The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
25 registered members (c502cid, dishdude, carlprop, csandste, Blkstanger, 3 invisible), 740 guests, and 56 spiders.
Topics286,320
Posts4,906,408
Members67,597
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Porsche "Wet Mode" to Reduce Hydroplaning #4968666
01/03/19 11:53 AM
01/03/19 11:53 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
https://www.autonews.com/blogs/porsche-hopes-new-wet-mode-will-solve-911s-hydroplaning-problem
Quote
..."People drive too fast in the rain and are not aware of how close they are to the aquaplaning threshold," Morbitzer said, adding this was especially true for 911 customers......The best solution was to simply reduce speed and switch to the slow lane, but Porsche 911 drivers are not accustomed to this ...
...All new 911s will now come standard with a new safety system. Miniature microphone sensors analyze indirectly the intensity of the water on the road splashed up into the front wheel arches. Depending on the current speed, the vehicle can recommend the driver to activate the so-called "wet mode."
If activated, the vehicle starts to prepare itself for potential hydroplaning. Engine torque buildup is reduced, its distribution biased to the smaller front wheels for greater stability, and aero flaps open to create greater downforce. Actuating systems for safety features like Porsche stability management (PSM) and Porsche traction management (PTM) are lowered...
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968676
01/03/19 12:09 PM
01/03/19 12:09 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
Less expensive models can be equipped with a Mother-in-law feature that is prompted to scream: "Slow Down you Idiot !!"
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968677
01/03/19 12:09 PM
01/03/19 12:09 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
This tells me that Porsche is seeing a shift in the type of buyer for the 911. It's a buyer who's more interested in the panache of owning a 911 rather than actual driving of one.
hide
435i
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: BMWTurboDzl] #4968680
01/03/19 12:12 PM
01/03/19 12:12 PM
PimTac Offline
PimTac  Offline
hide
I think that same analogy can be applied to all the luxury brands.
Cannot see signatures any longer so it doesn’t matter.
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968683
01/03/19 12:15 PM
01/03/19 12:15 PM
PA
d00df00d Offline
d00df00d  Offline
PA
Intredasting!
2008 BMW M3 Sedan 6MT
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968688
01/03/19 12:19 PM
01/03/19 12:19 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
In other news a Porsche was passed by a Prius in a Thunderstorm...
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968693
01/03/19 12:24 PM
01/03/19 12:24 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Another solution in search of a problem, introduced by german engineers with idle hands.
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968707
01/03/19 12:44 PM
01/03/19 12:44 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968715
01/03/19 12:54 PM
01/03/19 12:54 PM
PimTac Offline
PimTac  Offline
My first thought on this was that it is a variation of a modern awd system used for this purpose but reading the article it is based on sound sensors in the wheel wells. The resulting effect is similar though.
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968720
01/03/19 12:57 PM
01/03/19 12:57 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
AWD+large, low profile, likely summer tires+non-dry conditions+add a dash of driver stupidity=crash!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: MONKEYMAN] #4968723
01/03/19 01:00 PM
01/03/19 01:00 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Nothing more fun than being next to a Porsche or other “HP” car in a snowstorm-as long as they don’t go sideways and hit you! Fortunately nanny traction control usually stops them (usually literally).
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: BMWTurboDzl] #4968757
01/03/19 01:38 PM
01/03/19 01:38 PM
PA
d00df00d Offline
d00df00d  Offline
PA
hide
1. Pretty sure panache has been more important than driving for a long time now.
2. It says what the shift was in the article: wider tires, more focus on dry performance.
This isn't about panache winning over driving. It's about people wanting bigger numbers rather than that make actual sense in the real world.
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968761
01/03/19 01:41 PM
01/03/19 01:41 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Another unneccesary safety device that will only raise insurance rates and increase repairs. All of this overengineering now is getting ridiculous.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: SubLGT] #4968770
01/03/19 01:58 PM
01/03/19 01:58 PM
PA
d00df00d Offline
d00df00d  Offline
PA
Guys.
You all know this is a selectable mode, right?
Like... It's not a thing that's always on and impossible to defeat. It's a light that comes on sometimes, does literally nothing else unless you press the button, and then stops doing things the moment you press the button again.
I agree it shouldn't be necessary but you guys are whining like it's a horseman of the automotive apocalypse. Calm down.
Re: Porsche "Wet Mode" to Reduce Hydroplaning [Re: Audios] #4968771
01/03/19 01:58 PM
01/03/19 01:58 PM
Michigan
khittner Offline
khittner  Offline
Michigan
What will an aftermarket fender-well rain sensor cost at RockAuto?
Page 1 of 4 1 2 3 4
