Originally Posted by MolaKule
For some reason they had to declare the Molybdenum dialkyldithiocarbamate (MoDTC), as one of the "Long chain alkyl thio carbamide metal complexes."
MoDTC is primarily a friction reducer with some secondary anti-oxidant and AW properties.
Thanks MolaKule. There was some mention of molybdenum polysulphide in some of the places I checked. I had wondered about that.
The prefix thio in chemistry means, "the oxygen atom in the compound has been replaced by a sulfur atom."
Here is the basic Dithio structure in the first image. Notice at least two (Di) sulfur atoms are linked, which could be a "poly-sulfide" type of structure when the same type of structure is "repeated."
Add a metallic linkage to it and you would have, say a Molybdenum Dithiocarbamate or MoDTC molecule as seen in the bottom image. The "carbamate" part represents the carbon atoms linked into the "MOlybdenum DiThioCarbamate" structure.
"ide" tells us that this is a compound made up of only two elements. For example, "carbon dioxide." Notice that is made up of just two elements, carbon and oxygen or CO2.
"ate" usually means the compound is made of three elements or "groups" of three elements, such as for example Calcium Chlorate or Ca(ClO3)2.
That will be an additional charge of $1300.00 for the semester.
