Car is an 07 Ford Crown Vic with 47,000 miles. Car had 327 rear gear with locker and was very quiet, wanted a little more on bottom so had a local shop install 373 gears. Car had bad whine on slight acceleration at most any speed. No noise off throttle, hard throttle, or coast. Went back to shop and have had 3 different sets of 373 gears installed, all whine. Shop owner tells me all were installed properly and at correct specs. I am at a loss as what to do next; take it to another shop, try some super heavy lube, or just live with it? I have to believe that a gear set can be installed without whine. The old saying "only a fool continues to do the same thing over and over, expecting different results" may apply to me in this case. Opinions will be much appreciated.
