Originally Posted by parshisa
Update: lab re-ran FD and voscocity - came back same values. Oh well, dilution it is, low wear I take. 7K or a bit more should be just about right. Amsoil is such an amazing oil, I cannot even think of any other brand that would've donw such a remarkable job
I didn't expect it to change, unless it was cubby fingers that typed a wrong digit.
I wouldn't be surprised if Walmart's Supertech gave you the same results for much cheaper.
With the fuel getting in, I wouldn't run any extended runs on high end Lube, if it was me.
With the expensive Amsoil, you pretty much have to run it long enough to make sense. I don't think this engine is a good candidate for this, regardless if the wear isn't elevated. There's just no way all this fuel in the sump isn't causing some type of wear possibly even unseen by the Lab
