1994 Civic LX, 1.5L hard to start
CA
1994 Civic LX, 1.5 with ˜200k
Past month my friend has been having issues with starting the car when it is raining.
On rainy days the car would crank and turn but the car would not start.
We removed the main relay and resoldered and are waiting for a good rainy day to test.
Monday- Drizzled on and off and car started up fine (slight drizzle).
Tuesday- Trouble
Morning was cold (40's deg F), and car started up fine but later that day it got warmer (70's deg F) and car would not start.
Floored the accelerator pedal all the way down and turned the ignition to try to start the car.
It cranked for about 9 seconds and the car finally started.
Ran rough for a few seconds and then drove fine afterwards.
I'm looking at other possibilities that might be causing the issues-
Bad Wires
Bad Distributor
Bad main relay (soldered may not have done job properly)
Fuel Filter (friend says he doesn't remember ever replacing it)
Parts replaced: Cap and rotor about 1 month ago, prior to desoldering main relay. Did not solve issue
Any advice is greatly appreciated
When it won't start, turn the key on but don't crank, and watch for the check engine light to come on then go out. If it comes on and stays on there is a problem with the main relay or the ECU and it's not going to start until the light goes out.
If that is OK next mist some water on the spark wires, if that causes them to short out, replace them. Also check your "new" cap for cracks.
I remember when I got my parents old ford econoline (1990) in 2002. It had never had a tuneup. the misty morning dew would not allow the car to start. I literally had to bust out the hair dryer and dry the wires before it would start. First thing I did was tune that bad boy up.
Visually check the spark plug wires at night . Much easier to see any arcing . Then hit them with the mist , if needed .
In a pinch , I have used WD-40 to " dry out " plug wires / distributor cap .
the main relay controls the fuel pump. turn the key on, but not crank, and see if you can hear the fuel pump start in the fuel tank. if it makes a humming sound, the main relay is ok.
If I were you, I post this issue with a specific Honda forum where the members knows all the quirks of Honda.
Over here, we have member who does not even own a Civic trying to help you from their experience from other type of cars with a different set of quirks/issues.
Have your friend be a member of that forum directly so he can see the answer also.
If you plan to keep the vehicle for a long time you may as well change the fuel filter.
Check the plug wires carefully. Night time with a spray bottle of water is best.
Ok, get a 2nd opinion from the Honda guys. You're not gonna hurt my feelings. The symptoms, including the age of the car, are generiic old heap . and not model specific
That's not an old generic heap, it is a Japanese car from the golden era before they started watering them down for North American sensibilities. I wish they built them like that today.
Where the valves ever adjusted? It might be a long shot, since tight or loose valves on a Honda will result in the engine running funny or needing a valve job due to burned valves. There's an igniter module in the distributor but it rarely goes out in those.
Do the basics first - wires(NGK or Honda OEM), plugs(NGK or Denso), fuel filter and then work up.
Amen. I still longingly search ebay for a 1989 Accord 5 speed like my friend's parents had in highschool. It's getting less and less likely I'll find one in good condition.
With that said, a crash in one of those would make for a bad day.
Update
This morning we decided to perform a few tests that may lead to solving the hard starts.
Test 1
We turned the ignition so that all the dash lights were on and then waited a few seconds to see which lights would turn off (prior to starting the car).
We noticed that the SRS and Check Engine lights eventually turn off.
At the same time we could also hear that classic buzzing sound come on and then turn off (can't remember how many seconds from time it turns on to time it turns off).
Again, all of the dash lights came on and after a few seconds the SRS light turned off first then after a few more seconds the Check Engine light turned off.
Test 2
We turned the ignition like we would normally do and the car fired right up, car turned on. (Cold morning and first attempt to start car).
We then turned the car off and went to Test 3. We did not drive it.
Test 3
We turned the ignition like we would normally do and the car would only crank and would not start (would not turn on).
