2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Subaru Forester with rusty brakes
by Donald - 12/14/19 12:55 PM
2017 Honda CRV, 1.5 Turbo, Mobil AFE 0W-30
by 06_lx - 12/14/19 11:48 AM
Toyota WS ATF or Aisin WS ATF
by dblshock - 12/14/19 10:28 AM
Bauer Dual Action Polisher
by TheLawnRanger - 12/14/19 10:12 AM
Questionable Tool Cart/Nice Price
by TheLawnRanger - 12/14/19 09:57 AM
Craftsman Tool Cart at Ace
by TheLawnRanger - 12/14/19 09:52 AM
Looking to buy a oscillating saw
by JLawrence08648 - 12/14/19 07:46 AM
What's your favorite handgun?
by Silverado12 - 12/14/19 07:07 AM
DOT3 or DOT 4 Brake Fluid ?
by ChrisD46 - 12/14/19 06:34 AM
nautoncall, Pluckster, DerekPho, mikinko, merrittgene
70128 Registered Users
92 registered members (-SyN-, 77GrandPrix, 2009Edge, Audios, 4WD, addyguy, 12 invisible), 1,724 guests, and 21 spiders.
Topics298,808
Posts5,141,618
Members70,128
Most Online3,589
Nov 2nd, 2019
Need a little help with AC Ford 4.6 #4958625 12/22/18 10:13 AM
L
laserred96gt Offline OP
L
The AC in my 04 E150 started acting up a couple of weeks ago, basically it runs good for about 5 minutes than suction line starts to freeze and the compressor clicks on and off constantly.
My initial thought was a restriction, I connected my gauges and pressures seem good but high side needle fluctuated rapidly. I evacuated the system, removed old orifice tube, ran nitrogen through the system, replaced the orifice tube, pulled a good vacuum and still does the same thing, what could it be??
2017 4Runner Limited, 50k
04 E-150, 4.6, 240K, Synblend 5w20.
11 Camry 2.5, 70K, PU 5w20.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958638 12/22/18 10:33 AM
Chris142 Online Content
Online Content
Jump the low pressure switch. See if it stays on. If it does what are the pressures?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958650 12/22/18 10:54 AM
M
mattd Online Content
Online Content
M
What are the pressures? Are you sure that is the correct orifice tube?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958670 12/22/18 11:26 AM
L
L
I don't remember the pressures right now but basically weighed in the the charge, 40 Oz's, the orifice tube I got at O'Reilly, looked just like the one that came out.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958675 12/22/18 11:31 AM
M
Online Content
M
The reason I ask about the orifice tube is that most fords use either a maroon or blue The reason I ask about the orifice tube is that most fourth use either a maroon or blue tube. I would look it up by application to verify. Exact pressures would be more helpful other than what it weighed in at. Have you ever added some type of stop leak to the system? The color looks strange unless you added some type of stop leak or orange dye
Is the fan operating properly?
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958696 12/22/18 11:49 AM
L
L
Yes there was dye in the system, must have been the previous owner, I have owned the van since 2011 and never had a problem with the AC.
Blower motor is working, it is not blowing as hard as it used when I first bought it though.
I will check the pressures and read them next time.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958697 12/22/18 11:50 AM
M
mk378 Offline
M
Orifice tube systems work by controlling the low side pressure to avoid freeze-up. The boiling point of R-134a varies with pressure. If the pressure is not allowed to fall below about 25 psi, the evaporator won't get cold enough to freeze.
There are two ways to do this. The simple one is to have the low side switch cycle off at 25. Thus the compressor cycles during normal operation. The more sophisticated version is a variable compressor with internal pressure control so it stops pumping below 25. In this scheme, the compressor should not normally cycle. There is a low pressure switch that turns off around 10 to protect against running the compressor in case of a total leak-out.
As others said the pressures are the way to diagnose this.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958700 12/22/18 11:54 AM
M
Online Content
M
When I said fan I mean condenser/radiator fan
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: mattd] #4958728 12/22/18 12:30 PM
L
L
There's are a couple of pictures of the pressures with the compressor on and off.
low side reads 30psi/+1
High site125psi/+15
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958740 12/22/18 12:41 PM
L
L
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958770 12/22/18 01:14 PM
M
Online Content
M
Those pressures aren’t bad the high side is on the low side are you sure the system is properly charged? What is the ambient temp? Also when you see the suction line freeze the compressor cycle off? At whatlow side pressure does that happen? If they stay at those pressures it shouldn’t cycle off. It won’t cycle off until less than 10-15psi or less on low side.
Make sure the cooling fan clutch isn’t frozen making it run all the time
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958860 12/22/18 03:45 PM
F
FSully1 Offline
F
Need ambient temp......looks under charged, if no compressor issue.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958933 12/22/18 05:24 PM
K
Kode Offline
K
I would look at some sensor as the culprit.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959008 12/22/18 07:26 PM
Colt45ws Offline
Im gonna say there isnt enough charge in it and thats why its freezing up.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959340 12/23/18 09:08 AM
W
WyrTwister Offline
W
If the evaporator blower is not moving enough air , it can affect the suction pressures . Maybe , even to the point of freezing the coil .
If the condenser blower is not moving enough air , high pressure will be too high .
Wyr
God bless
