High level input question
by buck91. 07/19/19 02:47 PM
Drill press vise?
by buck91. 07/19/19 02:40 PM
More filter porn to come ;)
by 53' Stude. 07/19/19 02:37 PM
Massive amounts of PEA got into my oil ???
by j_mac. 07/19/19 02:10 PM
Anyone have over 200K on their GDI or TGDI engine?
by Speak2Mountain. 07/19/19 12:55 PM
ATF to help with seeping output shaft seal
by spavel6. 07/19/19 12:39 PM
A/C Gas refill with stop leak/dye?
by stockrex. 07/19/19 12:26 PM
[pics] 2004 Corolla spark plug, piston tops
by zorobabel. 07/19/19 11:55 AM
Apple Repair
by madRiver. 07/19/19 11:54 AM
"Hiding" behind the beard?
by BMWTurboDzl. 07/19/19 11:16 AM
Which conventional oil do you use and why?
by JustN89. 07/19/19 10:14 AM
SN+ 0w-30?
by noclutch. 07/19/19 09:46 AM
Atturo Trail Blade A/T ?
by tiredguy. 07/19/19 09:18 AM
'79 IH 782 survivor
by wings&wheels. 07/19/19 08:55 AM
A REAL oil stash!!!!!
by Gixxer8989. 07/19/19 08:53 AM
Skyactiv Engines have proven to be bulletproof
by buster. 07/19/19 08:52 AM
Tacoma Crawl Control
by buster. 07/19/19 08:01 AM
Philippe1988, ChiefDaBooty, JIMBO5658, Agway, Murphhyy18
68709 Registered Users
104 registered members (4WD, 01rangerxl, 324Matt, 08z06, ammolab, 53' Stude, 14 invisible), 2,354 guests, and 19 spiders.
Topics292,088
Posts5,016,713
Members68,709
Most Online2,967
Mar 10th, 2019
Flood LED Flickers #4963908
12/28/18 10:25 PM
12/28/18 10:25 PM
northern Alabama
benjamming Offline OP
northern Alabama
Our house was new construction in 2006 with 4 Cooper model ms37 rain tight motion detector flood lights (2 bulb each setup). I've installed 3 Sylvania 74772 LED bulbs. One fixture will cause LED bulb flicker. It will do this if LEDs are installed in both sockets or if one socket is empty & the other has an LED installed. No dimmers installed just a dumb switch that operates 2 fixtures (other fixture has standard PAR38 bulbs). Another fixture (separate switch) on the back side of the house does not have this issue. It has an LED in one socket & the other is standard PAR38 bulb.
Thoughts as the issue?
Re: Flood LED Flickers [Re: benjamming] #4963937
12/28/18 11:14 PM
12/28/18 11:14 PM
New England, USA
wings&wheels Offline
New England, USA
is the motion detector made for LED's? I had the same problem with an older timer that was not made for led's. Lasted for a few years after I switched to led's, then started flickering, but still operated fine w/ incandescent. May need a newer fixture if you want led's.
This is assuming the led bulb is not the problem. Over the years, I have had a few led bulbs fail by flickering or strobing.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996 (Wife's)
'01 Porsche Boxster S (mostly Wife's...)
Piper Pa28-236
Re: Flood LED Flickers [Re: benjamming] #4963947
12/28/18 11:28 PM
12/28/18 11:28 PM
CA
spackard Offline
spackard  Offline
CA
Looks it was about $20 when new. Toss and buy another.
Even the RAB STL200, at $77, now has (only) a 10 year warranty (used to be lifetime).
Re: Flood LED Flickers [Re: benjamming] #4964033
12/29/18 04:52 AM
12/29/18 04:52 AM
Hudson valley
Oildudeny Offline
Oildudeny  Offline
Hudson valley
I have an old fixture that works fine with LEDS, did you check the fixture wiring make sure black is to black white to white. Make sure the neutral (white) wire has a good connection. LED bulbs could be more picky over the incandescent.
Re: Flood LED Flickers [Re: benjamming] #4964089
12/29/18 08:22 AM
12/29/18 08:22 AM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Many control circuits "contactors" or "relays" work via solid state components. On a basic level, the 60HZ pure sine wave is changed into something else by passing through semiconductors. It won't matter on a conventional bulb, but many LED's have drive circuitry designed to work with conventional AC power.
Re: Flood LED Flickers [Re: benjamming] #4964111
12/29/18 08:56 AM
12/29/18 08:56 AM
ME
eljefino Offline
eljefino  Offline
ME
You might see if you can put an old-school night light bulb in the other fixture socket to mask your issue.
I have the same problem and hear a relay click when the light goes on, so it's not like it's going through a MOSFET or anything, or maybe it is-- they're pretty cheap inside.
When LEDs first got cheap ~5 years ago I got some actual Cree branded ones that take 1/2 second to stop making light after I shut them off. (They were really trying to mimic incandescent quality.) They may have better rectifiers inside which would again mask your issue.
What's your target here, are you trying to save electricity? How many minutes are these lights on per day and what's the payback?
Re: Flood LED Flickers [Re: benjamming] #4964119
12/29/18 09:14 AM
12/29/18 09:14 AM
MD
ET16 Offline
ET16  Offline
MD
I had the same problem. I put in a higher wattage bulb, and it went away. It seemed that the circuit wasn't drawing enough for the switch with the lower wattage.
Re: Flood LED Flickers [Re: benjamming] #4964508
12/29/18 04:50 PM
12/29/18 04:50 PM
northern Alabama
northern Alabama
eljefino,
I'll put a regular bulb back into the one fixture where there is flickering to see if that solves the problem.
If it doesn't flicker, then that's not masking the issue but removing the issue, right?
Just wanted to try some out...
