2006 Nissan Pathfinder with the rear heat and AC...this issue seems to be very common.
while changing valve cover gaskets, I saw where my heater hose connector has snapped off from the fitting on the firewall. It has two lines going to the rear of the car. I dug out the piece in the hose.
anyone else have this and found a quick way to fix instead of buying the $300 assembly from Nissan? I need a plastic hose piece that can go into the fitting about 3mm and then have a barbed hose fitting for the heater hose. Thinking of using some JB Weld to hold it.
Thanks
Thanks
