Cool info on the Corvette
by mcrn. 07/20/19 05:55 AM
Your preferred syn or conv oil
by NavyVet88. 07/20/19 05:03 AM
Bruce Crower Passes
by 02SE. 07/20/19 12:30 AM
Toyota YZZA1 Filter, 9,958mls
by edyvw. 07/20/19 12:06 AM
Chevron Supreme 5w30 Noack?
by Whammo. 07/19/19 11:56 PM
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT
by Earls1st. 07/19/19 11:32 PM
Which 0W20 to slow use
by lukejo. 07/19/19 11:09 PM
2012 Camry suspension question
by lukejo. 07/19/19 11:03 PM
Opinions on manufactured homes
by ram_man. 07/19/19 10:50 PM
NGK Ruthenium HX
by David1. 07/19/19 10:21 PM
Royal Purple Filter Mileage Rating
by JerryBob. 07/19/19 09:53 PM
what brand of filter is this?
by ctwhitechin. 07/19/19 09:45 PM
VW Amorak truck
by AZjeff. 07/19/19 09:25 PM
New Honda Super Cub - leaking oil
by Lawn_Care. 07/19/19 08:55 PM
Loc-n-lube
by rideon. 07/19/19 07:54 PM
Humidity thread follow-up... phew!
by 14Accent. 07/19/19 06:55 PM
Stonehunter, ctwhitechin, gwandless, Philippe1988, ChiefDaBooty
68712 Registered Users
60 registered members (andyd, 2009Edge, 87sammy, 97K15004WD, 2015_PSD, AlienBug, 5 invisible), 1,345 guests, and 23 spiders.
Topics292,124
Posts5,017,259
Members68,712
Most Online2,967
Mar 10th, 2019
More Subaru mouse issues #4965482
12/30/18 05:31 PM
12/30/18 05:31 PM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
Ok, in the Subaru Forester I have an electronic Mouse Blocker Pro under the hood, a balsam bag near glove compartment, and another in the spare tire area. New mouse nest about 12" from the balsam bag in the spare tire area.
I think my cat being 12 or so has past his prime being a mouser.
Maybe a ferrel cat?
Re: More Subaru mouse issues [Re: Donald] #4965487
12/30/18 05:43 PM
12/30/18 05:43 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
I have lots of rodent trouble here. I have found that if I move the cars every day they don't move in. I also put out sticky traps in my garage, under the cars.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: More Subaru mouse issues [Re: Donald] #4965491
12/30/18 05:47 PM
12/30/18 05:47 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
My aunt has to park her Crosstrek with the hood open, no issues since she started that.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: More Subaru mouse issues [Re: Donald] #4965501
12/30/18 05:58 PM
12/30/18 05:58 PM
Alberta
carviewsonic Offline
Alberta
I put a couple of traps in each garage along the walls baited with peanut butter, and also a trap under the front bumper of my daughter's car which has a parking spot outside. In the garages I catch maybe a couple mice per year, but about a dozen mice per year under my daughter's car. I started doing this years ago after mice got into my son's car and made nest in the glove box. I've been using the same plastic traps for years, they don't crush the mouse and are easy to empty and re-use.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: More Subaru mouse issues [Re: Donald] #4965554
12/30/18 07:16 PM
12/30/18 07:16 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Set more traps.
Re: More Subaru mouse issues [Re: Donald] #4965602
12/30/18 08:14 PM
12/30/18 08:14 PM
NY
fcjeep Offline
fcjeep  Offline
NY
"Repels-All" spray bottle.
https://www.homedepot.com/p/Bonide-32-oz-Repels-All-Ready-to-Use-Repellent-238/202022320
This works like a charm for me for raccoons around my garbage cans. Sprayed around my GC when it was laid up in the street for a few months earlier this year and never had any issues.
Wear gloves and hold your breath....it stinks something awful.
2006 Jeep GC 4.7L, Died @ 153059 mi frown
2008 Xterra 4.0L, 104500 mi
2016 Jeep GC 3.6L, 19100 mi
2017 Benz C300 14000 mi
Re: More Subaru mouse issues [Re: Donald] #4965781
12/30/18 11:31 PM
12/30/18 11:31 PM
Northeast
sxg6 Offline
sxg6  Offline
Northeast
Inside the spare tire area? Are you missing a plastic or rubber plug that goes in the spare tire area?
Re: More Subaru mouse issues [Re: carviewsonic] #4965849
12/31/18 04:41 AM
12/31/18 04:41 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
The peanut butter does work well for me too. I also put a couple small perforated plastic bags with moth balls inside, under the hood which has stopped the nesting for me. You could give it a try in the spare tire compartment.
The "thinking" man's friend.
Re: More Subaru mouse issues [Re: Donald] #4965939
12/31/18 10:01 AM
12/31/18 10:01 AM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
This is an outside always car. I will check for the rubber plug in the spare tire area.
2015 Ford F250 w/Powerstroke
Re: More Subaru mouse issues [Re: Donald] #4966051
12/31/18 12:13 PM
12/31/18 12:13 PM
PA
KalapanaBlack Offline
PA
I doubt you are missing anything. They are probably entering through the pressure equalizing flaps buried behind each side of the rear bumper. There should be a screen in there, but it'd be easy for a rodent to lift the flap and tear through the screen.
I have also seen rodents enter through rubber firewall plugs installed by the manufacturer in the unused RHD steering column hole. Once they are inside, they can burrow under the carpet in the spaces for wiring looms to run, meaning just because they are in the rear of the car doesn't mean that's where they entered.
Re: More Subaru mouse issues [Re: Donald] #4966110
12/31/18 01:09 PM
12/31/18 01:09 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Bait the traps with Slim Jim’s stuck well on the peg of the trap.. Always works where PB fails constantly.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: More Subaru mouse issues [Re: Donald] #4966452
12/31/18 08:34 PM
12/31/18 08:34 PM
Northeastern Vermont
littleant Offline
littleant  Offline
I start baiting traps with cheese mid to late fall in my garage. I get between 1-4 every day. They are looking for a place to winter. All winter i may get 3. Spring i will get 1 a day for about a week. What I have found out is the V engines are more prone to nest under hood. My jeep is straight Six and have never seen a nest anywhere. Maybe they just don't like jeeps.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: More Subaru mouse issues [Re: 2strokeNorthstar] #4966644
01/01/19 07:03 AM
01/01/19 07:03 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Mild, regular or hot?
Re: More Subaru mouse issues [Re: Donald] #4966772
01/01/19 10:14 AM
01/01/19 10:14 AM
Upstate NY
Donald Offline OP
Donald  Offline OP
Upstate NY
This is an outdoor car.
