Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
81 registered members (64bawagon, 2015_PSD, Alfred_B, 2004tdigls, 1foxracing, 2009Edge, 7 invisible), 1,411 guests, and 60 spiders.
Topics286,109
Posts4,902,745
Members67,563
Most Online2,967
Mar 10th, 2019
UOA places #4948706
12/11/18 01:31 AM
12/11/18 01:31 AM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
Which place gives you the most data? From what I've read, TBN and TAN are extra!
What other data is good to have that's not part of standard test?
I did a search and Blackstone and Polaris comes up but that's from 2013.
I have a sample from a gdi engine (10Wx30 M1 EP - 7413 miles) and curious to see if it had more life. Jug says 15K miles and OM says 7500 miles ...
Oil color was very dark brown after 7413 miles.
Do I need to get standard test plus tan, tbn, nitration, oxidation, What else?
Most likely I am going to do this only once and don't mind if I have to pay a little extra to get more useful data!
Thanks
Re: UOA places [Re: OilUzer] #4948749
12/11/18 06:38 AM
12/11/18 06:38 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Thanks
Couple of things here.
First, the color means nothing.
Second, the manufacturer interval for change is irrelevant if you're seeking extended drains. It's just the stepping off point.
Third one single UOA isn't really enough to have any trending data for extended use.
When I'm seeking an extended drain I sneak up on my target mileage a few thousand miles at a time, or increase the intervals until the data says to stop, whichever suits my goal. This requires multiple analyses not a single data point.
To that end you'd be best served with an inexpensive Wix kit ($9) with analysis by ALS Labs that includes TBN, versus a Blackstone kit at $35 that contains the same basic information. You can now get 3.5 samples for the price of one.
If you're really hoping to get to 15k OCI, take samples along the way, let the data talk, keep emotions out of it and share your data.
Finally this probably isn't the answer you wanted, but in reality you shouldn't jump from 7500 to 15k based off one UOA no matter how many things it measures.
Luke
Re: UOA places [Re: FlyNavyP3] #4948762
12/11/18 07:24 AM
12/11/18 07:24 AM
Lancaster County PA
diyjake Online content
diyjake  Online Content
Lancaster County PA
Where do you get this kit? $9 does that include the kit and the test or just the kit?
Re: UOA places [Re: diyjake] #4948766
12/11/18 07:32 AM
12/11/18 07:32 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Wix 24077, purchase from RockAuto.
Price includes the sample kit analysis and TBN, everything but the postage.
Luke
Re: UOA places [Re: OilUzer] #4948770
12/11/18 07:36 AM
12/11/18 07:36 AM
Lancaster County PA
Lancaster County PA
Thank you!
Re: UOA places [Re: OilUzer] #4948776
12/11/18 07:53 AM
12/11/18 07:53 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Thanks
NAPA is about the best deal out there. $16 and it includes TBN. Polaris is also good but only reasonable if you by a 10 pack of their tests. I would forget about Blackstone. OAI is a private label of Polaris sold by Amsoil.
2015 Ford F250 w/Powerstroke
Re: UOA places [Re: OilUzer] #4948827
12/11/18 09:19 AM
12/11/18 09:19 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
NAPA is the same kit sold as a WIX kit on rock, but Rock ie cheaper, includes TBN.
Luke
Re: UOA places [Re: OilUzer] #4949082
12/11/18 03:11 PM
12/11/18 03:11 PM
Upstate NY
Upstate NY
Thanks
You realize that some values are really only valid when trending. So a single UOA will be of limited value.
Re: UOA places [Re: OilUzer] #4949093
12/11/18 03:21 PM
12/11/18 03:21 PM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
If it's in the $9 or $16 range, I may do more uoa as suggested! shocked2
I was thinking it will be up in the $40+ range and with that price, I would rather changing the oil instead than getting uoa every time! The car is not that fancy! grin2
are the quality/accuracy of the less expensive tests as good?
Also what about oxidation/nitration? Does it come with these tests or is it good to have?
Re: UOA places [Re: OilUzer] #4969369
01/04/19 03:38 AM
01/04/19 03:38 AM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
So I'm going to do a uoa.
Since I won't understand the results, i will post it here but I rather not to hear you should have got this or that ...
does the basic test plus oxidation, nitration, tbn and tan cover everything needed?
The only thing I care about is how much life is left. that's all.
Don't care about trend, etc.
Thanks
Re: UOA places [Re: OilUzer] #4969440
01/04/19 07:26 AM
01/04/19 07:26 AM
The land of USA-made Subies!
SubieRubyRoo Offline
I'm getting some samples done by TestOil in Ohio here pretty soon; I have never had one of their reports but I want to see what they look like and how thorough the test is, and what a basic test includes. I'll post the first ones up in the VOA section, then make a special note in my UOA what lab it was done at.
The $9 test mentioned by Luke sounds pretty sweet.
