Router died after power went out
by RhondaHonda. 04/20/19 07:08 PM
Took a ride in a 2018 Buick TourX
by Rumble. 04/20/19 06:45 PM
Solar panel with charge controller.
by spasm3. 04/20/19 06:38 PM
String trimmer line size preference?
by 92saturnsl2. 04/20/19 06:38 PM
What would you do?
by Yuk. 04/20/19 06:26 PM
Best Time For Battery Sales
by borgward. 04/20/19 05:08 PM
2006 chrysler town and country 5w30 o.k.?
by hooperswish1. 04/20/19 04:56 PM
??? Messages on Chevy 2500
by lukejo. 04/20/19 04:50 PM
Koi (carp) bait
by wings&wheels. 04/20/19 04:30 PM
More power from my weed wackers?
by Chris142. 04/20/19 04:24 PM
Is your tool chest/tool area well organized?
by ZZman. 04/20/19 03:41 PM
Mixing of vicosities
by Matt97. 04/20/19 02:56 PM
Tired Of These YouTube "Cover Bands"
by Warstud. 04/20/19 02:47 PM
Digital Torque Adapter
by LeakySeals. 04/20/19 02:12 PM
Lenovo c930 vs Asus ZenBook UX433FN
by mcrn. 04/20/19 01:34 PM
Food health standards overrated?
by BossMoss. 04/20/19 01:20 PM
Ubuntu 19.04 is out
by simple_gifts. 04/20/19 01:02 PM
Fixing microwave handle
by Donald. 04/20/19 12:55 PM
Lost an engine, rebuild, replace, scrap?
by CBR.worm. 04/20/19 12:22 PM
Tundra73, Dkouz, MichaelT1981, Rahstyle, Dlbaldwin01
67860 Registered Users
114 registered members (92saturnsl2, Alfred_B, aba4430, AMGTHIS, AdditiveOCD, 2002 Maxima SE, 6 invisible), 1,970 guests, and 23 spiders.
Topics287,798
Posts4,934,734
Members67,860
Most Online2,967
Mar 10th, 2019
Need a little help with AC Ford 4.6 #4958625
12/22/18 11:13 AM
12/22/18 11:13 AM
Florida
laserred96gt Offline OP
Florida
The AC in my 04 E150 started acting up a couple of weeks ago, basically it runs good for about 5 minutes than suction line starts to freeze and the compressor clicks on and off constantly.
My initial thought was a restriction, I connected my gauges and pressures seem good but high side needle fluctuated rapidly. I evacuated the system, removed old orifice tube, ran nitrogen through the system, replaced the orifice tube, pulled a good vacuum and still does the same thing, what could it be??
2017 4Runner Limited, 46k
04 E-150, 4.6, 235K, Synblend 5w20.
11 Camry 2.5, 66K, PU 5w20.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958638
12/22/18 11:33 AM
12/22/18 11:33 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Jump the low pressure switch. See if it stays on. If it does what are the pressures?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958650
12/22/18 11:54 AM
12/22/18 11:54 AM
RI
mattd Online content
mattd  Online Content
RI
What are the pressures? Are you sure that is the correct orifice tube?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958670
12/22/18 12:26 PM
12/22/18 12:26 PM
Florida
Florida
I don't remember the pressures right now but basically weighed in the the charge, 40 Oz's, the orifice tube I got at O'Reilly, looked just like the one that came out.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958675
12/22/18 12:31 PM
12/22/18 12:31 PM
RI
RI
The reason I ask about the orifice tube is that most fords use either a maroon or blue The reason I ask about the orifice tube is that most fourth use either a maroon or blue tube. I would look it up by application to verify. Exact pressures would be more helpful other than what it weighed in at. Have you ever added some type of stop leak to the system? The color looks strange unless you added some type of stop leak or orange dye
Is the fan operating properly?
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958696
12/22/18 12:49 PM
12/22/18 12:49 PM
Florida
Florida
Yes there was dye in the system, must have been the previous owner, I have owned the van since 2011 and never had a problem with the AC.
Blower motor is working, it is not blowing as hard as it used when I first bought it though.
I will check the pressures and read them next time.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958697
12/22/18 12:50 PM
12/22/18 12:50 PM
USA
mk378 Offline
mk378  Offline
USA
Orifice tube systems work by controlling the low side pressure to avoid freeze-up. The boiling point of R-134a varies with pressure. If the pressure is not allowed to fall below about 25 psi, the evaporator won't get cold enough to freeze.
There are two ways to do this. The simple one is to have the low side switch cycle off at 25. Thus the compressor cycles during normal operation. The more sophisticated version is a variable compressor with internal pressure control so it stops pumping below 25. In this scheme, the compressor should not normally cycle. There is a low pressure switch that turns off around 10 to protect against running the compressor in case of a total leak-out.
As others said the pressures are the way to diagnose this.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958700
12/22/18 12:54 PM
12/22/18 12:54 PM
RI
RI
When I said fan I mean condenser/radiator fan
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: mattd] #4958728
12/22/18 01:30 PM
12/22/18 01:30 PM
Florida
Florida
There's are a couple of pictures of the pressures with the compressor on and off.
low side reads 30psi/+1
High site125psi/+15
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958740
12/22/18 01:41 PM
12/22/18 01:41 PM
Florida
Florida
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958770
12/22/18 02:14 PM
12/22/18 02:14 PM
RI
RI
Those pressures aren’t bad the high side is on the low side are you sure the system is properly charged? What is the ambient temp? Also when you see the suction line freeze the compressor cycle off? At whatlow side pressure does that happen? If they stay at those pressures it shouldn’t cycle off. It won’t cycle off until less than 10-15psi or less on low side.
Make sure the cooling fan clutch isn’t frozen making it run all the time
ASE Master, L1
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958860
12/22/18 04:45 PM
12/22/18 04:45 PM
Florida
FSully1 Offline
FSully1  Offline
Florida
Need ambient temp......looks under charged, if no compressor issue.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4958933
12/22/18 06:24 PM
12/22/18 06:24 PM
Mn
Kode Offline
Kode  Offline
Mn
I would look at some sensor as the culprit.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959008
12/22/18 08:26 PM
12/22/18 08:26 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Im gonna say there isnt enough charge in it and thats why its freezing up.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959340
12/23/18 10:08 AM
12/23/18 10:08 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If the evaporator blower is not moving enough air , it can affect the suction pressures . Maybe , even to the point of freezing the coil .
If the condenser blower is not moving enough air , high pressure will be too high .
Wyr
God bless
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959702
12/23/18 06:41 PM
12/23/18 06:41 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Fords tend to have dye from the factory.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959925
12/23/18 10:43 PM
12/23/18 10:43 PM
Florida
DONWATERS Offline
DONWATERS  Offline
Florida
I say dirty leaf clogged evaporator core.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959942
12/23/18 10:52 PM
12/23/18 10:52 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
If this van has Auxiliary A/C.....It's way undercharged at 40 ounces.
2001 Chevy Camaro L92/4L80E
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4960594
12/24/18 06:36 PM
12/24/18 06:36 PM
Florida
Florida
No it is a cargo van, it only takes 40ozs, yeah what im leaning at is a partially clogged evap in combination with lower ambient temperature and weak blower motor not moving enough air across the coil. Noticed early this morning when it was colder outside that lines started freezing right away, I also noticed the problem the first cold day we had in Florida.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #5008521
02/12/19 06:21 AM
02/12/19 06:21 AM
Florida
Florida
Sorry to bring back an old thread but found the problem to be a bad low pressure switch, hopefully this will help someone, thank Chris and everyone for their replies.
