I got it in the mail Monday, and did a valve adjustment / other maintenance on a Honda Element yesterday,
It loosened all the 8 and 10mm bolts fine. It probably overtightened these bolts past their spec 9 ft lbs for many. But then, I wouldn't have torqued the bolts i did use this on anyway during assembly.
-It did not have enough torque to loosen a 12mm power steering pump bolt
(tightening spec 16 ftlbs - albeit extremely grimy bolt), it did spin it off after loosening with a ratchet.
-The head was too large to fit to try to loosen the second (hidden) 12mm power steering pump bolt. (Frame of car, ac lines, ps hoses in the way).
-I wasn't going to touch my spark plugs, or any valve cover reassembly with a power tool.
-of course, this wasn't going anywhere close to the locknuts
All in all, it did save time. It's not magical though, as it should probably be used with discretion.
If I had bought the 3/8" fuel version with a higher torque capability, I presume it would have helped getting the one power steering pump bolt out. Still wouldn't fit into the space for the hidden power steering pump bolt. It may or may not have fit into the space of a few bracket bolts that were attached to the valve cover. I may not have used it for many of the random reassembly bolts. I'd be afraid of overtigtening things and breaking plastic casing parts.
