and smoked all the time, while my lowly little 302 and 4.6 motors took a beating every weekend at the track and still didn't use a drop of oil.
It was always a fun rivalry, I had one friend with a factory "freak" 02 Camaro M6 car that would run 12's in stock trim. He was a demon on the shifter but man that thing was fast. I think that motor made it to just shy of 30k miles before it blew up!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
