My Wife is the primary driver of a 2008 Impala LT. For whatever reason, she's a little heavy on her brakes, and we have issues with her rotors warping.
She's currently using a set of Raybestos semi metallic pads which aren't over impressive in braking performance, and they produce an unbelievable amount of dust.
I want to migrate over to Bosch pads; my choices are ceramic pads, or severe duty pads which are metallic. I prefer the ceramic pads as they produce less dust.
The car weighs around 3,700 pounds; the brake setup is 4 wheel disk. Do y'all think that I can go with the ceramic pads? Also, is there any difference in the pad's ability to dissipate temperature, between metallic or ceramic, or is this a non issue?
Thanks for your time
