Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
91 registered members (4WD, 28oz, anndel, 69Torino, A310, 11 invisible), 1,989 guests, and 35 spiders.
Topics296,850
Posts4,960,145
Members66,978
Most Online2,688
Jan 19th, 2019
Page 2 of 2 1 2
Re: SuperTech oil stabilizer vs Lucas [Re: spk2000] #4964160
12/29/18 09:04 AM
12/29/18 09:04 AM
Tacoma, WA, USA
Cubey Offline OP
Cubey  Offline OP
Tacoma, WA, USA
Originally Posted by spk2000
Might try straight 20W50 or if you can find a non racing 60. Have often heard the Lucas OS is a 60W base oil. Not even sure it has additives. I poured some in my car once and ran it a bit. Pulled dipstick and could see what others have said bubbly foam on dipstick so I haven't tried it since.
This CarQuest oil seems to be the only 20w50 I can find by searching online that is actually API SN/CF. Walmart's cheaper 20w50 is SN only.
https://shop.advanceautoparts.com/p...0-motor-oil-5-quart-cq650-5qt/11704770-p
But then again, being picky about CF spec is probably silly when I'm talking of dumping Lucas in.
2003 Pontiac Vibe - M1 HM 5w30/M1-103 Filter
1988 Honda Elite 250 - Honda GN4 10w40
Re: SuperTech oil stabilizer vs Lucas [Re: Cubey] #4964161
12/29/18 09:07 AM
12/29/18 09:07 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I bought a restriction guage and put it on that little nub on the air filter lid. The life of the injectors is only about 100k. After that they start weeping which kills mpg.
I bought the timing tool and have adjusted mine. It was way off. The timing does not effect mpg much. It does make a huge difference in power though.
Before I adjusted mine I could not merge on to a freeway safely. Now in going 60mph when I get to the end of the acceleration ramp.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: SuperTech oil stabilizer vs Lucas [Re: Linctex] #4964166
12/29/18 09:09 AM
12/29/18 09:09 AM
Tacoma, WA, USA
Cubey Offline OP
Cubey  Offline OP
Tacoma, WA, USA
Originally Posted by Linctex
Originally Posted by Cubey
It still gets 10 city/14-15hwy with cheap all terrain tires. It got slightly better with the mismatched, but worn out highway treads it had before. Timing is off or it might get a little better mpg, but that has nothing to do with oil consumption. .
I think your injection pump is a bit out of time, for sure.
Don't the IDI's lose a degree of timing every 40,000 miles or so?
It was retarded quite a bit from when i got it (14k ago as of right now). While towing an old 27ft travel trailer this summer, I adjusted the timing a couple times, advancing it, and it slightly improved towing power. I've since sold the trailer and I'm back to using my short truck camper. It didn't hurt the mpg but seemed to help with towing. I keep meaning to go to get to somebody to time it properly but haven't.
Re: SuperTech oil stabilizer vs Lucas [Re: Cubey] #4964316
12/29/18 12:51 PM
12/29/18 12:51 PM
Time for a road trip. Bring it here! I'll time it.
Re: SuperTech oil stabilizer vs Lucas [Re: Chris142] #4964329
12/29/18 01:01 PM
12/29/18 01:01 PM
Tacoma, WA, USA
Cubey Offline OP
Cubey  Offline OP
Tacoma, WA, USA
Over on another forum, lots of people offer free or cheap timing but it's a matter of getting there. I travel the country full time basically in the truck/tiny camper. Since it runs well, it hasn't been a huge priority.
It needs glow plugs (again) and the "olives". Cold weather (lower 30s and below) shink the olives and the glow plugs can't cope. In the 40s? It's fine. Even starting fluid barely got it going this morning. I have manual control glow plugs so I can safely use it. It starts perfectly in warmer weather or when its warmed up, so yeah.
Re: SuperTech oil stabilizer vs Lucas [Re: Cubey] #4964368
12/29/18 01:34 PM
12/29/18 01:34 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Schaffer Oil Moly EP would thicken like Lucas but actually has some additives, I would use STP over Lucas because it also has additives and not just heavy bright stock. Schaffer Moly EP isn't super expensive and available from Amazon.
Luke
Re: SuperTech oil stabilizer vs Lucas [Re: FlyNavyP3] #4964770
12/29/18 09:30 PM
12/29/18 09:30 PM
Tacoma, WA, USA
Cubey Offline OP
Cubey  Offline OP
Tacoma, WA, USA
Thanks for the suggestions. Does Scaffer or STP not foam up like Lucas supposedly does?
Then there's also MotorHoney but I don't know what it has or doesn't have.
Re: SuperTech oil stabilizer vs Lucas [Re: Cubey] #4965879
12/31/18 06:38 AM
12/31/18 06:38 AM
South Carolina (SC)
RyanY Online content
RyanY  Online Content
South Carolina (SC)
Has anyone tried Valvoline Maxlife HD oil in oil burners? I have noticed considerably reduced oil consumption in gas engines after switching to HM oil but have not owned a diesel. Of course, the cause of the burning will determine whether HM oil helps, but I would start here instead of additives. After all, it is only a few $ more than normal oil.
2007 Cadillac CTS 3.6L >117k miles (Castrol Magnatec 5W-30 + AC Delco filter)
2012 Honda Odyssey EX-L >93k miles (Pennzoil Platinum 0W-20 + Fram Ultra filter)
Re: SuperTech oil stabilizer vs Lucas [Re: RyanY] #4966099
12/31/18 11:56 AM
12/31/18 11:56 AM
Tacoma, WA, USA
Cubey Offline OP
Cubey  Offline OP
Tacoma, WA, USA
I'm probably going to be trying it. It seems to be thicker. Go check out my thread in the diesel oil board about it:
https://www.bobistheoilguy.com/foru...onew/1/any-maxlife-15w40-diesel-oil-fans
Re: SuperTech oil stabilizer vs Lucas [Re: Cubey] #4967030
01/01/19 02:31 PM
01/01/19 02:31 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
If you want thick, good, and cheap, I think Mystik JT8 15w-50 is calling your name. You'll save a little coin not buying a "stabilizer".
Re: SuperTech oil stabilizer vs Lucas [Re: Cubey] #4975532
01/10/19 07:57 PM
01/10/19 07:57 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Yeah yeah, I know there is a lot of hatred here for the product. I'm not trying to ask "should i?". I have used it previously and I'm satisfied with the results it provides.
He did provide the correct answer, though. I'd say you shouldn't use it, but that's not what you're asking. However, his answer is correct because it should be fairly trivial and very cheap for a blender to come up with a Lucas clone. Dumbing it down would be the real challenge.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: SuperTech oil stabilizer vs Lucas [Re: Garak] #4975661
01/10/19 10:49 PM
01/10/19 10:49 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
LOL
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Page 2 of 2 1 2
