After reading a few threads with discussion about cleaning barrels, I'm still unclear as to which, if either is better... I see some take the stance of clean every time you're done shooting, to bore snaking after x or xx shots and I've seen remarks about practically never cleaning them. It doesn't seem exclusive to low velocity rimfires either.
I'd like to know if there is actual data or proof that any of the above mentioned approaches is better than the others. Also if a barrel is seldom or never cleaned, does that open the door to corrosion/rust? I understand that in severe climates such as extreme humidity, salt spray and so on, rust will no doubt be serious concern. But what about those that live in more hospitable conditions with an average guy who shoots every month or two with some hunting thrown in for good measure?
I know some barn burning rounds will leave copper fouling behind and lead bullets in certain types of rifling or higher pressure/velocity loads will lead a barrel which need tending to to prevent overpressure issues, but I'm mainly referring to typical rounds like .22LR, .223, .300BLK, 7.62x39, .308 and so on.
I like the idea of doing nothing (so to speak) to improve my accuracy but wonder what can be expected (both good and bad) at the range.