Test 4
We stepped on the accelerator to the floor (held pedal to floor), turned the ignition to try to start and car started right up.
Test 5
We turned the ignition so that all dash lights turned on and then proceeded to try to start car immediately after the SRS light turned off.
Car would only crank, No Start.
Test 5
We turned the ignition so that all dash lights turned on and then waited for the SRS light to turn off and waited for the Check Engine light to turn off.
Car started with no hesitation
So far, the car will start if we wait for the Check Engine Light to turn off (will not start if Check Engine light is lit).
Whats next:
1. Replace fuel filter. It looks like the fuel filter has never been replaced.
2. Going to check spark plugs.
Turning the key on but don't crank, the check engine light should come on for about exactly 2 seconds then go out. Every time, without fail.
Delayed turn-off of the check engine light is either the main relay or the ECU. If the light is staying on, the ECU is not properly booted up and the engine cannot start.
Check the ECU ground wires on the thermostat housing they can cause a lot of ECU related weirdness.
This is how Civics of that era behave when the fuel level is low, slow pressure buildup, long crank to start. The fact that waiting for the pump to finish priming helps a bit suggests fuel pressure ie filter. On the right track to replace the filter, can't hurt to change it
Takes longer than 2 seconds for check engine light to go away.
Is the action of depressing the Accelerator pedal to the floor when trying to start car somehow bypassing the ECU (making it think that it's flooded)?
We resoldered the main relay but we believe that it might still be bad just by the age itself (1994).
How do we test ECU?
How do we really know that it could be the Main Relay.
Before resoldering the Main relay, the only time we had issues starting the car was when it rained.
After resoldering the relay we started to experience the other symptoms.
Please advise
Sounds like fuel delivery. Filter or pump. Might even being that old have crud blocking the sock on the pickup in the tank. Remember, japmobiles have those wonderful access hatches under the back seat. You Can very easily yank that fuel pump in a few minutes Unlike all the rest of the garbage cars out there. Sort of ironic since I'm like all the rest🙄,those Japanese fuel pumps almost never failed.
You might pop off the upper cover and see of that timing belt is stretched or tensioner slipped. It is only intention by one tiny little 10 or 12 mm head bolt. Remember those engines are interference engines and if you snap a timing belt you almost always destroy the engine. That one should be a belt number three being changed at 60,000. Check for ( if they put it on there) on the timing cover the sticker showing when it was last changed and make sure or just change it will be done with it. And yes those belts it will snap around 65,000 without hot rotting you're dogging it just going down the road, I've done it.
Sounds like the main relay under the driver's side dash; it's a common problem with Hondas. I just had this problem this summer. The car would turn but not start in high humidity. When the car won't start, tap on the main relay a few times and it will probably start; the points crack over time. Resolder or buy and install a new relay.
Update:
Replaced fuel filter and noticed that the check engine light would go away a few seconds after turning ignition (not cranking). The car started fine each time and no check engine delay was observed.
We wanted to see if it would act up in rainy weather so we waited for another rainy day.
Rained last week and so we tried starting the car like normal and without paying attention to Check Engine Light. It started fine.
As the day went on and the rain continued throughout the day we decided to try to start the car again and the car would only crank and not start. It was then that we observed a permanent check engine light when just turning on ignition (without trying to crank or start).
We decided to buy a new main relay (Genuine part by Mitsuba) and we replaced it this morning.
We tried starting the car under cool weather (no rain) and it would only crank and not start. We noticed that the check engine light does not turn off after a few seconds of turning the ignition. The check engine light stays on.
We noticed that the fuel pump whirl sound does not come on so we decided to check for fuel pressure at the fuel filter. No fuel coming out of fuel line to filter when cranking or trying to start.
Again, no fuel pump whirl sound that can be heard when turning ignition (not trying to start or crank).
We are wondering if it's a fuel pump issue (heard it's rare) or the ECU (mentioned by forum member earlier).
What can we do next?
