I'm swapping in a used transmission on a friend's 01 Explorer XLT 4.0 V6 with 5R55E 4WD Transmission. The original transmission failed by no longer going into reverse gear. I pulled a replacement with 125k miles from a 2000 Explorer in the pull-a-part that had been in a bad wreck, so with any luck the transmission still has some life left in it. The fluid that drained out of it didn't look terrible, but probably was never changed. Planning to change out the filter when installing it.
I'm wondering what to use in the transmission and transfer case. Ford specs Mercon V in the transmission and regular Mercon in the TC, but I've had good results with Redline and Amsoil synthetics in other vehicles and would be interested in other's experience with any good synthetic substitutes. Hoping to get as much life as possible out of this replacement transmission. Thanks much
