2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
34 registered members (carlprop, 1.8Tango, BobGoblin, 69GTX, 4 invisible), 948 guests, and 33 spiders.
Topics296,864
Posts4,960,360
Members66,982
Most Online2,688
Jan 19th, 2019
Old Cummins small cam filled it up 8 gals of oil 2 bottle of lubomoly 2 good ? #4952409
12/15/18 01:23 AM
12/15/18 01:23 AM
nj
BigRich954 Offline OP
nj
I have a old small cam Cummins which are known for wiping out the camshaft lobe‘s. I put 4gallons of T6 and 4 gals Delco 15 W 40 then put in two bottle two bottles of Liquid Moly and two bottles of the ZDDP plus Additive
Do you think that should be good to cover the camshaft from getting wiped out even with the low amount of bottles and large amount of oil?
Re: Old Cummins small cam filled it up 8 gals of oil 2 bottle of lubomoly 2 good ? [Re: BigRich954] #4952440
12/15/18 04:11 AM
12/15/18 04:11 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Pretty potent brew, You should be covered. laugh
If you want the job done right......do it yourself.
Re: Old Cummins small cam filled it up 8 gals of oil 2 bottle of lubomoly 2 good ? [Re: BigRich954] #4952514
12/15/18 08:03 AM
12/15/18 08:03 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
It will defienitely be noticeable if you have it analyzed, but normally they recommend 1 bottle for up to 5 liters, so it may be weak.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Old Cummins small cam filled it up 8 gals of oil 2 bottle of lubomoly 2 good ? [Re: BigRich954] #4952540
12/15/18 08:46 AM
12/15/18 08:46 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
It won't help. That Cummins has roller cam followers. They wear down when fuel pressure is turned up by changing the button in the pump.
Won't be a problem @ normal hp ratings.
What hp is yours?
Most held 12 gallons with both filters replaced.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Old Cummins small cam filled it up 8 gals of oil 2 bottle of lubomoly 2 good ? [Re: BigRich954] #4952720
12/15/18 01:25 PM
12/15/18 01:25 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yup. In std tune they are reliable. But, of course, every concrete cowboy out there turned them up ...
Re: Old Cummins small cam filled it up 8 gals of oil 2 bottle of lubomoly 2 good ? [Re: BigRich954] #4952949
12/15/18 08:08 PM
12/15/18 08:08 PM
nj
nj
I’m pretty sure it’s a stock 400hp small cam from what I told.
I thought they had flat tappit cam followers . It might have put closer to 10 gals cause I did have to top it off a few times. .
I could only find one oil filter on engine and one aftermarket luberfiner 750 filter
