Non-DPF engine oil in Diesel BMW F10
by L93013 - 10/14/19 04:00 AM
Mercedes, Worth It?
by rrretiree7 - 10/14/19 02:30 AM
Using Marine Gear Oil in a Tractor
by Hot_Ajax - 10/14/19 12:53 AM
Looking for Everstart battery dimensions list
by jbclem - 10/13/19 11:42 PM
Washed the Terrain
by gregk24 - 10/13/19 10:23 PM
Oil recommendation for my flat tappet cam?
by fusseli - 10/13/19 10:02 PM
Less oil consumption when near add line?
by ledslinger - 10/13/19 09:33 PM
Honda Accord V6 Destroyed -- Timing Belt Failure
by CrackyWainwright - 10/13/19 08:48 PM
Valvoline Advanced Full Synthetic
by GaryPoe - 10/13/19 08:36 PM
Help!!!! 2000 GM 2.4 LITER TWIN CAM WATER PUMP
by Prich - 10/13/19 07:46 PM
Oil running off dipstick after hard driving
by DV0993 - 10/13/19 07:39 PM
Craftsman YT4000 - Slow uphill
by Covington - 10/13/19 07:23 PM
Outside Temperature Gauge
by rrretiree7 - 10/13/19 06:59 PM
Battery judgement based on analyzer
by tvaughn0712 - 10/13/19 06:49 PM
Low number plate
by Nayov - 10/13/19 06:34 PM
Valve Lubrication help
by MikeDanger - 10/13/19 05:31 PM
Havoline Pro DS Problems/Benefits?
by TheLawnRanger - 10/13/19 04:40 PM
Reusing oil filter
by Brojo - 10/13/19 04:11 PM
LMLowner, Gordonhersh, Starrman, Covington, pktrkt
69548 Registered Users
30 registered members (92saturnsl2, Bailes1992, 4WD, bbhero, billt460, 4 invisible), 761 guests, and 35 spiders.
Topics295,943
Posts5,087,727
Members69,548
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959702 12/23/18 06:41 PM
bdcardinal Offline
Originally Posted by laserred96gt
Yes there was dye in the system, must have been the previous owner, I have owned the van since 2011 and never had a problem with the AC.
Blower motor is working, it is not blowing as hard as it used when I first bought it though.
I will check the pressures and read them next time.
Fords tend to have dye from the factory.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959925 12/23/18 10:43 PM
DONWATERS Offline
I say dirty leaf clogged evaporator core.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4959942 12/23/18 10:52 PM
clinebarger Offline
If this van has Auxiliary A/C.....It's way undercharged at 40 ounces.
2001 Chevy Camaro L92/4L80E
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #4960594 12/24/18 06:36 PM
L
laserred96gt Offline OP
L
No it is a cargo van, it only takes 40ozs, yeah what im leaning at is a partially clogged evap in combination with lower ambient temperature and weak blower motor not moving enough air across the coil. Noticed early this morning when it was colder outside that lines started freezing right away, I also noticed the problem the first cold day we had in Florida.
2017 4Runner Limited, 50k
04 E-150, 4.6, 240K, Synblend 5w20.
11 Camry 2.5, 70K, PU 5w20.
Re: Need a little help with AC Ford 4.6 [Re: laserred96gt] #5008521 02/12/19 06:21 AM
L
L
Sorry to bring back an old thread but found the problem to be a bad low pressure switch, hopefully this will help someone, thank Chris and everyone for their replies.
Page 2 of 2 1 2
