Ford testing new vehicles
by 97prizm - 09/21/19 08:00 PM
Any stuffed pepper lovers here?
by 53' Stude - 09/21/19 06:55 PM
Shrinking Window Tint.
by George7941 - 09/21/19 05:30 PM
Drain and refill or Cooler line flush?
by jrvn - 09/21/19 05:25 PM
Federated Auto Parts 400 at Richmond Raceway
by bdcardinal - 09/21/19 04:40 PM
Stick with OEM or try aftermarket?
by Nav45 - 09/21/19 04:25 PM
Body Shop guys, what should I expect to pay?
by dwcopple - 09/21/19 03:59 PM
What Vehicle and Trailer to Tow Tractor?
by lancerplayer - 09/21/19 03:40 PM
Garage high humidity floor wet vehicle inside.
by littleant - 09/21/19 03:34 PM
[NEW] Carquest 95515 / Fits MB GLA/CLA
by SlavaB - 09/21/19 03:23 PM
KENDALL GT-1 HIGH PERFORMANCE SYN BLEND 5W-30
by OilReport99 - 09/21/19 03:02 PM
Weekend detail
by gregk24 - 09/21/19 02:32 PM
Valvoline Premium Blue 8600 ES 15W40
by 53' Stude - 09/21/19 01:20 PM
Axle shaft seal leak?
by aquariuscsm - 09/21/19 01:14 PM
Refills for Denso Designer wipers
by mclasser - 09/21/19 12:45 PM
What make steering wheel hard to turn
by Rohan - 09/21/19 12:43 PM
Z55 coil spring options
by LeakySeals - 09/21/19 12:28 PM
diy AA Solar charger?
by earlyre - 09/21/19 11:53 AM
OilReport99, TungGT, ErikLeifson, Kinnes25, Bamajoe
69348 Registered Users
95 registered members (4WD, ammolab, 2015_PSD, 928, 97prizm, 10WSmuckers, 10 invisible), 1,983 guests, and 26 spiders.
Topics294,879
Posts5,068,565
Members69,348
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959702 12/23/18 06:41 PM
bdcardinal Online Content
Online Content
Originally Posted by laserred96gt
Yes there was dye in the system, must have been the previous owner, I have owned the van since 2011 and never had a problem with the AC.
Blower motor is working, it is not blowing as hard as it used when I first bought it though.
I will check the pressures and read them next time.
Fords tend to have dye from the factory.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959925 12/23/18 10:43 PM
DONWATERS Offline
I say dirty leaf clogged evaporator core.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959942 12/23/18 10:52 PM
clinebarger Online Content
Online Content
If this van has Auxiliary A/C.....It's way undercharged at 40 ounces.
2001 Chevy Camaro L92/4L80E
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4960594 12/24/18 06:36 PM
L
laserred96gt Offline OP
L
No it is a cargo van, it only takes 40ozs, yeah what im leaning at is a partially clogged evap in combination with lower ambient temperature and weak blower motor not moving enough air across the coil. Noticed early this morning when it was colder outside that lines started freezing right away, I also noticed the problem the first cold day we had in Florida.
2017 4Runner Limited, 50k
04 E-150, 4.6, 240K, Synblend 5w20.
11 Camry 2.5, 70K, PU 5w20.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #5008521 02/12/19 06:21 AM
L
L
Sorry to bring back an old thread but found the problem to be a bad low pressure switch, hopefully this will help someone, thank Chris and everyone for their replies.
Page 2 of 2 1 2
