Originally Posted by 14Accent
Nonsense. There's nothing wrong with buying a N*, especially a newer one. Anything post-03 will be fine.
The Lacrosse Super's (the V8 ones, like the one you're looking at) are nice cars. They use the same chassis as the Seville in my signature, and many other Cadillac's.
There are a few things to mention:
Magneride suspension: The V8 Buick's used Magnetic dampers, just like Cadillac did. They will fail, and they are expensive. You can replace them with normal struts/shocks for not much cost.
Service effort: Yes, the Northstar is PACKED in. Minor services, however, are easy. Oil changes, transmission fluid, etc. Spark plugs are made out to be awful, but they aren't. The intake boot is known to tear, the part is cheap and the intake comes off in about 30 minutes with hand tools.
People are going to bring up head gaskets, and honestly it's overblown. Yes, the early cars had issues. I've had 4 N* cars over the past 10 years: a '94, a '96, a '99, and an '03. NONE had cooling system issues, and I drive them hard. After GM switched to larger head bolts and a revised torque sequence, the problem was basically resolved short of some idiot drivers abusing their cars.
Oil burning and leaks: All N* engines leak. They just do. The later ones are better, but just expect it to have some seepage from the oil pan and block halves. Also, drive it HARD. These engines carbon up and the rings stick, they need to be brought to redline several times a week and are happy to do so.
The 4T80 transmission is basically bulletproof. Early ones had an issue with breaking shift solenoids, this was easily fixed with an update kit. All models after '00 or so have this installed at the factory. Beyond that, just try and break one.
My take? If the car is $5k or less, buy it if it's in as good a shape as you make it sound. Less than $3k? Buy it and flip it if you don't like it. You won't lose money.
Auction prices Actual sales
12/18/18 $1,000 108,871
11/13/18 $2,700 111,971
11/7/18 $1,550 146,751
12/13/18 $2,300149,813
