What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
124 registered members (01rangerxl, Agnosto, 92saturnsl2, 2010Civic, ABerns, 2009Edge, 11 invisible), 2,231 guests, and 65 spiders.
Topics286,030
Posts4,901,125
Members67,549
Most Online2,967
Mar 10th, 2019
A few reports on my 2002 f250 7.3 navistar #4962545
12/27/18 12:48 PM
12/27/18 12:48 PM
Nebraska
JessMatthews Offline OP
Nebraska
I just wanted to share my reports with everyone here, I’m mostly a lurker here but thought this info could help. I have several reports which all have been with Ameriguard 10-30 oil and arch oil additive except for the second report which is Delo 10-30xle. The last report is just oil with no arch oil. I do have an oil bypass filter on this pickup, but with all reports everything stayed the same with regular filter and changing out bypass, also fuel and coolant filter. I live in country and don’t drive hardly on pavement and do some towing. Sorry it’s so long but I’d like to thank Newton for all the information on oil analysis and 10-30 in a 7.3 or 6 engine, I took the info and ran with it. Hope you enjoy thanks
Re: A few reports on my 2002 f250 7.3 navistar [Re: JessMatthews] #4962564
12/27/18 01:19 PM
12/27/18 01:19 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Shear not bad, almost no fuel in oil, TBN of 6.8-looks like 10K would be easily doable! Was this run Delo 10W30 again?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: A few reports on my 2002 f250 7.3 navistar [Re: JessMatthews] #4962593
12/27/18 02:02 PM
12/27/18 02:02 PM
Nebraska
Nebraska
This last 7500 mile run was on Ameriguard 10w/30
Re: A few reports on my 2002 f250 7.3 navistar [Re: JessMatthews] #4962712
12/27/18 04:58 PM
12/27/18 04:58 PM
TX
KJSmith Offline
KJSmith  Offline
TX
Why not run the oil the manufacturer recommends?
Re: A few reports on my 2002 f250 7.3 navistar [Re: JessMatthews] #4962735
12/27/18 05:37 PM
12/27/18 05:37 PM
wv
krismoriah72 Offline
wv
Potassium seems to be trending down...coolant in the oil?
Re: A few reports on my 2002 f250 7.3 navistar [Re: JessMatthews] #4962824
12/27/18 07:21 PM
12/27/18 07:21 PM
Nebraska
Nebraska
Potassium is from the oil additive archoil nothing to worry.
Re: A few reports on my 2002 f250 7.3 navistar [Re: JessMatthews] #4963141
12/28/18 06:58 AM
12/28/18 06:58 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Generally the Fe wear metals are staying consistent at or slightly above 2ppm/1k miles; excellent wear.
Other wear metals are so low that they are just noise; nothing to concern yourself with.
Contamination is low otherwise; no coolant or silica getting in. TBN strong.
Given mostly off-road use, the air filter is doing particularly well; don't mess with it!
The Archoil probably is doing nothing for wear, but if you feel it's helping with "stichion", that's up to you to decide if you want to continue its use or not. I don't see it hurting anything; whether it helps the injectors or not I cannot tell you. Running a BP filter element can certainly help push out the OCIs; I'd say continue a few at 10k miles, then push up in 5k increments, with UOAs along the way. As long as the wear metals stay "in control", then you're good!
Almost 200k miles on the engine; she is just now getting broke in! The ol' 7.3L is a stalwart with a strong reputation for good reason; they just run and run. Every once in a while you'll have to replace some sensors (cam position; ICP; IPR, etc), and the oil cooler o-rings and turbo pedestal o-rings will eventually need replaced, but other than that, it's just a great running engine. Most anything that has to be replaced on these engines is easily accessed externally. Just a simple engine to work on, overall. Love these engines; my son had an F250 7.3L that had 275k on it when we sold her. Engine ran great; ferrous oxide cancer was eating the body alive; they don't call this the rust belt for nothing.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
